I bought a 6.0 intercooler and was wondering what piping I should be using? Summit racing has sections of exhaust tubing in all sorts of shapes and sizes. What size OD do I need?
Diesel Tech For Yardmaster INC.. College Degree In Heavy Duty Diesel and Power Generator Systems
1997 F-250 Heavy Duty 4x4 Off Road EX.Cab Short Bed. -4" Suspension Lift - 4" exhaust - 3" Downpipe - 5" Stacks - 10Kmod - Shimmed FPR - Home made air intake - Rosewood Stage 1's - TS 6pos Chip - 4:10 gears - Valair SMF conversion - currently tore apart for restoration
2004 F-350 FX4 - 4" Turbo Back - WORST truck I have ever owned - For sale
Simple observation - do you really want somebody else's guess or dimensions based on what they might have in their truck? Don't get me wrong, it is good to ask questions but you need to work with what you have as there is always a chance of variations that will cause headaches. You are a technician, do you have a Vernier caliper? Measure the OD on all of the inlets and outlets pairing them accordingly. Use those dimensions before ordering.
__________________ . Ford Master Diesel Technician Diesel Technician Society
buy couple of 90 and 45 degree bends and 3 inch pipe order 4, 3 inch 4 inches long hoses and 8 stainless steel clamps. go ford dealer and get the 2 hoses thet connect the intercooler to the 3 inch intercooler pipes
if you need a little twinking for slite bends go to your friendly muffler shop snd get your intercooler pipes bent
also somepeople i know bought from ford the 99 intercooler pipe and used the old hacksaw and it worked perrty good
__________________ 1997 F 350 4X4, idm mod, wide open performance GQSSB turbo, stage 2` s by bean` s, intercooler, 4" no muffler, stack, trans from brians truck shop rear, disk brakes, and a stecher stage 1 hpop 6 position chip with bean` s programs crane valae springs, air dog lift pump and electric fuel pump and regulatorand water methonal injection
for the 6.0 IC you will need a 3.25" to 3" coupler for the pass-side of the IC. the piping is all 3". make the pipe in 2 pcs presides. it makes it easyer to work on the truck when just have to take the top have of the pipe off.
HIS AND HERS PSD!
POWER BY:BDP,BTS,TDP,RSP,CTP
His-97,F250,RC,4X4,#2 12.975 @ 103.34
12.88 @ 104.46 my fastest
12.79@ 105.68 the wife fastest
fuel only
Does anybody have problems with the hoses sliding off of the tubes where they have been cut when the turbo is making boost? Thanks for your help, Eric.
yes, but solved the problem by cleaning with brake cleaner and tightin the clamp as tight as you dare, any oil no matter how slight will cause them to blow off
when i get a chance am going to weld a bead around the pipe about an inch from the end and then i dont think will have that problem again
am making about 38 lbs and no problem
Wow 38 lbs! I just bought a 6.0 intercooler and will be starting on it next month. Thanks to everyone who has posted pics and info on the install. After the intercooler I am palnning on the DIY injectors and guages. Thanks again, Eric.
