Old 11-11-2006, 10:15 AM   #1 (permalink)
Where to get non-reman (or quality) front calipers
This will be the third set of lifetime swap front calipers on my truck. Does anyone know where I can find quality calipers where I do not have to worry the guy rebuilding them had a hangover that day?
This is really frustrating having to go through this process yet again. The problem is they are leaking.
Any links, places to look, etc would be appreciated.
Ron
95 PSD CC DRW 4.10 E40D. <font color="green"> Swamped 175/173/A</font>. 2002 HPOP and 02 IPR. PowerPacked (what a pain in the a** to install), Katless (kitty's been scattered, splattered, smothered and fried). BTS Tranny (3/04), B&M Deep dish tranny pan, 2-24K coolers and remote tranny spin on filter. Amsoil everywhere with dual bypass oil filter system. Hypermax 5" exhaust. BMW proof front bumper. Dual Optima Marine batteries. Bean's fuel system upgrade, Joe Servo IDM mod. Detroit Soft Locker installed. 1/4 Ton rear bumper, made out of 1" steel plate [img]/ubbthreads/images/graemlins/smile.gif[/img] Other things done, just for fun... FLHRCI for fun. 26 years Naval service, finally retired and still haven't grown up.
ranaumo is offline
Old 11-12-2006, 06:15 PM   #2 (permalink)
Soaggydogg's Avatar
My Photos: (11)
Re: Where to get non-reman (or quality) front calipers
Call www.appliedrotortechnology.com and www.frozenrotors.com and ask them about quality calipers. They might sell them or recommend someone.
'95 F250 Ported Snorkle, Foil Delete and a little more
'02 Excursion Matched Perfect and Staggered Special
Total Diesel Performance Custom Tuning
Rockin S Performance BTS dealer
good-times.webshots.com/photo/2120855500037306169oDlfMF Well did you touch it?
Soaggydogg is offline
Old 11-12-2006, 08:25 PM   #3 (permalink)
jchipper's Avatar
if you were here on the west coast LesSchwab has em
2000. Stock F-350 210k miles, white, 4x4, extended cab, Long Bed. 285/75/16 BFG All Terrain T/A, Marinco Block Heater Mod, Tymar Intake. And that's all for now, but looking to get Edge Juice with Attitude
SOLD--96, Stock PSD, Service Body, Nothing really special 200,000+ miles
and...
Sold to Dad... Might buy it back someday I love this truck - 93, 7.3 Non Turbo 300,000+ miles replaced E40D at 287k miles, also just a stock truck, Run about 450+ Gallons of straight WMO, now back on diesel
jchipper is offline
Old 11-14-2006, 07:24 PM   #4 (permalink)
gnxtc2's Avatar
You could try here: http://www.1aauto.com/1A/BrakeCalipe.../FSeriesPickup
I did not see a listing for the bolt on calipers. I have a '94 D60 under my truck and they have listing. Maybe if you do an indepth search, they might have one.
Billy T.
gnxtc2@aol.com
'97 Black F250HD,XLT, SC, LB, 4x4, Suncoast E40D, Triple Disk Converter, Dana 60, 3.55LS, built 12/97, US GEAR downpipe, Bilstein 5150s, Front add-a-leaf w/urethane bushings, VDO EGT, Trans Temp, and Boost gauges, Hellwig rear swaybar, Shimmed fuel regulator, 4" Exhaust-Straight piped,FORD AIC, Custom triple A-pillar gauge holder,B&M Supercooler, gutted EBPV, B&M Transpan, ART Cryo slotted rotors, Tony Wildman 4 position chip, Joe Servo IDM, MAP sensor mod, Blackbird rear disc conversion, RSK w/ "V" & "F" code SD springs, 149K
PICTURES OF IT ALL
Fort Lee, NJ
gnxtc2 is offline
Old 11-14-2006, 08:28 PM   #5 (permalink)
dont have a link but how bout Stainless Steel Brakes, the ones that put stainless sleeves in everything?
Diesel Mechanic 28 yrs
Garbage_Mechanic is offline
Old 11-16-2006, 01:21 PM   #6 (permalink)
Darth_Stroker's Avatar
My Photos: (6)
I just saw some 8piston caliper upgrades for our trucks in a magazine I'll look it up later.
Alan
97 F350 CC 4x4
BDP Stage 2's, Dominator 66 turbo, 4pos Wildman Chip, BTS Tranny, ATS .95 Wastegated exhaust housing, Hypermax IC and Pipes, comp 910 valve springs, MBRP DP and 4" exhaust, DIY intake, 17 deg SD hpop, Autmometer sport comp boost,pyro,tranny temp, 35" BFG A/T's, Centerline wheels,3.55 LS, Powerslot rotors,hawk pads, gpr bypass,ac mod,fumoto valve,coolant filter,ELC coolant,JD coolant eye,fpr shim,EBPV gut, IDM Mod
Fightin Texas Aggie Class of '98
Darth_Stroker is offline
Old 11-17-2006, 11:19 PM   #7 (permalink)
My Photos: (6)
www.ssbrakes.com
Old 11-22-2006, 08:02 AM   #8 (permalink)
gnxtc2's Avatar
I dought you will find an aftermarket/performance bolt on/slide pin caliper for our body style trucks. I just see SD stuff out there.
Billy T.
gnxtc2@aol.com
PICTURES OF IT ALL
Fort Lee, NJ
gnxtc2 is offline
Old 11-22-2006, 02:29 PM   #9 (permalink)
ya, www.ssbrakes.com doesn't make products for our trucks, only the newer SD trucks
1997 F250 4x4 extra cab 5 speed manual w/6" Tuff Country lift, 35" tires, Superlift Superrunner Steering System, AFE Stage 2 Intake, 4" exhaust w/downpipe no cat or muffler, EGT and boost gauges, 1.0 turbo housing from Dale, 60hp DP Tuner chip!
Brandonizr is offline
Old 11-22-2006, 08:56 PM   #10 (permalink)
My Photos: (6)
I read the ad wrong. sorry.
» Sponsor Links
»Garage Storage and Cabinets
