Old 11-02-2006, 05:35 AM   #1 (permalink)
What is the valve stem size?
I need to know what the valve stem size for our valves is,so I can buy the locks for my retainers.Thanks [img]/ubbthreads/images/graemlins/smile.gif[/img]
Clifford A.Thomas III
Dyno'd 343 hp and 685 ft.lbs. torque #2 tow setting
http://community.webshots.com/user/cliff1972
1996 F250 4x4 Reg Cab,(3rd)rebuilt engine 9/2007.DYI Stage II 170cc,stock turbo,3" dp,ARP mains,open air filter,DP Tuner F5,4 1/2" s.s. exhaust w/ Borala muffler,Joe servo IDM mod,HX MOD,stock E4OD w/ up graded valve body,TCI convertor,4.10 posi,315/75R16 BFG MT's
Waiting to install:stock 6.0 intercooler and DIY hybrid kit
Wanting to buy:head studs, Comp 910,FASS 150/180 and Modded H2E
1964 Impala 468BBC 6.98 at 98 mph in the 1/8th
1969 Nova 408BBC 6.96 at 96mph in the 1/8th
cliff-1972 is offline
Old 11-02-2006, 10:22 AM   #2 (permalink)
Re: What is the valve stem size?
.312
'99 PSD, CC, DRW,
'97 PSD, Reg Cab, 4R100, intercooler, Superduty turbo, Stage I's
Tinscout is offline
Old 11-02-2006, 07:22 PM   #3 (permalink)
Thanks [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Old 11-02-2006, 08:07 PM   #4 (permalink)
Summit sells two different 10 degree locks # CCA 617-16 and CCA 618-16.One is for lash cap the other is not.Which will I need?They fit a .310 stem I believe this will work also,right?
Old 11-03-2006, 03:42 AM   #5 (permalink)
If your valve stems use lash caps, then buy the locks with the lash caps recesses.
Lash caps look like little metal cups that fit on the top ends of the valve stems....If you select non lash cap locks and then install lash caps, the locks may release when the valve gets tapped open....and that's about the worst thing that you could ever want to happen.
Lash caps are made of harder materials to prevent wear on the stems and are often offered in various thicknesses to provide differing lash clearances where there is no other means to adjust clearance.
Depending on the geometry, you can often use lash cap style locks without lash caps, but not the other way around.
But wait a minute...how did you get in this situation?...did you buy a basket case with disassembled heads, or did you do the tear down?
95 F-350 DRW extended cab Dixie Custom, 180K troublefree miles, straight pipes, no other mods....Yet.
My two dixie Customs pic
My other passion pic
My other hobby..MUSIC!..I have a dance pole, lights and mirrors in that room now!
Yehaw is offline
Old 11-03-2006, 05:02 AM   #6 (permalink)
I am floating the valves is the reason why I am doing this.
Old 11-03-2006, 01:11 PM   #7 (permalink)
Valves float due to either weak springs or reving the engine beyond the design limits of the components in valve train.
When valves float, the power curve hits a brick wall cause you end up with a 'hole' in the engine, and the exhaust valves can burn instantly.(not assuming you don't know this)
Sounds like you might have some tech stuff to share on the forum....I ain't seen anything associated with performance head work/cam and valve train on these engines. All posted so far deals with mostly bolt on intake/exhaust and turbo stuff.
Besides that, I'm kinda nosey...What you got going on?
Yehaw is offline
Old 11-03-2006, 03:27 PM   #8 (permalink)
Are you using a stock retainer, and what spring are you using?
'99 PSD, CC, DRW,
Tinscout is offline
Old 11-03-2006, 04:30 PM   #9 (permalink)
I like nosey [img]/ubbthreads/images/graemlins/biggrin.gif[/img].I dynoed a couple of weeks ago and I and some others feel my valve train might have a little to do with the low hp # amoung otherthings [img]/ubbthreads/images/graemlins/tongue.gif[/img]The engine is capable of more rpms now than when it was stock,so I should have upgraded the valvetrain when I rebuilt it.
Tinscout,I going with Comp Cams 26120-16 beehive springs,795-16 retainers,either 618 or 617-16 locks and I don't know if I need them,4696-16 locators.I need to find out if I really need them though [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Also,who has done a valve spring install while the engine is still in the truck?I got a set heads I could redo and install after their finished.
Old 11-03-2006, 07:10 PM   #10 (permalink)
Who has done a valve spring install while the engine is still in the truck?I got a set heads I could redo and install after their finished.
[/ QUOTE ]I tried it once on a small block Chevy and gave up as soon as I dropped the very first valve I tried it on....But that's just me....All I know is that as soon as the valve get's bumped off it's seat, the air flowing past it tends to suck it down.
I guess a guy could rig up an air hose to a glow plug or injector hole and try it with the piston at TDC on the firing stroke. Just make sure to have it in gear so you don't roll the engine with air pressure and be real careful when you lever down on the retainers to watch that the stems don't drop even the slightest bit....Get you a magnet on a stick ready to suck the locks out as soon as you release them, then ease the leverage off.
Do you think you floated the intake or exhaust valves?
Yehaw is offline
Old 11-03-2006, 08:00 PM   #11 (permalink)
I would imagine both were floating
Old 11-03-2006, 08:01 PM   #12 (permalink)
Banned
i had this problem,floating valves with to much boost,and it always happen after i let off of it after wot.around 40-45 lbs did it for me.would bend a push rod or break a rocker.
i didn't use the set up that you are going to be useing,i went a differnt way.but i will say it would be very tough to do with the motor in the truck.from changing the valves to putting the head back on with out damageing the gaskit.it would a lot easyer for you to just pull the motor and do it on a stand
tubzz is offline
Old 11-03-2006, 08:42 PM   #13 (permalink)
[/ QUOTE ]Not necessarily....there is 'float' and there is 'loft'...Loft is when a valve doesn't follow the downramp of the cam but manages to go shut but not shut long enuff, or not shut IAW designed cam profile....float is when it doesn't go shut at all...Loft can happen on the intakes of a boosted engine before it does it on the exhaust.
I was just wondering if his dyno guys managed to determine exactly what was happening or simply labled it 'float' and suggested he go with stiffer springs.
Yehaw is offline
Old 11-03-2006, 10:57 PM   #14 (permalink)
I've been told by those who run engines at and above the level I am at I should be looking into up grading the valve train.I guess in a way it is cheap insurance in the long run [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Tbuzz,what is the route you went with?
Old 11-04-2006, 09:00 PM   #15 (permalink)
Banned
Tubzz,what is the route you went with?
i went with a dual valve spring assemblie
tubzz is offline
