Old 02-23-2007, 09:36 PM   #1 (permalink)
What are the weak points in the ZF 5 speed.
When I have my engine out I will be going through the tranny as well because it has the low rpm growl. I am wondering if there is anything I can do to beef it up to make it last behind a set of stage ones and a D66.
ShawnMyk is offline
Old 02-24-2007, 08:43 AM   #2 (permalink)
Re: What are the weak points in the ZF 5 speed.
I dont think you'll have a whole lot of problems. Just make sure you update to a single flywheel clutch that will hold more power. If you really wanna go over board you could put in a bigger input shaft, but for what your planning you really dont need it.
Matt
99PowerStroker is offline
Old 02-24-2007, 10:42 AM   #3 (permalink)
MarkEkberg's Avatar
My Photos: (13)
Your low rpm growl is normal. It is called gear rollover.
MarkEkberg is offline
Old 02-24-2007, 02:41 PM   #4 (permalink)
rednck21's Avatar
replace the dmf with a smf and a good clutch kit, fill it with some mobil and it should last awhile [img]/ubbthreads/images/graemlins/grin.gif[/img]
2000 F-250, reg. cab, 4x4, XLT, 7.3, 4R100, built 6/00-forged rods!, DP Tuner F5, AFE stg. 2 w/PG7, MBRP 4", Autometer Ultralight boost/pyro/trans temp gauges, 285 BFG's
2002 Ranger, 3.0 daily driver
73 Bronco Sport - lifted, locked, 331 FI stroker
ECBR
PICS
WEBSHOTS
rednck21 is offline
Old 02-24-2007, 05:48 PM   #5 (permalink)
Patrick Feeley's Avatar
My Photos: (18)
You should be fine with a stock tranny. I think the weak point is the input shaft (which is larger on the 6-speed). There was talk of someone waaay back looking into making a custom, larger, input shaft for the 5-speed, but I'm not sure it ever materialized. Cheers!
1994 F350 CC DRW 2WD PSD (ALF4), ZF 5 Speed, 4.10 LS, SBC Con-O SMFW/Clutch, Baldwin Filter, Tymar HPX Hose, DPPI DP, Bilsteins, $12 AIC, Coolant Filter, Stancor GPR, Explorer Overhead Console, A-Pillar w/ISSPRO Black Ice, EV Boost, and EV Pyro (pre-turbo) , Relocated Block Heater Plug, Modified Pedestal, Gutted EBPV.
Patrick Feeley is offline
Old 02-24-2007, 06:01 PM   #6 (permalink)
My Photos: (13)
IIRC southbend has an upgraded input that is the same size as the 6 speed.
Tim
'97 F350 crew cab 4x4 lwb xlt 5 speed 225hp
'95 F250 reg cab 2wd xl auto 215hp
75f100 is offline
Old 02-24-2007, 06:46 PM   #7 (permalink)
I did not see it on there site.
95 F350 cc, 4x4, 5sp with a short shift kit, 3.55LS, D66 turbo, Beans stage 1's inj, modded ped, 15/17* HPOP [Thanks Joey] DIY fuel system, IDM mod ,hx mod, DPR intercooler, 3" intakes 3" dp, 4" side out, 2piller w/boost&pyro, steering column mount w/hpop gauge, TW chip, AFE stage 1, ccv mod, DIY oil & coolant filter setups, John Deere coolant eye, ORU RSK, Black Centerline wildcats w/Hankook RT03 315-75-16 mt, RockDog front bumper w/8" Hellas and a CT performance rear bumper/tire carrier, 05 SD front and rear seats.
Trying to find time to install Con O clutch, Ford rear diff cover, Blackbird rear disc brake setup.
I have two Kids and they come first...
http://community.webshots.com/user/TECH5150
TECH51 is offline
Old 02-24-2007, 11:59 PM   #8 (permalink)
I need a new input shaft and some other parts, anyone know if this upgraded shaft is for real ?
95 PSD crew cab LWB 5 speed KP D60. Converted to 4wd from 2wd (wow, what a job!). Custom RSK with SD springs. 290k miles and running strong. SMFW conversion, 3" DP, 1.0 A/R exhaust housing on rebuilt turbo.
skeen550 is offline
Old 02-25-2007, 03:00 AM   #9 (permalink)
I know the growl may be normal but I dont like it. It makes the truck sound like a real Junker, especially when the tranny is hot. Sounds like the world is coming to an end from under my truck. I already have a Luk flywheel and clutch kit so I should be all set.
ShawnMyk is offline
Old 02-25-2007, 12:32 PM   #10 (permalink)
Give this guy a call, he's got a heavy input shaft and all kinds of clutchs from stock to dd's and the prices are really good [img]/ubbthreads/images/graemlins/wink.gif[/img]. His names Kenny by the way.
http://www.kennysmachine.com/index.cfm
Matt
Old 02-26-2007, 05:36 PM   #11 (permalink)
Matt
sent an e-mail, will post what he says.
skeen550 is offline
Old 02-27-2007, 02:18 PM   #12 (permalink)
Dieselfever78's Avatar
Send a message via AIM to Dieselfever78
Matt
[img]/ubbthreads/images/graemlins/shocked.gif[/img] [img]/ubbthreads/images/graemlins/phoney.gif[/img] [img]/ubbthreads/images/graemlins/vomit.gif[/img] You could wear out 2 south bends in the time it takes him to get back with you
-Michael
Dieselfever78 is offline
Old 02-27-2007, 06:31 PM   #13 (permalink)
well, so far no reply ... guess I will call.
skeen550 is offline
Old 02-28-2007, 04:11 PM   #14 (permalink)
He is in the process of moving into a new shop so that won't make getting ahold of him any easier
-Michael
» Sponsor Links
»Garage Storage and Cabinets
