it has been so long since i did one, does anyone remember what size bolts to buy. would like to stop and pick em up in the morning and do it at the shop.
Thanks for the help
Travis
SWAMP'S Extreme Powerstroke Performance
2L Motorsports
Charter Member of www.FOKISD.ORG
99 F350 ext dually 2crueL (moded somewhat)
86 F250 4x4 - C6 3.55Ls[b]
The Mule 1995 F350 CC - 4x4
95 E350 PSD 190k miles
97 F250 ext lb 160k 4x4
97 FSuperduty Plumbers Truck
93 Ranger (soon to have twinned 4bt) My Webshots
97 crew cab short box f250 power stroke 4x4 automatic. 4.10s a stock other an 209500 miles first tank 18mpg, 4in exaust with no kitty or muffler now.
1983 F-350 Crew cab 4x4 4.10 5 speed 90 cummins 12v, turned up pump, centerforce clutch, stright piped,97 alcoa ford wheels, with custom built flatbed 265 85 16s
sold!!!! 96 crew cab short box f250 power stroke 4x4 automatic. 4.10s one wheel wonder 180000 miles, old chip no epv 3in down pipe, 5" STACK custom air cleaner (like tymar) custom bumper 285 85 16's
to keep it from sagging in. Sometimes, when the truck gets in a bind, the front tires rub the bumper and pull it down some. Shimming the bumper pushes it away from the tires.
Craig
__________________ 2000 Ford F250 Lariat 4x4 Auto SuperCab LB PSD
2L Motorsports transmission (Precision 3 disk converter, valve body, upgraded clutches), V10 tranny cooler, TS chip, MBRP 4" exhaust, 4" to 5" tip, Auto Meter Z Series Boost, Pyro and Tranny, Poor Man's DIY intake, Boost Relief Valve, Crank Case Vent routed under truck, AIH plug
i beleive they are 5/8 in diameter, buy 2 inch full thread grade 8 bolts. Don't hold me to this but i am trying to remember. Still interested in those flares travis?
1997 F350 CC 4x4 5spd- 4.10, XLT, custom intake, custom 4 inch exhaust, 4 inch lift, cerametallic clutch, Ramsey hydraulic winch, PTO, swamp babies, 6 pos. TS chip, hideaway strobes etc..all the goodies
1995 F350 Wrecker, 4wd, Vulcan 882
I just put my bumper on using brackets I bought off Ebay.
They were NOT 5/8", that's HUGE, did you mean you used a 5/8" wrench?
I think the bolts I used were 3/8" coarse thread.
My bumper was in the bed of the truck when I bought it, I had to hammer, rubout, weld, and make it work to fit to the brackets (cut off with a torch for a winch bumper that was then removed by the P/O)
SO, I've never seen the stock bumper bolts.... but I know the 3/8 fit the holes.
I would say 2" length would work fine, no problem if they are too long!
Belleville, MI (Detroit / Ann Arbor)
'97 F250 4x4 7.3PSD ZF5spd 4L10
PA2818 diy intake, wicked wheel diy turbo rebuild, .84 turbo housing, no muffler, I LOVE MY BEANS TS'ers! ;-), new pedal box bushings, Fleetgaurd coolant filter, Seat Mod, electric fan, Eagle 16x8 w/265 75 Firestone Steeltex AT, cooling pkg front bumper
'69 Mustang 428CJ(ongoing project)
'99 escort zx2 commuter
'86 Supra classic ski boat 351W PCM power
'54 Belair sedan, all original
I just put 4 big fender washers under the mount to frame part. using stock bolts. got it alot closer. then dave (golfer) took off in it. So hopefully that will fix the problem. Thanks Travis
2L Motorsports
