Old 10-19-2008, 12:02 PM   #1 (permalink)
What rims fit ??
Will the rims off my 1990 Dodge 2500 fit my 1997 F250 ??
The Dodge will never see the street again with new tires & my F250 is a working truck.
97 F250 SC LB 4X4 PSD TDE0, E4OD,3.55's, 285/70/16"s ,Modified fuel tank vents, 375+k headed for 500k
Leader is offline
Old 10-19-2008, 12:14 PM   #2 (permalink)
Yes they will 8x6.5 but I don't no if the off set is diff.
95 F350 cc, 4x4, 5sp with a short shift kit, 3.55LS, D66 turbo, Beans stage 1's inj, modded ped, 15/17* HPOP [Thanks Joey] DIY fuel system, IDM mod ,hx mod, DPR intercooler, 3" intakes 3" dp, 4" side out, 2piller w/boost&pyro, steering column mount w/hpop gauge, TW chip, AFE stage 1, ccv mod, DIY oil & coolant filter setups, John Deere coolant eye, ORU RSK, Black Centerline wildcats w/Hankook RT03 315-75-16 mt, RockDog front bumper w/8" Hellas and a CT performance rear bumper/tire carrier, 05 SD front and rear seats.
Trying to find time to install Con O clutch, Ford rear diff cover, Blackbird rear disc brake setup.
I have two Kids and they come first...
http://community.webshots.com/user/TECH5150
TECH51 is offline
Old 10-20-2008, 02:25 AM   #3 (permalink)
u2slow's Avatar
My Photos: (16)
Its the newer Dodge's you have to worry about the wheel offset - somethng that vintage - no.
For '90, Dodge center holes should be large enough for a Ford hub. (Its Chevy wheels that have the smaller hole.)
95 F350 Crew 5spd/4.10, SuperChips tuner, solid flywheel, T444E waterpump, 205° stat, Locked F&R, 9.00R16 Michelin XLs
97 E350 SRW cutaway, E4OD/D70/4.10, 19.5s on the rear, deep trans pan, batteries inside, 1800W inverter, manual glowplugs
84 C30 Suburban, 6.2/4-spd, 3.21s
Other rigs I goof around with regularly:
93 F350 4x4, 7.3 IDI turbo, 5spd, 4.10s
90 F250 4x4, 7.3 IDI, 5spd, 3.55s
, D60 swap, straight pipe, turned up fuel screw
u2slow is offline
Old 10-20-2008, 06:24 AM   #4 (permalink)
Thanks... The center hole was what I was worried about.
Leader is offline
Old 10-21-2008, 09:45 PM   #5 (permalink)
u2slow's Avatar
My Photos: (16)
Better measure just in case... I got burned on a Dodge wheel tonight. Center hole not big enough.
u2slow is offline
Old 10-22-2008, 05:44 PM   #6 (permalink)
Big K's Avatar
Send a message via ICQ to Big K
Yeap, Center Hole and Backspacing is the issue
Big K is offline
Old 10-22-2008, 08:12 PM   #7 (permalink)
u2slow's Avatar
My Photos: (16)
The backspacing is fine until you get into 94+ Dodge... and it changed again (even more positive) in the 98-01+ range.
But the center hole - yeah its a problem. The one I tried was a 16x6 (or 6.5") steelie... it had the Chrysler pentagram stamped into it. But who's to say the Dodge you're getting wheels off of even has Dodge wheels.
u2slow is offline
» Sponsor Links
»Garage Storage and Cabinets
