Old 10-19-2006, 06:50 PM   #1 (permalink)
My Photos: (38)
What GPM does an electric fuel pump need to be?
I want this to flow as much or more than a stock superduty pump.
Who has done their own fuel supply system eliminating the fuel bowl, mechanical pump etc?
What pump did you use?
I've heard of using a Holley pump, which one?
Just trying to find one cheaper than a new Super Duty pump.
Thanks guys.
This is for a fuel system on a 97, just to clarify.
some stuff
14.8 @ 90
gregrob is offline
Old 10-19-2006, 06:59 PM   #2 (permalink)
Soaggydogg's Avatar
My Photos: (11)
Re: What GPM does an electric fuel pump need to be?
The super duty pump has been proven over and over. There are cheaper pumps and more expensive one but I would stick with a SD pump and not enough then use two of them.
'95 F250 Ported Snorkle, Foil Delete and a little more
'02 Excursion Matched Perfect and Staggered Special
Total Diesel Performance Custom Tuning
Rockin S Performance BTS dealer
good-times.webshots.com/photo/2120855500037306169oDlfMF Well did you touch it?
Soaggydogg is offline
Old 10-19-2006, 07:16 PM   #3 (permalink)
My Photos: (38)
Thanks Ben. Any idea what the super duty pump flows.
What about a Holley blue? Hasn't someone used one of those?
some stuff
14.8 @ 90
gregrob is offline
Old 10-19-2006, 07:19 PM   #4 (permalink)
Greg, after 6k posts ya think you would know that the search utility is your best friend [img]/ubbthreads/images/graemlins/smirk.gif[/img] [img]/ubbthreads/images/graemlins/laugh.gif[/img]
cary
1971 EB Hard Core Crawler
2006 Yamaha FJR1300
2005 Suzuki King Quad
caryt is offline
Old 10-21-2006, 03:35 AM   #5 (permalink)
Most of the aftermarket pumps are not specifically designated as diesel compatible. I bought my last SD pump (to run duals) for $200 new (Airtex E2236) and know that a single pump (my Bean's fuel setup) will support 400+ hp properly plumbed. I haven't heard of many SD pump failures but maybe in a regulated return system the failure rate could be higher due to the amount of return fuel flow opposed to the stock dead head SD system. The aftermarket pump survival rates don't seem very high, like the Aeromotive A1000, for example, isn't it rated for only around 2000 hours? I don't recall if any of the common small pumps (like the Holley) are diesel rated or what the life expectancy is. I opted for the SD pump since its been proven to be long term reliable, cheaper than the big Aeromotive, easy to double up and for sure is diesel compatible.
As I recall, someone once posted the OBS federal single shot engines pumped just under 20 gph at around 50psi or so. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Dave Murakami 97 F-250 XLT Supercab PSD OffRoad, Bilsteins, Warn manuals, Rhinoliner, Bridgestone 285's, molded steps, smittybilt grille guard w/frame braces, Cibie driving lights, power rear window, Sony CD changer w/infinitys+basslink subwoofer, Tekonsha Prodigy, Snugtop, Reunel stainless steel rear bumper w/Warn HS9500 winch/PIAA backup lights, TFI, 7500lbs, 14.508 1/4, 408 rwhp/#2only, banks powerpack, gutted ebpv, 4" duals, map pressure regulator, JSidm, BTS, maddog stage II ABs, Bean's fuel system, Terminator, dieselpower tri-chip, tymared, black intake, non-fluttering Isspro EVs, almost stock!
masami is offline
» Sponsor Links
»Garage Storage and Cabinets
