Old 09-11-2005, 10:47 PM   #1 (permalink)
busbreath's Avatar
What Intercooler options are available?
General searching around here and on the web only turns up three options:
Banks - Expensive
Hypermax - small, expensive, not very available
Retrofit '99-up - Good kits, etc.
Are there any other options not listed, and what sucess/problems have you experienced with any of the options listed, or? My main concern is reducing EGT while towing, but this might provide good info for others as well. Other options that reduce EGT besides intake/exhaust mods would be welcome also. Thanks in advance for any input.
Doug
97 F-250 extra cab 2WD. K&N FIPK, 410 gears, Pace Edwards roll-top bed cover, Reese 16K 5th wheel hitch, defender trans cooler, 96K orig! New to me 10/2003. Pyrometer and trans temp pillar, boost gauge, SCMT, exhaust brake & t/c lockup, Hypermax downpipe/tymar out 4", ATS Intercooler (Thanks CaryT)
Mother is the Necessity of Invention!
busbreath is offline
Old 09-11-2005, 10:57 PM   #2 (permalink)
Patrick Feeley's Avatar
My Photos: (18)
Re: What Intercooler options are available?
There is also the ATS kit that I think is easy to install, but uses smaller size tubing. Cheers!
1994 F350 CC DRW 2WD PSD (ALF4), ZF 5 Speed, 4.10 LS, SBC Con-O SMFW/Clutch, Baldwin Filter, Tymar HPX Hose, DPPI DP, Bilsteins, $12 AIC, Coolant Filter, Stancor GPR, Explorer Overhead Console, A-Pillar w/ISSPRO Black Ice, EV Boost, and EV Pyro (pre-turbo) , Relocated Block Heater Plug, Modified Pedestal, Gutted EBPV.
Patrick Feeley is offline
Old 09-12-2005, 12:08 AM   #3 (permalink)
DaveBey's Avatar
My Photos: (212)
Send a message via AIM to DaveBey Send a message via Yahoo to DaveBey
There are four main options when it comes to adding an intercooler on our trucks: Banks, Hypermax, ATS, and '99+ Retrofit.
Banks, Hypermax, and ATS all sell kits designed for our trucks. Of these, the Banks kit probably flows/cools the best but, as you said, is very expensive. The next option and just as good, and for a better price, is the Hypermax. The ATS cooler is designed to fit behind the front bumper and may not require as much cutting as either the Banks or Hypermax.
The '99+ retrofit is a much cheaper option and with the GTS Motorsports kit readily available, it eliminates the need for custom fabrication.
If you are going for maximum cooling (and cost) the Hypermax Tapercore intercooler is the only way to go. This is designed for the '99+ Super Duties and has to be modified a bit to fit in our trucks but it can be done.
All of these intercoolers do their job just fine so it really boils down to how good a job they do on your pocketbook. [img]/ubbthreads/images/graemlins/tongue.gif[/img]
Cheers from Orlando, FL! [img]/ubbthreads/images/graemlins/smile.gif[/img]
Dave
1996 F-350 XLT CC SRW 4x4 with plenty o' Redneck Bling: APCM●BTS-E4OD●4L10●MADDOG injectors●Hypermax H2E, intercooler, & exhaust●TYMAR intake & HPX●TSM disc brakes●Hydro-Boost●International water pump●215 amp generator●CCV re-route●285/75R16 Wild Country XTX tires●Centramatics●Denon DCR-830RD & DCH-520 203,000 happy miles
DZLJIM 3:16
~~NTxPSA - Hold my beer and watch this.~~
DaveBey is offline
Old 09-12-2005, 09:25 PM   #4 (permalink)
My Photos: (5)
The 6 liter retrofit isn't a bad job either, right? Some good talk about that a while ago but haven't heard anything recently.
Truck: '97 F250 PSD , ext. cab, shortbed, 5-speed, 4wd, 4.10L
Upgrades: BDP Stage I's, Stealth HPOP, BB Turbo with 1.0 wastegated housing, 6 pos DP Tuner chip, SBC OFE, dual SD fuel pumps, traction bars, US Gear OD, MAP regulator, SP Dongle, downpipe, extra 45 gal fuel tank, EGT-boost-TIP gauges, bilsteins, TYMAR, no cat, 3.5" flowmaster into 4" exhaust, gutted EBPV, XM SKYFi2, cab lights, BFG AT 285/75/16, Autoenginuity, 169k on 5/10/06
Coming soon: 6.0 Intercooler
Dyno'd 298/575, 296/582 before Stealth and Turbo
swh22 is offline
Old 09-12-2005, 09:36 PM   #5 (permalink)
Banned
For band for the buck the retro takes it. If you want all out the tapercore is hard to beat but doesn't come in a kit to install in the '94-'97 trucks. Theoreticly an install kit that works for the retro SD coolers should work but it hasn't been confirmed as of yet. The Banks cooler is probably the best kit available but is spendy. Hypermax makes a kit for the '94-'97 trucks as well that is pretty good too.
gtspowerstroke is offline
Old 09-12-2005, 10:00 PM   #6 (permalink)
Banned
i stuffed a 6oh ic into my truck, works well [img]/ubbthreads/images/graemlins/grin.gif[/img]. Pics are in my sig.
luke
lukecline is offline
Old 09-12-2005, 10:22 PM   #7 (permalink)
Another way to reduce EGT's is to put on a more efficent turbo. But it will cost more than the intercoolers.
MY TRUCKS
1996 PSD F-350 crew cab 4x4, AB CODE CALIFORNIA TRUCK, 5 speed,CON-O SMFW modified by Southbend Clutch, ORU Reverse Shackle kit, 4:10, u.s. gear chip, IDM MOD BY ME , down pipe, 4 inch straight pipe, boost and EGT gauges,PRO COMP A/T's 305-70's, Bilstein's, ditched the k&n filter for an open element Baldwin PA 2818, kenwood & polk audio sound system.
2002 Excursion PSD 4x4 XLT Premium- TN BB 1.0 Turbo , 6.0 IC, 8 inch Sky Jacker lift, FOX shocks with remotes, 35-12.50R17 BFG Muds mounted on 17x10 Boyd Coddington Billet wheels, ORU Frozen rotors, custom hybrid intake, DVD/2 monitors, Billet grill, XM radio, DP Tuner PCM QLJ5/PMT1 combo, Edge Juice/Attitude for gauges.
SOUTHERN CALIFORNIA POWERSTROKES MEMBER
mattymx is offline
Old 09-12-2005, 10:46 PM   #8 (permalink)
Banned
Believe it or not my egt's didnt drop after h2e install. Egt's did however at higher boost (25+ psi) not skyrocket anymore. IMO if you want low egt's a 6oh ic is the way to go, period.
Old 09-12-2005, 11:05 PM   #9 (permalink)
sorry a lil off topic but luke whats with the t/c lockup mod? and i talked to wildman tonite and he said to talk to u about 6.0 i/c i was wonderin how much time u had into it
Joey
97 F-350,XLT, 4-dr, auto, 270xxx mi, Geolander A/T's, 4"exhaust, no ebpv, 203* t-stat, electric fans, lunar gauges, amsoil nose to tail, custom weight bracket and hitch for pullin, diy intake/air filter, hpx hose, LED cab lights, extra fuse panels, kenwood stereo system, pedestal from Rick, 4r100 out of an '01, trans mods from Jon, custom big fuel system, arb's front and rear, and 6.0 i/c, custom big oil
pics
"...the smoke rolled out and the day turned BLACK!"
stage II's
D66
THANKS BEAN!
awesome tuning
THANKS TONY!
'06 M7 153" Let it Snow!
joeyslushr is offline
Old 09-13-2005, 09:23 AM   #10 (permalink)
I put the Banks powerpack kit on my truck and am very happy with it. That being said, I wish I knew of this site prior to that purchase, because it was expensive. The install went smoothly, and egt's are fine, so I guess I'll live with it.
94.5 F350, DRW,CC 4.10's LS, Banks Powerpack, Centaurus II conversion pkg, homemade Tymar style intake, LuK clutch conversion, 115k miles and counting!
Biff is offline
Old 09-13-2005, 12:28 PM   #11 (permalink)
Banned
Pm sent joey [img]/ubbthreads/images/graemlins/wink.gif[/img]
Old 09-13-2005, 12:53 PM   #12 (permalink)
We're installing the Sledgehammer charger (tad smaller than the ASB), and a 6L intercooler on a 95PSD...new FE Clutch...gonna be sweet.
Powering the Fastest (no drugs) Power Strokes @
Thunder in Muncie 2004
TS Performance All Diesel Challenge 2004
Indianapolis Diesel Nationals 2007
Scheid's Diesel Extravaganza 2007
Powering the top Ford pullers @ the
Indianapolis Diesel Nationals 2006
99 F250
550hp #2
680hp NOS
Competition Injectors by
Swamp's Diesel Performance
866-595-8724
golfer is offline
Old 09-13-2005, 09:04 PM   #13 (permalink)
busbreath's Avatar
Thanks for all the replies! I was also curious about options to an intercooler (chip, etc.). I currently tow with superchips 1705 on tow safe, but I'm sure there are better options on a real 4 pos. chip. Dale at Tymar suggested that there might be better options to reducing EGT than a retrofit intercooler, but I have not yet had a chance to discuss this with him. I remain open to other options as well!
Thanks again,
Doug
Old 09-14-2005, 12:06 AM   #14 (permalink)
Keep in mind you need to lower the sway bar mounts 1 1/8" to clear the IC on 2wd trucks with the GTS/99 retro kit.
97 F250 XCab SWB 5spd, 4.10, Built 10/97. South Bend Clutch, 3"DP, 4" AFE, GTS Intercooler kit, Tony's Tunes, Gauges, and a list of $hit I want thats getting shorter.
°=ALT248
The day they take away the 2nd amendment is the start of the 2nd revolution.
LCOwner is offline
Old 09-14-2005, 02:50 AM   #15 (permalink)
Banned
Other options would be to get better air flow through the engine such as a better flowing intake and exhaust system or running a lower hp chip. You could also upgrade the turbo but you probably aren't getting the stocker out of it's efficiency range so that probably wouldn't help much. Dale doesn't seem to like intercoolers much especially the retro ones. Yes they make more lag but if you want to make it run cooler and more efficient then it's a must when you start turning these things up.
