Old 04-21-2005, 12:22 PM   #1 (permalink)
What mods first?
I'm picking up my first Ford PSD 7.3 1997 CC 4X4, was wondering what modification should I do first , is there a power chip? exhaust brake?? I'm not new to diesels but what do the knowing folks recommend for an engine manual? Just replaced my heads on my 6.5 Suburban ouch!! I will be towing a 29ft trailer about 5,400 lbs (well with in the limits of this truck), I will put the vegetable oil fuel system in.Also make my own biodiesel. Your wisdom will be appreciated.
webberrl is offline
Old 04-21-2005, 12:47 PM   #2 (permalink)
ChrisMartinTX's Avatar
My Photos: (6)
Re: What mods first?
auto or manual?
mods:
-TYMAR or that style air cleaner
-at minimum new downpipe if not a full exhaust
-chip
-ccv
-if you live in a warmer climate the a/c mod never hurts
-shim the fuel presure regulator
-then if you are serious about mods, ie injectors and crazy power... contact bean or swamp
oh and check out steve baz's website
http://pages.prodigy.net/stevebaz/
97 F-250
Specs
ChrisMartinTX is offline
Old 04-21-2005, 01:22 PM   #3 (permalink)
My Photos: (28)
Gauges first, then the list above.
'97 F350 CC, XLT, 4WD off road, 4.10, Milemarker manual hubs, Suncoast E40D w/ Bob Riley's (Dieselsite) remote filter & Triple Lock Torque Converter, Hypermax H2, BABY SWAMP'S! Swamp's 20* HPOP, Head Studs, TS 4 position chip w/ Bill's programming, Banks Intercooler. Ceramic coated up-pipes and down pipe. Triple pillar w/ Isspro boost, trans temp and digital EGT gauges. 4" Exhaust. 45gal Transfer flow rear tank. Dale Isley's HX mod. Joe Servo's IDM mod. Bob Riley's coolant filter, Coolant "T", Evans Coolant, A/C mod. Velvet-Ride's, Monroe Gas Magnum Shocks. TSM's rear disc brake kit. Frozen/ Slotted front rotors with Hawk Pads. Centramatic Wheel Balancers & 285/75/16 Michelin LTX/MS. Interior sound deadening (what a difference!).
BLDITRT1 is offline
Old 04-21-2005, 01:38 PM   #4 (permalink)
ChrisMartinTX , what is a ccv?
1996 F350 C/Cab,7.3L PSD/M Burgundy/15000 lb warn winch/Tymar filter/4"exhaust/no kitty/pre turbo pyro/boost guage/BD4banks chip/no back seat, custom tool box instead/110 4000 watt inverter/on board air/200 amp alternator/4"lift/ Royal purple oil rear 75/140,syncromax in tranney/RottelaT 15/40 in engine with Durolube/Evens npt+ watterless antifreze/luk clutch solid flywheel/home made AIC/power stearing line mod/home made traction bars,
shendoa is offline
Old 04-21-2005, 01:45 PM   #5 (permalink)
My Photos: (12)
crank case vent
its on the driver side valve cover and vents into you intake.
most people me included turn the vent around and hook a long piece of hose to it and run it out towards the back of the truck or plumb it into the exhaust.
I'm not real sure how this helps anything other than keeping you turbo blades clean of oil and grime.
of course then you will have to plug the hole on your intake hose.
Josh
'95 F350 PSD CC SRW 4x4 4.10s 5spd LUK clutch, hypermax dp 4in exhaust, tymar, shimmed fuel reg, gutted ebpv, big bumpers, isspro pyro, 250K miles
TexTon is offline
Old 04-21-2005, 01:51 PM   #6 (permalink)
MarkEkberg's Avatar
My Photos: (13)
Same as what has been mentioned before.
Gauges
Chip, make it something that will work with injectors
Downpipe
Intake
injectors
intercooler
MarkEkberg is offline
Old 04-21-2005, 01:55 PM   #7 (permalink)
ok thanks, I will do that. clean turbo sounds good.
shendoa is offline
Old 04-21-2005, 01:57 PM   #8 (permalink)
will shimming the fuel reg give me worse miles per gallon? and will it hurt the fuel pump?
shendoa is offline
Old 04-22-2005, 02:54 PM   #9 (permalink)
If it's an auto get a tranny temp gauge 100-250 deg before anything else.
Second would be any of the following: bigger tranny pan, tranny cooler, inline Magnifine tranny filter, Tymar air cleaner. Pyro gauge.
Third tier: Boost gauge, coolant filter.
My 2 cents - TP
'96 F-250 PStroke 4X4 E4OD
'74 Bronco 4X4 302/C-4
'03 Kawasaki KLR-650 2X1
KROWBAR26 is offline
Old 04-23-2005, 12:23 AM   #10 (permalink)
My Photos: (6)
Mines shimmed and I still can get 23 mpg... Did it fairly soon after I got the truck so don't have much to compare it to. My pump did develop a leak a few months later, however it did have 80000 miles and you kinda have to expect that when you are making something that is broken in at one pressure for hours or running to nearly double. Wasn't to early for it and was worth the gain to me... Pumps are only a hundred bucks or so. You could always just wait til you need a new pump. Oh and I rednecked mine with a BB, if you wanted to spend some money you could get the california regulator sping and junk from ford. I'm sure baz's site has something written up on it. Gauges are over rated...
97 F-250
Specs
» Sponsor Links
»Garage Storage and Cabinets
