Old 03-27-2008, 04:00 PM   #1 (permalink)
My Photos: (22)
What programs are you Stage1 guys running?
Looking for some input here. I'm looking for input on Tony's programs as well as Jody's. I'm looking for a program that will make my stage 1's act like a STOCK INJECTORED truck with a hot program. Basically I need a program that allows me to make pretty decent power (maybe a little more than what a maxed out stock injector can do) that isn't go to blow black when you push it down. I don't mind smoke but want to keep it to a minimum...especially in the bottom end. I know I can get Tony to tweak my chip, but I think it would be easier and quicker to find out from you guys what you are running. I'm pretty happy with postion 3 and 4 but I need to get #2 which is my daily driver position hammered out. I have considered switching to a DP-Tuner chip as well, so input on both of these guys programs would be appreciated.
Jerry
1997 F-350 XL Crewcab 4x4 SRW PSD a.k.a MEAN GREEN. DP-Tuner Chip, DIY Stage 1 injectors, D66 Turbo with 1.0 housing, K&N FIPKwith Amsoil element, 4" exhaust to 5" stacks, Banks intercooler, CCV modded to RDT, 4" Superlift with 35" BFG AT's.
1993 F-350 XLT Crewcab 4x4 SRW 7.3IDI non-turbo Project Truck
Jerry Miller is offline
Old 03-27-2008, 05:13 PM   #2 (permalink)
I run TW programs
hiidle
stock
tow
econo 80 i think
Powertrip
Tubzz dyno
Powetrip is a very agressive and fun tune, tubzz is a fun one too. Powertrip will roal the coal. Give him a jingle he'll set u up.
Dan
1997 PSD #34 15.093 @ 88.63mph(on BDPstage1s) Beans electric fuel, H2E FFD 230cc stroked acodes TWildman 6 position Tymar intake, 17*hpop, IDM mod, diamond back 4" turbo back dual exhaust (SD DP), Arp studs, comp valvesprings, 7.3 intercooler, Rough Country 4" lift, 315 Cepeks FC 2 on MT classics, Bdog electrolum gauges (pre/post turbo pyro), E4OD auto, 4.10LS, TC LU w/ ind light, CCV mod, Richter69 TC and accum body, 203* tstat, clear turn signals, toolbox light, ford manual hub conv., ext trim gone.
Highest hp 362, highest tq 723 corrected onstage 1s
future mods: bigoil, 2nd fuelpump
Work truck: 03 7.3 excab lb F250
New Family rig: 2002 7.3 Excursion edge evo II, mbrp 4" tb exhaust, tymar intake
Big_Dan97's Photos
Big_Dan97 is offline
Old 03-27-2008, 05:15 PM   #3 (permalink)
My Photos: (22)
Dan,
Can you tell me more about your Tow and Econ setting? How is the power and the smoke.
Jerry
Old 03-27-2008, 07:05 PM   #4 (permalink)
My Photos: (21)
I don't have stages, pretty much stock.... but what I have been playing with is some different settings on my TW chip.
Econ - seems to be doing quite well, not sure if it is part of the programming, but it stays in 3rd to about 2000 rpm, then switches to 4th. Its a smooth transition. Not as quiet as stock mode.
Daily - idles smoother than Econ, and has a bit more perk. I like this one a lot. And it does wonderful while pulling a 14,000 horse trailer.
Tow mode - Not sure about this one yet, seems like Daily works just as good, but with a bit more pep. I ended up switching back and forth in the mountains, and I think there are shifting differences. Not sure yet, still learning.
No added smoke on any of the modes, which is great.
( I would love to know more details about all of Tony's modes...)
-1997 F350 XLT crew cab 4x4 with big steel Gage RanchHand bumpers, Tymar intake ( 1-2 mpg improvement ) , 3" to 4" DP 4" exhaust exiting in front of rear wheel w/5" SS downtip. DIY AIC control ( AIC on Ebay now ), Premium Warn Manual hubs just installed, and Alpine 6 1/2 - 6x8 component speaker system. TW 6 pos chipset.
-1979 F250 4x4 with 33", gas 302. All farm truck, more rust than truck, more spunk than Chevy.
-1970 Ford 3400 tractor, 3cyl diesel with a cracked loader ( no longer cracked, I learned how to weld, yeeeaahhh! )
-1983 White/Herc 6cyl deisel 65kw genset that provides 180A to the house PRN.
Equineguy is offline
Old 03-27-2008, 09:06 PM   #5 (permalink)
Jerry- I have the same results as Equine guy, accept my tow differs from daily driver in that it shifts at higher RPM, so Im hangin on to the gears a little longer. The good thing is you tell him what you want and he does it, if its not EXACTLY what you want send it back and he'll make it happen.
Dan
Big_Dan97's Photos
Old 03-27-2008, 11:04 PM   #6 (permalink)
DP Tuner- 40,60,80,100, 80econo, 80 econo seems to work well with my GV OD on the freeway. Still playing with it, happey so far though.
Blue_Man is offline
Old 03-28-2008, 02:08 AM   #7 (permalink)
Jcart's Avatar
Hey Jerry,
I too have TW files and as I recall he doesn't rate by HP. Mine are econo which is low hp with no smoke with the mods I have. 2 is a tow program with little smoke and good EGT's 3 is a DD which will smoke lugging or if I get on it. 4. is a race program that hauls great but does smoke a bunch even when I get ontop the Turbo (spooled) and the fuel peddle is quite sensitive to input off the line.....Thinking your best bet would be to give him a shout....do you have an auto or ZF-5? I can look in the shop tomorrow for the actual names of the files if you like.
jrc
96 XLT F350 CC ZF-5 355's 16x8 aluminum rims 285/75R 16 Dick Cepek F-C IIs. T Wildman programs, Map regulator, DIY CCV & HX mod, TDS exhaust brake, BD gauges, downpipe 4" exhaust, custom SS resonator, LUK, SD I/C, Custom Shackle Reversal, Custom Moose Bar and Velvet rides, RS 9000x shocks, Custom Aluminum Drybox/fuel tank, Swamp's Baby Injectors, SD Hpop, DIY Oil by pass filtration, DIY electric fans, DIY E-Fuel system, Lighting by VisionX, LightForce and PIAA and other stuff.
http://community.webshots.com/user/jcart44
Jcart is offline
Old 03-29-2008, 04:41 PM   #8 (permalink)
Soaggydogg's Avatar
My Photos: (11)
Is your truck manual or auto. It takes more driver effort to make a manual not smoke and make an auto smoke.
You could be asking for something that will take Live Tuning or more reburns. By all means ask DP/Jody if he can burn a chip that will do that or what it will take.
'95 F250 Ported Snorkle, Foil Delete and a little more
'02 Excursion Matched Perfect and Staggered Special
Total Diesel Performance Custom Tuning
Rockin S Performance BTS dealer
good-times.webshots.com/photo/2120855500037306169oDlfMF Well did you touch it?
Soaggydogg is offline
Old 03-30-2008, 09:01 AM   #9 (permalink)
My Photos: (22)
Thanks guys for the input. I have the 5 speed and already have a chip from Tony. He has been great to work with. He has reburned my chip a few time so far, but I figured I would see what programs others had...hoping to find a person with the saem setup that had already worked out a program that controlled the smoke well at lower boost levels, etc.
Like I said, Tony is great, I am not knocking his programming. I was just trying to save the hassle of mailing the chip back and forth until I got the program the way I wanted, as I know it is hard to write a program based on info like, "I need a little less smoke in the bottom end" That is very subjective and a "little smoke" to one guy is a blazing forest fire to another.
That's the other reason I am toying with a chip from Jody. I believe he recently tuned a truck similar to mine that was looking for the same type of results, so I may just drop another 400 on another chip.
Jerry
» Sponsor Links
»Garage Storage and Cabinets
