Who is it that sells the upgraded wiring kit for higher watt headlight bulbs?
I believe this has been brought up in the past, but as usual the "search" feature has always been a problem for me to get results.
I believe GOS Racing sold them, but after leaving them an e-mail some time ago, with no response, I thought I would try to see if you folks may remember who it is that sells these, and what they might cost?
Links would be helpful if you have them. I believe the higher watt bulbs can then be used once this kit is installed.
'99.5PrairieTan/XLT/4x4/CC/SWB/7.3 <u>PARTS FROM DI:</u>6 pos Chip, MM inj., Custom DIIC, AFE2, Fass 150/180, Garrett GTP38r, Full fuel system w/ Billet sump and reg. return, HX mod, Built tranny w/ PI TQ. Conv., 4 pod w/ Autometers, Centric slotted rotors/pads
Re: Who is it that sells the upgraded wiring kit for higher watt headlight bulbs?
Just a thought if you wire up two relay's per light and DIY it only costs a few bucks, I looked into those harnesses and they wanted for an APC one like $60.
94redbeauty,
That's true you can do the harness cheaper..but...the APC harness also comes with a pair of heavy duty sockets that can take the higher heat and wattage of after market bulbs or bulbs that run both elements as in a bright box setup. That was the reason I went with the APC. If you could get the heavy duty headlight sockets cheap too then you would definitely have a winner.
Rick:Red 97 F350 CC DRW 4.10/LS E4OD, 28,000GVW trans cooler w/170F thermostat, remote ATF filter, Mobil 1 ATF, Sonnax valve & Tricum springs, Tymar Hi Performance Open Air Intake System W/Donaldson B085011 filter, IH water pump w/integrated coolant filter, BD downpipe & BD 4" cat back exhaust, "SWAMPED", Tymar HX mod, Tymar/Bill's 4 posn. "flip-chip" (this bad boy rocks), Isspro EV gages in 3 hole PITA Pod, "Harpooned" Fuel tanks, Bilstein shocks, Gutted EBPV, Alpine CDA-9825 head unit, Pioneer TS-A1671R 6 1/2" 220W Front, Pioneer TS-A6880R 6"X8" 240W rear, FOKISD member, Beavercreek, Ohio (near Dayton)
94redbeauty,
Yeah, your right on the sockets, would be nice to get ahold of a heavy duty set for cheap, I havent had any problems with the sockets yet w/ the DIY relay system, though I am sure in the future there will probily be a problem of burning them out.
Does the APC harness leave the low beams on with the highs and supply more voltage to lights or just more voltage to lights?
Chris
97 F-350 cc srw 4x4,White,cab hi Leer,E4OD,4.10's,Hypermax H2E,Banks intercooler,BDP stage 1 injectors and fuel system,BTS tranny,BTS twin hpop,4 postion chip programmed by Cale,Skyjacker 4" system,35" BFG's W/Welds,Rear air bags,Hayden 26,000 trans cooler,4" exhaust,Tymar intake&hx mod,Amsoil dual bypass filter w/Amsoil syn. oil, and diff. lube, Ford aic, Joe Servo idm.
353 HP 677 TQ on BTS's dyno at 0 correction
Chris,
The APC harness will "allow" a higher voltage because there is less/no voltage drop due to resistance. The wire size is bigger and direct from the battery. No the APC harness does not cause both filaments to come on on high beam, you have to use a diode ($.75) to do that, and it works great. If you follow the link I supplied earlier and read Big K's posts and look at the pictures in his sig. you will see how it is done.
Here is a quote from the one to read [ QUOTE ]
This is the setup I am running and been running for a while.
Diamond Headlight Buckets, (Over a Year and a Half)
APC 9007 Headlight Harness, Part #509106, (About 2 months Now)
and APC 80/100 Xenon Super White, (About a Month Now)
A few more pics here also
Also, I have a Diode on the unused stock headlight bulbs connector from the high to the low, So when the Highs come on the Lows Stay on!
I have probably been thru about 10 or so Set of Headlight bulbs before I found some I have liked. Ya name it, I have tired it, (expect expensive PIAA's )
Dale,
I did get your e-mail and I did respond. I just checked my 'sent' list and did go, oh well sorry about that.
We just started building our own upgraded harness for trucks using the 9007 bulbs. These use a hight temp plastic for the connectors and have a replaceable fusible link for protection.
These are now complete and will start shipping tomorrow, let us know if we can help. JS.
Rick,
When you install the diode do you put it in each of the old sockets or just one of the old sockets? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Thanks,
Chris
Chris,
You will have one un-used old (stock)socket, put it there. I put the relays and the connection to the battery on the passenger side, so that left the driver's side socket un-used and where I put the diode. Here is a picture from Big K diode install , and here is his excellent write-up Big K article
What's the difference between the APC (p/n 034-509106, @ Jegs for $40 w/ shipping), and yours (@ $52 w/ shipping)?
I don't mind paying a little more as long as I get more for that money.
'97 F350 CC, XLT, 4WD off road, 4.10, Milemarker manual hubs, Suncoast E40D w/ Bob Riley's (Dieselsite) remote filter & Triple Lock Torque Converter, Hypermax H2, BABY SWAMP'S! Swamp's 20* HPOP, Head Studs, TS 4 position chip w/ Bill's programming, Banks Intercooler. Ceramic coated up-pipes and down pipe. Triple pillar w/ Isspro boost, trans temp and digital EGT gauges. 4" Exhaust. 45gal Transfer flow rear tank. Dale Isley's HX mod. Joe Servo's IDM mod. Bob Riley's coolant filter, Coolant "T", Evans Coolant, A/C mod. Velvet-Ride's, Monroe Gas Magnum Shocks. TSM's rear disc brake kit. Frozen/ Slotted front rotors with Hawk Pads. Centramatic Wheel Balancers & 285/75/16 Michelin LTX/MS. Interior sound deadening (what a difference!).
