Whats the difference between D and E rated BFG AT's in 285's?
Thanks to you guys I've settled on 285's. Now I have to decide to get the D or E rated tires. Both of these are rated for more weight than the 235 E rated tires I have now. Will one tire "air down" better for deep sand driving? I'm thinking the E range may be heavier and get worse milage than the D rated tires overall. What would you suggest? Thanks.
1997 F350 XLT PSD Crew 4x4 5spd 76K miles gold/white, 285/75R/16 BFG's,Alcoas,4:10,Tymar intake
Blue Marlin decal
Re: Whats the difference between D and E rated BFG AT's in 285's?
I was told the difference is in the sidewall, the e's have more plies wich is better for towing a fifth wheel/goose neck. I bought kelly safari's with a e rating , it rides pretty hard but i guess the front add a leaf and the timbren air springs dont help. Hope this helps
Frank
__________________ http://community.webshots.com/user/dieseldutton
2004 Pitbull Motorsports rigid chopper
121 TP 130rwh 250 avon
04 CRF250 mine
02 CR80 sons
03 XR100 daughters
425 Polaris magnum
500 Polaris sportsman and 300 lakota everyones
1998 27.5 Wilderness 5th wheel
I beleive they are all d rated in that size, if not get the E as the side wall has more plys.
1997 F250 FireTruck Red,CC SB,auto( Prescion TC, HD-2Tugger),5" exhaust, custom Swamp 195cc Hybrid injectors, TWildman 4-pos chip,open air cleaner, I/C w Banks intake, 225,000km,AIC,dual electric fans,Sky mfg RSK w/ D60w/ARB locker,Ramsey 15k# winch, BFG/AT 315's, F450 rear springs, home of Craig's Performance Diesel pictures
" lying is a cheap way out of reality, the real cost is the loss of respect and trust"
Since your truck is a '97 4x4, I'm assuming it is single rear wheel. If you tow very much at all, I'd say go for the E's. The extra price is worth the stability. If you don't tow/haul much, go for the D's. The biggest difference is in the sidewall.
Both will 'air down' for sand, but the E's will have a firmer ride for a given air pressure.
I have not seen any proof of worse mileage for E rated tires, but it is "theoretically" possible. Probably less that .01%. Most of that would be due to weight.
But under load the Es would not squat as much, reducing the friction.
Unless you only haul a little bit, the Es are the way to go.
I bought the E's. I figured that it was worth it to spend the little it of extra money on them. They ride well, and I didn't notice much decrease in mileage when I moved up from some 265's.
Kurt
SOLD!!
1997 F350 XL PowerStroke 4WD, ZF-5 w/ South Bend Con OFE Clutch
Regular Cab, Long Bed, SRW, 3L55's, Bilstein shocks, Warn premium hubs
3-inch downpipe/4 inch exhaust w/ Magnaflow muffler and cat
Tymar intake
International Water Pump with integrated filter
Wildman Four-Position Chip; Baby Swamps; D66 turbo with 1.00 housing; SD HPOP
Isspro EV Boost and Pyrometer gauges
285/75R16 E-Rated BFG All Terrain KO's
Rear Disc Brakes from Blackbirds Custom Trucks Pictures of it all...
