Wheel bearing help. - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 09-04-2009, 11:46 AM   #1 (permalink)
drwoodchopper's Avatar
Wheel bearing help.
So on my way to work this morning my front drivers side wheel bearing started squaking at me. I have it all tore apart now. Now the main question is how do you remove and install the new races or whatever the proper name is?
1997 F350 CC4X4 120K superclean truck Beans 6 pos chip! IDM mod(it works!) Pyro, Boost and Trans Autometers over mirror. 4" straight pipe! 285/65X18's Nittos. Ford V-10 trans cooler, Tymar Intake, 6 leaker intercooler. Swamps 175/146 sticks fed by Adrenaline in front of a BTS. WOP QSSB turbo! 1997 F350 XLT 4dr 125K 5" Pipe no muf and no kitty (totaled). 04/04 F350 EX Cab LWB "Leveled" Lariat FX4 Limited slip. BFG's 295/75R16. 4" pipe from back of kitty exiting in front of rear wheel. Autometer Pyro and Boost guages 65K. 422hp and 772tq (SOLD) 96 F250 powerstroke extended cab. Original E40D 132K Wood hauling machine. 10k MOD. Autometer Pyro and Boost gauges. Gutted Cat. Sold.
1966 Mustang "mostly restored" replaced by 2009 Dodge Chalenger! My Youtube vid. http://www.youtube.com/watch?v=fdXy-bV6Zks
drwoodchopper is offline
Old 09-04-2009, 12:25 PM   #2 (permalink)
The autoparts stores probably rent a slide-hammer/bearing puller kit, although when I changed out mine I just used a brass drift punch.
1997 F350 CC DRW E4OD POS. electric fuel, DIY6637, Beans Stage I. 200k and counting.
webshots
RD97 is offline
Old 09-04-2009, 01:02 PM   #3 (permalink)
Supporting Member
skeewee's Avatar
When I didn't have the right tools I used a punch or a big flat blade screwdriver & I tapped them out then when I was ready to install the new races I just tapped them back in. I was very careful not to ding anything. Use alot of high temp grease!! I just replaced the front bearings last weekend on my 96PSD & replaced the 4X4 Hubs as well.
1997 F-250 XLT 7.3PSD 5SPD 4X4. Pyro and Boost Gauges, 3" DP 5" Exhaust, 160cc Stage 1 injectors, Adrenaline HPOP, TS 6pos Chip, 10K ICP Mod, Shimmed FPR, Open Air Filter, I/C w Banks Intake & Compressor Wheel, South Bend Clutch w/SMF, HD Bilsteins. Gotta Love The OBS!
skeewee is offline
Old 09-04-2009, 02:47 PM   #4 (permalink)
brass drift and hammer....pound out the old ones...pound in the new ones....
Ford F250 Short Bed Extended Cab/190K/5 speed/BDP Tranny Savers/Redline MTFin tranny/410 gears/open diff./No cat. conv./4" warped speed exhaust w/5" chrome tip/Gutted EBPV/3.5" downpipe/ Tymar open air intake/95 dana 60 / 6" skyjacker Lift/ Factory Manual hubs/HX hose/Ranch Hand Rear bumper/ Fumoto drain valve/Baldwin bypass/Coolant Bypass/Energy Suspension bushings(red)up front/bilstein 5100 shocks/Valeo clutch/31575R16 Cooper SST mt/K-9 Remote Security System/Mag Tech Diff. Cover/(ALF 6 Factory Program) TS 6 Position flip chip/Diamond Cut Headlights/203* Thermostat/Autometer Gauges/TSM Rear Disc Conversion
agomez is offline
Old 09-04-2009, 02:57 PM   #5 (permalink)
Done.
Old 09-04-2009, 03:39 PM   #6 (permalink)
Hey guys when you re-pack the bearings, say there isn't any grease on the spindle or in the hub, would you recommend smearing a bunch on the spindle and in the hub? If so, how much?
96 F250 PSD ext cab SB, 5 spd 3'' DP with straight piped exhaust, tymar intake. 150k mi. Dana 60, SD v code springs, RSK
psu927 is offline
