Who has a teachers heart? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 11-21-2009, 09:25 AM   #1 (permalink)
Post Who has a teachers heart?
I was wondering if some of you out there would like to comment on the basics of Power inhancement of the 7.3. I have been reading some of the threads but to be honest It is like talking to my youngest son about today's computer technolgies. How about a diffinition of terms, and a basic 1,2,3, approach to power inhancement. You know start with and then maybe etc, maybe a few dos and don'ts Be gentle boys it is my first time. Before I waste money and time I tend to trust more what is being said here than anywhere else. Thanks in advance Lipe1
lipe1 is offline
Old 11-21-2009, 09:41 AM   #2 (permalink)
well welcome to the site. yes these forums generally have alot of great info. most of the peeps here have been there done it at least once, so they can give you experienced direction. Saying that we need to know a little more information about your rig. what year of 7.3 are you talking about and how much power are you looking for and how much money are you wanting to spend. First off i would like to say buy gauges (boost, pyrometer, tranny) so that you get feedback as how the truck is running. again welcome to the site.
ALSO BE WARNED WHEN YOU START DOWN THIS PATH OF MODS ITS HARD TO STOP.........MORE POWER=MORE MONEY.....
Somedays its just not worth chewing through the restraints
2011 F350 CC lariat ultimate dually with nav, line x, more mods comming
Y2K 4x4 250 PSD Xcab, auto, way too many mods to list Broken March 2011, written off due to collision
Crazy_Canuck is offline
Old 11-21-2009, 02:11 PM   #3 (permalink)
DaveBey's Avatar
My Photos: (203)
lipe1 -- Howdy and Welcome to TheDieselStop!
Only two things are required for power enhancement on the 7.3L Power Stroke: more fuel and more air. But, as they say, the devil's in the details. HOW you go about adding fuel and air, and the support modifications required, ultimately determine the level of power enhancement. Of course, how much money you're willing to spend also is a factor.
A good power enhancement plan should start with gauges to give you a baseline on the vitals of your powertrain and also help guide you through additional upgrades. The pyrometer measures exhasut gas temperature and should be mounted pre-turbo (generally in the driver side exhaust manifold) to measure exhaust gas temperature. Anything more than 1300° for extended periods of time is bad. The boost gauge measures, well, boost pressure. About 25-35 psi of boost is about all the stock turbo can handle. Boost pressures higher than about 40 cause the head gaskets to pop. As you approach higher levels of exhasut gas temperature and boost pressure, it's time to upgrade! Finally, if you have an automatic transmission, a transmission temperature gauge to monitor the transmission fluid temperature. Heat kills a transmission and as temperatures get higher, additional cooling is required.
The next step involves getting more air in, and out, of the engine. It's time to upgrade the intake and the exhaust! An open element filter replaces the stock air filter assembly with an big paper filter allowing more, clean air into the engine. Replacing the exhaust from the turbocharger back eliminates the extremely restrictive factory downpipe. Modificaiton of the passengerside firewall is required to fit a downpipe. A 3" diameter downpipe and a 4" diameter exhaust are the "standard" exhaust upgrades. Replacing the exhaust will also require replacement of the muffler and most exhaust kits include a new muffler.
A high-pressure oil crossover hose ties the high pressure oil rails in the cylinder heads together to eliminate 'pulsing' and helps provide a more even flow of high pressure oil between the cylinder heads.
Now it's time for more fuel. That calls for a chip or programmer. There are any number of companies selling chips and programmers. My recommendation is a reprogrammable adjustable chip. For example, I have a 4-position chip with tow, economy, daily driver power, and more power settings. If I make any additional modifications to the engine, the chip can be reprogrammed to accomodate those modifications. The majority of the programmers are a one-size-fits-all type of product and would be good for a relatively stock truck.
Now you're at an impass. You've done all the standard "cheap" modifications. The wife or significant other is probably upset with you spending so much time with your truck. It's time to replenish the piggy bank for some more modifications. And maybe buy some new curtains or a sofa to keep the wife/significant other happy.
Seriously though, virtually any other modifications are relatively expensive compared to what you've done so far. At this point there are two paths: more power or more supporting modifications. If your transmisison is still okay, now would be a good time for some larger injectors. If not, it's time for some transmission upgrades.
If you have a manual transmission, a new single-mass flywheel is probably in order. If you have an automatic transmission, it's probably time to rebuild the transmission. You can drive the truck until the transmission starts to fail or flat-out fails or you can be pro-active. It's your choice. And your pocketbook! I recommend Brian's Truck Shop in Lead Hill, Arkansas rebuild your E4OD. A transmission rebuild should include a new torque converter, additional clutch packs, and better fluid flow through the transmission. If you get to the point where a new transmission is in order, it's time for a new thread! Transmissions are a topic unto themselves...
Fuel injectors. They're typically the next stop for more power. Generally speaking there are three stages of fuel injectors (four if you cound stock fuel injectors). Stage I enlarges the fuel injection holes in the injector nozzles. Stage II enlarges the fuel injection holes even more. Stage III are generally a 'hybrid' style injector combining parts from injectors in other International engines to provide more fuel to the combustion chamber. A safe approach is to start with Stage I injectors and then upgrade those injectors to later stages as you modify further. Stage II injectors require more, cooler air (different turbocharger and an intercooler) and Stage III injectors require more, cooler air and internal engine modifications. Adding any style injectors require reprogramming of your chip to account for the additional fuel or the different style of injector.
Now would be a good time to modify or replace the turbocharger. The standard in replacement turbochargers is the Hypermax H2E. Just about every other replacement turbocharger is measured against it in, for instance, air flow. Replacing the stock Garrett turbocharger with a larger turbocharger allows you to flow more air to go with the more fuel you added with your injectors.
Before you add the larger turbocharger, or after; your gauges will tell you; would be the time for an intercooler. The intercooler cools the air on the intake side of the turbocharger which in turns leads to cooler exhast gas temperatures. Cool air is also denser than warm. Denser air = more air for the engine.
Now would be a good time to upgrade the fuel system. The '94-'97 7.3L Power Strokes have a mechanical fuel pump which is replaced with an electric fuel pump (or pumps). The also involves removing the fuel filter/water separator assembly on top of the engine and replacing with pre- and post-fuel pump filters. This also involves running new fuel lines from the fuel pump to the cylinder head. There are a myriad of kits and ways to go about upgrading the fuel system.
If you started with Stage I injectors, you have have the modifications to support Stage II injectors. And guess what? It's time to re-program your chip!
Think of the high-pressure oil pump on the 7.3L Power Stroke like an injection pump on the older 7.3L Indirect Injection engines or the 5.9L Cummins. The high-pressure oil pump is NOT an injection pump but it helps to think of it like one when in comes to modifications. Each fuel injector on the 7.3L Power Stroke has it's own injection pump. That's why the 7.3L Power Stroke fuel injector is physically larger than that of, say, a 5.9L Cummins. Upgrading the high-pressure oil pump can be as simple as replacing it with one from a 2000+ 7.3L or upgrading to a dual-pump setup. Upgrading to a dual pump setup usually requires the fuel filter/water separator assembly be removed. Oh, and you'll probably want to re-program your chip.
By now you've got almost all the supporting modifications for Stage III injectors. One last things remains: head studs/head gaskets. There are multiple strengths of head studs and multiple thickness/syles of head gaskets available. At this point, what's recommended depends on the specific modifications you've done or plan to do. Now you're ready for those Stage III injectors.
3" intake manifolds can be done when you upgrade your turbocharger or add an intercooler. At this point you've done just about everything you can do externally. A girdle can strenghen the lower end of the engine if you plan to get extreme with your modifications. You can also install multiple turbochargers or replace the exhaust manifolds with exhaust headers.
Once you decide on a particular modification, call vendors and ask them questions about their products. Go with a vendor with which you're comfortable and you trust. Make sure they answer your questions honestly and are straight-forward with you. TheDieselStop.com is a great resource and there's a wealth of information in the forums and archives.
Cheers from Claremore, OK!
Dave
1996 F-350 XLT CC SRW 4x4 BTS-E4OD●4L10●Tyrant Diesel chip●Hypermax H2E, intercooler, exhaust●TE-T500●7.3L Regulated Return Fuel System●215 amp generator●International water pump●Hydro-Boost●6.0L Fan●APCM 245,000 happy miles
DZLJIM 3:16
~~NTxPSA - Hold my beer and watch this.~~
DaveBey is offline
Old 11-21-2009, 10:55 PM   #4 (permalink)
Davebey, Now that is what I'm talking about! Your post was concise, clear, informative, and professionally written. Either your do this for a living our your hobby has become an all consuming passion. My little project (which is parked most days) consist of taking my 97 F250 XLT extended cab with a short bed, which I have had for 7 yrs, and providing enough modifications to get to the point of impass as noted in your reply, she has only about 140k on her and she sits proud on her 4" lift and 33's, a cowl induction hood, she stiil turnin heads with her bluish ghost flames laid over black. My northern climate has her showing her age in few places but Ill get her turned around, and with your outline I think I'll have her feeling like a totally new woman as well. Thanks for taking the time! Lipe1
lipe1 is offline
