I have spent the better part of 4 houts trying to find a place to buy them from.
I would like to get AL center caps, but at this point I am hoping for chrome replacements. I can't find them anywhere on line.
Does someone have any links to stuf like this?
Mark,
I bought a pair of stainless rear covers and Gorilla lug nuts from a place on e-bay. I cant remember the company name, I will have to find it, but they were great to deal with.
Frank
__________________ http://community.webshots.com/user/dieseldutton
2004 Pitbull Motorsports rigid chopper
121 TP 130rwh 250 avon
04 CRF250 mine
02 CR80 sons
03 XR100 daughters
425 Polaris magnum
500 Polaris sportsman and 300 lakota everyones
1998 27.5 Wilderness 5th wheel
I got my stainless centers from a Key Auto parts dealer, formerly Keystone Automotive. I like the McGard chrome lug nuts and locks - lifetime warranty!
1997 F350 7.3 PSD Black Crew Cab XLT 4X45 Speed Manual * 212,000 miles original owner* Banks Power Pack * DP Tuner F5 Chip * Centerforce Dual Friction w/SMF * Baby Swamps Phantom II Pyrometer Fuel and Boost Gauges * Customized Dual 4" Diamond Eye SS Exhaust w/offroad pipe * Dieselsite Turbo Saver * 2001 IDM * Amsoil Bypass Filter * AFE/Tymar * Viair Onboard * Mag-Hytec Diff Cover * Amsoil Everywhere * LT315/70R17/D on M/T Classic Locks * PULSE HPOP and CPR Fuel System* http://community.webshots.com/user/ammayernick
Do you have the factory rims? If you do they are Alcoa rims and Alcoa makes a set of chrome lugs and al covers. I could come up with some part#s if needed.
Pics in my sig.
Dave
__________________ '97 F350 XLT CC, 4x4, SRW, H2E, Modified babys, BTS Trans, Head Studs,,,,,too much to list.
