Old 11-16-2006, 09:59 PM   #1 (permalink)
Where is the power at?
I am fed up with my truck. I have a 97 f-250 4 door 4x4 with a 4" lift and 125,000 miles. I have put in the down pipe, exhaust, air intake, and a 6 position chip. I have a 32' 5th wheel trailer that weighs about 10,000 pounds full, and I can't pull it past 50mph on a flat surface. As soon as I hit a little incline it starts slowing from there. I have friends with f-150's pulling 25' trailers that have no problem running 55mph up hills. I run my chip at the third setting which is the first hp bump setting and I get almost 20lbs of boost max. Before I did the mods I was only getting 10lbs of boost. My motor is louder than most and I don't know if that makes any difference? Does anyone have any suggestions or is this all normal? Any help would be great. Thanks, Dan
mtrsportdan is offline
Old 11-16-2006, 10:03 PM   #2 (permalink)
Re: Where is the power at?
thats alot of weight and your lift prob doesnt help anything either. What gearing do you have? Sounds like its time for a set of small injectors and an intercooler.
95 f350 Redneck war wagon- lots o goodies
kellycoon is offline
Old 11-16-2006, 10:11 PM   #3 (permalink)
It has 4:10's
Old 11-16-2006, 10:35 PM   #4 (permalink)
Soaggydogg's Avatar
My Photos: (11)
That isn't that much weight and the lift means nothing but the tire size could. How high is that Fiver, like a parchute and 6ft above cab or a lower profile? I hauled weight before and didn't have issues with slight mods.
Out...
Ben
'95 F250 Ported Snorkle, Foil Delete and a little more
'02 Excursion Matched Perfect and Staggered Special
Total Diesel Performance Custom Tuning
Rockin S Performance BTS dealer
good-times.webshots.com/photo/2120855500037306169oDlfMF Well did you touch it?
Soaggydogg is offline
Old 11-16-2006, 11:21 PM   #5 (permalink)
There is something wrong somewhere. What size are your tires? I have a 95 and pull a 11k+ pull trailer and can do much better than that. I just switched from 285s to 265s and the difference is night and day on the hills.
95 CCLB 4X4, DP, TYMAR, 5POS CHIP, 4",3 GUAGE POD, 115k, 265/75/16 bfg E, E4OD,4.10s,Putnams hitches front and rear,Air bags rear.
realbadlarry is offline
Old 11-17-2006, 12:57 AM   #6 (permalink)
I would say it is a high profile trailer that sticks up about 5ft. over the truck and my tires are 315's. Before I put on the lift and the tires is still seemed kinda gutless. The mods helped, mainly the chip but the exhaust and intake didn't do much. It's an auto also. Thanks, Dan
Old 11-17-2006, 01:16 AM   #7 (permalink)
AlaskaRedneK's Avatar
Im no expert, but w/ my stock injectors and a chip I could get 25psi.... Weak Fuel Pump??? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Best of Luck, hope you get this taken care of,
-Stouff
'97 F-350 CC/LB 7.3L PSD 4x4 4.10's, ~111K miles/ 5" Turnout Stacks, Isspro EV Guages, 7.3 IC, gutted stock fan- w/ single electric fan, Stage 3 DIY Hybrids, Bad Boy RacerX Tranny built by me, headstuds, 910s, pushrods, 17* pump, 3" intakes, H2E, Tunes from Tony
AlaskaRedneK is offline
Old 11-17-2006, 09:07 AM   #8 (permalink)
you have a problem!!!! I pull 11k 5ft above the cab and run 80+ on 33" tires the hills will slow me down but only to 50 or so and that is in mt so there are some big hills. hope that helps
tow rig
95 f-350 cc. 5spd. Rsk. 33x12.50 procomps. diy intake. 7.3 I/C. gutted ebv 3.5"down pipe.diy 5" exhust bdp stage 1 injectors comp cam 910 vavlesprings d66 turbo with ped mod and wildman chip
towed rig:
77 IH scout travler. 40" tsl's 500hp 454 203/205 dana 60/14 bolt
IHjunky is offline
Old 11-17-2006, 09:43 AM   #9 (permalink)
I am I real frustrated. I have so much money in this truck to get it where I thought it needed to be and it isn't there. I am wondering about my turbo and injectors. It just takes forever for the turbo to spool up and hit 20psi of boost, and like I said the motor is real loud and someone told me that's the injectors. I love my truck but I am getting real close to selling.
Old 11-17-2006, 10:00 AM   #10 (permalink)
My Photos: (5)
have you done a buzz test and / or cylinder contribution test?
you should before making any drastic decisions....
if you have good oil pressure and good fuel pressure, your ebpv is not stuck partially closed, and your transmission / torque converter are in good condition (if your converter is worn out you could be loosing a lot of power there)
I would seriuosly suspect your injectors.
Belleville, MI (Detroit / Ann Arbor)
'97 F250 4x4 7.3PSD ZF5spd 4L10
PA2818 diy intake, wicked wheel diy turbo rebuild, .84 turbo housing, no muffler, I LOVE MY BEANS TS'ers! ;-), new pedal box bushings, Fleetgaurd coolant filter, Seat Mod, electric fan, Eagle 16x8 w/265 75 Firestone Steeltex AT, cooling pkg front bumper
'69 Mustang 428CJ(ongoing project)
'99 escort zx2 commuter
'86 Supra classic ski boat 351W PCM power
'54 Belair sedan, all original
milner351 is offline
Old 11-17-2006, 10:01 AM   #11 (permalink)
First of all, what chip are you running? What hp increase is the 3rd setting? Have you tried towing in the 4th setting?
Check your uppipes for leaks, and exhaust manifolds. If you have preturbo exhaust leaks it will murder boost.
It does sound like there is something that aint quite according to Hoyle, as you should be making more power.
You need to get a fuel guage on it and see what your psi is when your towing, not just at idle.
When was the last time you changed fuel filter? Cleaned the regulator screen?
Unplug the Map sensor and take it out for a run and see what kind of boost you make then.
Also have you gutted the ebpv? If its partially closed it will kill performance as well.
Pull the intake and check your turbo out, see how much play is in the shaft and what kind of condition the fins on the wheel are in.
99.5 F-350 C/C Dually, Stealth HPOP, Full Force Diesel stroked A code injectors, Holset turbo, AEM intake.
Vengeance is offline
Old 11-17-2006, 02:57 PM   #12 (permalink)
Nit
I have the same truck, but with custom injectors, towing is no issue what so ever, your air flow is messed up, check teh above list.
1997 F250 FireTruck Red,CC SB,auto( Prescion TC, HD-2Tugger),5" exhaust, custom Swamp 195cc Hybrid injectors, TWildman 4-pos chip,open air cleaner, I/C w Banks intake, 225,000km,AIC,dual electric fans,Sky mfg RSK w/ D60w/ARB locker,Ramsey 15k# winch, BFG/AT 315's, F450 rear springs, home of Craig's Performance Diesel
pictures
" lying is a cheap way out of reality, the real cost is the loss of respect and trust"
dirty30
Nit is offline
Old 11-17-2006, 10:50 PM   #13 (permalink)
My fuel filter has 5k miles on it. I haven't done the screen thing that you are talking about. Is there any good directions on how to do that? How is boost supposed to look on the gauge? Mine doesn't come up unless I got my foot in it. I can drive around normal and not get on it and maybe hit 4lbs. And when I do have my foot in it it gradually goes up as I get into the 2200rpm range. Is that normal? I really appreciate all the help you guys are giving. Thanks, Dan
Old 11-17-2006, 10:56 PM   #14 (permalink)
I forgot my my chip is the t5 6position chip 3rd setting is 50hp, 4th is 75, 5th is 100, and 6th is 140hp. I tried towing in 75hp mode and it didn't seem to make a difference.
Old 11-17-2006, 10:59 PM   #15 (permalink)
Again I forgot the ebpv valve is still there. Where is the map sensor?
» Sponsor Links
