Re: Who's the guy with the OBS converted to dually?
Wondering if you changed the rear axle and springs to the dually setup or did you just use the adaptors? How about the rear fenders? Did you change anything up front? I ran across a post just a few weeks ago, and one guy had a black OBS truck that he converted. I believe it was a short bed which looked great! Mine is also a short bed.
I'm looking to pick up some "legitimate" towing capacity for a 5th wheel. Motor has plenty of power, just don't want to overload the axles.
Main thing.... just looking for some insight into the conversion. I really don't want a new body style truck.
Thanks in advance!
97' F250 4x4 crew cab. 4:10 gears,High Idle mod, Dana 60 conversion using 3"SKY RSK w/03' SD springs and 3 3/4" rear blocks to level. Tymar, Issopro gauges on 3 gauge pod, 3" down pipe, shimmed FPR and DP tuner 6 pos. chip (12-13-07). http://community.webshots.com/user/amberjax
Brian,
You are the one I was looking for, but I thought that you changed yours to a dually, not the other way. By the way, is the rear end in your truck, the dually rear end?
I just used the adapters, as I have a dedicated tow rig for the heavy haul stuff.
I was not looking for more carrying capacity, but I think the springs would do fine if you were to add a multi-leaf overload in place of the single-leaf factory overload. There is a member on here who has all the info on GVW/GCVW--I think named "Smokey Wren".
I looked for over a year for a dually rear end, with no luck, so I went with the Arrowcraft adapters.
As far as the bed goes,I located a bed from a 97 4X2 dually and bolted it on.
The front axle was easy as I simply changed the bearing hubs,the rotors interchange between 4X4 SRW and 4X4 DRW.
Hope this helps.
Jimbo
95 F350 CC 4x4 DRW ZF6 4.56 l/s front & rear rsk 9.00R16's Banks stinger
02 F550 EC 7.3 ZF6 4X2 (soon to be 4X4) tow rig
AIS, 4" turbo back, what's next?
I converted mine to dually several years ago to haul a large truck camper then converted it back when I got rid of the camper.
Regardless of what everyone claims I noticed NO difference in stability with the duals compared to singles...just felt better knowing a single rear tire blowout wouldn't roll me. Truck felt fine with singles and felt fine with duals although it did tend to wiggle track more in interstate truck ruts worn by big rigs.
Ya know if the WHOLE truck was as wide as dually fenders I'd probably own one, but I don't like the butt of the truck sticking out.....
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: amberjax</div><div class="ubbcode-body">Brian,
You are the one I was looking for, but I thought that you changed yours to a dually, not the other way. By the way, is the rear end in your truck, the dually rear end? </div></div>
Yea,stock rear end.I'm using a 2" billet steel spacer to put the tires out in the fender.
95 F350 CC XLT,bought new as 2x Dually,owner converted to 4x4,open intake,SD IC,1.0 Housing,Pedestal Mod,Gutted EBPV,dp,5"no muff, Baumann TCS controlled e4od,"I LOVE that thing"!,Baumann VB kit,UCC Custom Billet T/C-VERY low stall speed,Mag-Hytec pan,dual True-Cools,remote filter,3 pos.T/C lock-up switch w/LED,Elec.fans on trans.& engine w/Derale adj.stats,Gauges,Kingpin D60 w/Lock Right,Detroit Locker in the 10.25,4.88s,4" Nat. springs w/ORU-SRK in fr.,crossover steering,10" Atlas springs in rear-no blocks!,Bilstein 5100s,38" PJ Dirt Grips on 16x12" M/T Classic Locks w/Centramatic balancers,Warn hubs,Powerslot rotors,Hawk pads,Can-Back canvas top.
