Old 08-09-2005, 12:25 PM   #1 (permalink)
My Photos: (6)
What are the issues with a 02 HPOP on a 95?
I seem to recall that people have said that I will have problems mounting a 02 HPOP on a 95 HPOP reservoir? Something to do with a check valve or something?
Can someone explain this to me?
I will be upgrading to some stage 2 or 3 injectors at some point and will probaly need to upgrade the HPOP at the same time so I am trying to collect info on what my buy list will have to be and what I my options are.
Would it be easier to just install a 20 degree pump or Stealth pump? (excluding cost considerations) Would I still need to modify or upgrade the reservoir?
thanks in advance!
'95 F250 XLT 4X4 Ext Cab long bed, 5 speed, SMFW, custom kevlar LuK clutch by Superior Friction San Jose, 3.55 LSD, '88 kingpin D60, Sky RSK with SD V code springs, 175K miles, ATS 1.15 BB turbo, BDP Stage 2.5 injectors, BDP fuel system, 4 line Stealth, '02 120V IDM, ARP studs, Spearco 7.3 intercooler, 3" intakes, Northern Diesel Performance 6-pos TS chip w/TW tunes, guages, Tymar intake, EBPS bypass mod, IH bellowed uppipes, 4" DP, straight exhaust, 200PSI train horns and 215A alternator..
Home of the 94 and 95 HPOP anti bleed down mod
General Truck pictures..
radarman is offline
Old 08-09-2005, 05:14 PM   #2 (permalink)
My Photos: (37)
Re: What are the issues with a 02 HPOP on a 95?
it is really easy. there are two fittings that the braided steel lines run to from the rails, when you buy the new pump you must reuse your old fitting, really really easy.
if i had to do it over i would go with the 20* pump cause the cost is not too much more for the amount of oil it will move. i have not thrown a cel with everything in my sig so thats pretty good, but i think it could use some more oil up top.
New truck 1984 f-250 xlt ext cab. in progress
Newer truck 95 ctd
*SOLD*1997 f-250 auto, 4x4, 132,000,crewcab,remote start,relocated batteries, beans custom stage II's, beans custom 6 pos. chip, beans headstuds, 2002 intake plentums, 2002 HPOP, custom cold air intake, dual 6-in stacks, 4-in lift, 35-in MTR's, auto meter phantom gauges, (3rd) monsterbox tranny, billet input shaft, triple disk TQ, 4:10 Limited slip, snow performance water/meth injection. block painted sonic blue pearl
HP= 388 TQ= 732 w/o water/meth
1/4 mile= 14.4 @ 96mph with dp tuner 6 position chip
PICS
andrew974x4 is offline
Old 08-09-2005, 09:23 PM   #3 (permalink)
Nit
on a 95 you don't have a stand pipe biult into teh res cover, it will drain over 8 hours with a 02 pump on it. I do have a fix for it if you PM me.
1997 F250 FireTruck Red,CC SB,auto( Prescion TC, HD-2Tugger),5" exhaust, custom Swamp 195cc Hybrid injectors, TWildman 4-pos chip,open air cleaner, I/C w Banks intake, 225,000km,AIC,dual electric fans,Sky mfg RSK w/ D60w/ARB locker,Ramsey 15k# winch, BFG/AT 315's, F450 rear springs, home of Craig's Performance Diesel
pictures
" lying is a cheap way out of reality, the real cost is the loss of respect and trust"
dirty30
Nit is offline
Old 08-09-2005, 09:46 PM   #4 (permalink)
You will need Nit's fix. It works great! [img]/ubbthreads/images/graemlins/grin.gif[/img]
Clayton,
<font color="red">*ASK ME ABOUT MY AWSOME TWILDMAN CHIP*</font>
95'F-350 4x4
Truck PICS SOLD!! (due to exwife!)
99' F-250 CC 4x4, 4r100 SOLD (due to exwife!)
99' F-350 SC,2WD,auto (New GF's truck!!!!)
Ride It, Rope It, POWERSTROKE IT!
bulrid8 is offline
Old 08-09-2005, 10:10 PM   #5 (permalink)
My Photos: (5)
yep
1999.5 cc dually
69 mustang, 472", c/4
9 sec alky injected bracket bomber....
529" in the works as we speak
Richter69 is offline
Old 08-09-2005, 11:28 PM   #6 (permalink)
Powerstroke2000's Avatar
My Photos: (17)
I'm using one of Nit's acumulator tanks on my '95 truck with my '01 pump, and it works perfectly! Send him an e-mail or PM him, and he can fix you up.
It's a simple install and works real slick! [img]/ubbthreads/images/graemlins/smile.gif[/img]
Dale
IDM mod
TYMAR intake
Amsoil dual by-pass
Precision Ind triple disk Torque Convertor & Pro build tranny
Transgo Tugger shift kit
Ford AIC & full gauges
Mini-Me/SWAMP 250cc Hybrid 530 injectors
17° HPOP
5" custom exhaust
Superduty Intercooler & GTS pipe kit
CCV mod
TS 4 position Flip Chip
<span style="color: blue"> My truck </span> & <span style="color: blue"> Dual Idler Tensioner mod </span> , <span style="color: blue"> Superduty HPOP & Mini-Me ~ Swamp Injectors </span>
Powerstroke2000 is offline
Old 08-10-2005, 01:49 AM   #7 (permalink)
GSXRTURBOQUAD's Avatar
I have another fix: A Dual Pump System(Stealth or Terminator) will fix any and all issues. Best part is, Big Oil. I played with another little fix, seemed to work well if the vehicle was started every 10-12 days, any longer it would bleed down as well, but that's history. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
95 F350 Crewcab4X4: TE Twin Turbo(BB fed by a Turbonetics TN76 from BWD), DDP BD Injectors, DIIC with custom stainless 3" piping, <span style="color: red">Terminator HPOS</span>, DI headstuds, BTS tranny, TruCool 40GVW cooler, <span style="color: blue">DP LIVE TUNED F5 with Extreme ICP!</span> , Custom fuel system, MagHytec diff cover.
01 F350 Regcab4X4: soon to be sold.
97 F350 Regcab4X4: Project(everything to make power).
02 Excursion4X4Limited: Wifes ride(stock)
<span style="color: red"> www.TerminatorEngineering.com, Proud Sponsor of the Diesel Stop.</span>
<span style="color: blue">Terminator High Pressure Oil Systems</span>
http://community.webshots.com/user/gsxrturboquad
SDRCM #7
GSXRTURBOQUAD is offline
Old 08-10-2005, 09:33 AM   #8 (permalink)
My Photos: (6)
Good good..
thanks for the info fellas..
So, do the upgraded pumps need the same fix that Nit has or do they bypass the entire bleed down issue?
radarman is offline
Old 08-10-2005, 09:35 AM   #9 (permalink)
Would this be the same on a '96. I recently purchased a humped hpop to upgrade my stocker, just wondering what to expect on the install.
'01 F-250,4x4,SC,LWB, Evans coolant/coolant filter, ATS Stage 5 tranny/torque converter, V-10 tranny cooler, 3.73 w/Detroit locker, Truetrac front, Bilstein 5100's, Auto-Meter Phantom's, 5" Hypermax exhaust
BDP
'02 F-250 4x2 CC SWB 4R100, 3.73ls(shimmed carrier), DI chip, CCV mod, 203* t-stat, coolant filter, AIH delete, Tymar HPX oil line, AIS, WW, Banks 1.0 "slowspool" housing, pedistal mod, Banks elbow&BHA, 4" turbo back w/btm, Isspro's
6.0 intercooler install(OBS)&truck pics
<span style="color: red">RDRCM #10 </span>
Sniper's credo "If you run, you'll just die tired"
richmondfarms is offline
Old 08-10-2005, 11:59 AM   #10 (permalink)
I will be soon, too. Please tell. [img]/ubbthreads/images/graemlins/grin.gif[/img]
- Ryan
<font color="red">7.3 POWERSTROKE DIESEL</font> F-250 Flatbed 4x4 -- full info and pics inside
<font color="black">DOB 6/10/1996</font>
<font color="red">bdp</font> <font color="#8B7162">Stage I injectors and custom programs</font>
<font color="orange">SBC</font> <font color="#8B7162">Con OFE</font>
<font color="green">2002</font> <font color="#8B7162">SD HPOP</font>
285HP
Live in SoCal? Check out SoCAPS! [img]/ubbthreads/images/graemlins/grin.gif[/img]
ryanPSD is offline
Old 08-10-2005, 12:23 PM   #11 (permalink)
My Photos: (6)
I am told that the bleeddown issue is only a factor on PRE 96 strokes.. The 96 and newer do NOT have this issue..
Lucky people.. [img]/ubbthreads/images/graemlins/depressed.gif[/img]
Someone correct me if I am wrong.
radarman is offline
Old 08-10-2005, 05:09 PM   #12 (permalink)
You are correct, 94 and 95's only.
On the Dual pump kits, just specify you have a 95, and you will have no issues. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
SDRCM #7
» Sponsor Links
»Garage Storage and Cabinets
