Old 11-02-2007, 09:13 PM   #1 (permalink)
sheepman's Avatar
My Photos: (6)
A whole lota whistle
Has any one else got'n a lot of whistle from a turbo with a 1.00 turbine and wicked wheel?
When I rebuilt the turbo I added a 1.00 turbine housing and a wicked wheel. Diamond eye DP and the pipe I can't say the name of. I Kept the stock Muff and tail pipe.
sheepman is offline
Old 11-02-2007, 09:43 PM   #2 (permalink)
My Photos: (22)
Re: A whole lota whistle
Why did you go with the wicked wheel? The stock 94-97 compressor wheel is already the "wicked wheel" Just curious. Glad to hear the whistle increased....I've got a 1.0 housing sitting on my work bench right now.
Jerry
1997 F-350 XL Crewcab 4x4 SRW PSD a.k.a MEAN GREEN. DP-Tuner Chip, DIY Stage 1 injectors, D66 Turbo with 1.0 housing, K&N FIPKwith Amsoil element, 4" exhaust to 5" stacks, Banks intercooler, CCV modded to RDT, 4" Superlift with 35" BFG AT's.
1993 F-350 XLT Crewcab 4x4 SRW 7.3IDI non-turbo Project Truck
Jerry Miller is offline
Old 11-03-2007, 12:39 AM   #3 (permalink)
sheepman's Avatar
My Photos: (6)
I did a complete rebuild and replaced the comp. wheel with it, when I called to order parts. I had replace the bearing housing too.
sheepman is offline
Old 11-03-2007, 12:46 AM   #4 (permalink)
I added an ATS .95 housing to my 96. With the 5" straight pipe it actually kinda made me say uncle as far as the whistle goes. Whew. Just towed 1,000 miles or so and couln't hear it with the windows up though. But next to a wall at low rpm...wow. And at about 2300 rpm or so under hard accel the rumble and the whistle come together for something almost as exciting as sex. The wife blew by me in it the other day and I dont know which was more exciting, a girl in a hot rod powerstroke or the sound of the exhaust.
Diesel Mechanic 28 yrs
Garbage_Mechanic is offline
Old 11-04-2007, 03:33 AM   #5 (permalink)
Did you check the clearance around the downpipe? If it touches the firewall then there is a lot of direct conduction of turbo noise to the cab.
Dave Murakami 97 F-250 XLT Supercab PSD OffRoad, Bilsteins, Warn manuals, Rhinoliner, Bridgestone 285's, molded steps, smittybilt grille guard w/frame braces, Cibie driving lights, power rear window, Sony CD changer w/infinitys+basslink subwoofer, Tekonsha Prodigy, Snugtop, Reunel stainless steel rear bumper w/Warn HS9500 winch/PIAA backup lights, TFI, 7500lbs, 14.508 1/4, 408 rwhp/#2only, banks powerpack, gutted ebpv, 4" duals, map pressure regulator, JSidm, BTS, maddog stage II ABs, Bean's fuel system, Terminator, dieselpower tri-chip, tymared, black intake, non-fluttering Isspro EVs, almost stock!
masami is offline
Old 11-04-2007, 05:16 AM   #6 (permalink)
just wondering if anyone with the dom66 has more whistle? i think it would with the smaller a/r of the turbine, but im not really sure what exactly makes that beautiful beautiful noise. im thinking about that turbo along with stage II's. just love to hear that turbo whine [img]/forums/images/%%GRAEMLIN_URL%%/smile.gif[/img]
....sorry to post a lil off topic.
96 F250 4x4. trans, boost and pyro gauges.manual locking warn hubs. dp tuner (stock 40hp, 80hp,120hp.)banks transcommand. shimmed FPR.tymar intake. CCV Delete. exhaust- 3" dp to 4" straight pipe, 6" miter cut stack 36" tip 315/75/R16 BF mud terrain's with 16"American Racing Baja's.
Michael_Bower is offline
Old 11-08-2007, 03:10 PM   #7 (permalink)
sheepman's Avatar
My Photos: (6)
I made lots of room for the down pipe. I used a 10 ton porta power with the duck bill and pressed it out as far as it would go. Made Lots of room.
sheepman is offline
Old 11-13-2007, 06:41 PM   #8 (permalink)
brencoracing09's Avatar
Send a message via AIM to brencoracing09
by going with a smaller housing would you be loosing power overall though....how does that effect it and at what kinda rpms would you say your stock turbo spooled compared to the new housing? Also is there anything else that you did to the turbo or did you just do the housing?
95 psd,cc,dually,long box,288k,xlt,diy open element intake,unplugged fuel bowl heater....darn that fuse 22
brencoracing09 is offline
Old 11-13-2007, 10:13 PM   #9 (permalink)
Fordpowrstroke73's Avatar
My Photos: (6)
Send a message via AIM to Fordpowrstroke73
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Mad_Stacker</div><div class="ubbcode-body">Why did you go with the wicked wheel? The stock 94-97 compressor wheel is already the "wicked wheel" Just curious. Glad to hear the whistle increased....I've got a 1.0 housing sitting on my work bench right now.
Jerry </div></div>
When my first turbo went out, I found out that it didn't have the stock wheel. It looked like the wheel off of a stock SD.
'95 Ford F-350, CC,4x4, 7.3 Powerstroke,RDS Stage 1's,Tony Wildman 6 position chip,3.55LS,modded IDM(Thanks Dan),3" downpipe-5" mitre cuts,ebpv gutted, 6" tip,Napa 6637 air filter,Autometer ultra lite triple pillar gauges,Dana 60,Rancho RS 5000 schocks,E40D junk trans,,Aluminum tool box with 7 LED's, headache rack,bed protectors,Hayden Trans. Cooler,Custom Homemade SD Stainless Steel Nerf Bars,285/75/16 BFG All Terrains on Factory Alcoa's,'02 SD Intercooler with homemade IC pipes,Gooseneck hitch
Fordpowrstroke73 is offline
» Sponsor Links
»Garage Storage and Cabinets
