I'M TIRED OF ALL THESE DA__ SUPERDOODIES THAT ARE TALLER THAN MY TRUCK! I can pass most of em, but they are still taller than me! I WANT MY TRUCK LIFTED! Ain't that the most beautiful *****en you heard lately? Guess I better take advantage of the situation huh? [img]/ubbthreads/images/graemlins/wink.gif[/img]
It has been the plan all along to put a RSK on it. Since Cary educated me, I'll be using 2004 SD front springs (thanks Dutchman!). Got that all down. The real question is what to do with the rear. The way I see it there are 3 basic ways to do it:
6 inch blocks under the stock 3 leaf springs. Advantage, cheap and simple. Dis: wheel hop, and all the things that are negative about blocks. Plus I really want to put on new springs, they are actually worn pretty bad. I can always add air bags if needed. I could use new stock SD rear springs.
Sky rear shackle flip. Advantage, inexpensive. Dis: concerned about the taper block needed to reset the pinion angle back to stock. Also there have been cautions about the shackles folding under side load.....ohh not too pretty with the camper on. Some have used F450 shackles to solve this, ones could be fabbed too.
Replacement lift springs W/O blocks: Briansshop did this- very clean. The most expensive, but the cleanest. I would lean to using Donahoe multileaf SD rear springs for the ride. Probably the best ride set up but what about hauling / towing. Air bags would be needed at least.
One last thing, this truck must be the swiss army knife of trucks. It must be able to haul 2,000 lbs in the bed, haul a cabover camper, and pull any trailer I come across. I need it to be reliable enough to drive the Alcan to Alaska, and I don't want it so unique that I cant fix it away from home. I'm the type to have / carry spares and rebuild things before they break.
What do you think?
Diesel Mechanic 28 yrs
I have the SKY man rsk on my truck. I really like it. I did not go with the sd springs, but it does still ride a little better due to the better placing of the shackles. The sd springs do ride even better I hear. I have the regular F-350 blocks on the rear of my truck now along with an addaleaf. It rides exactly level. About a 3" lift in front with around 1.5 to 2 inches in the rear. I tow and haul more then most would dream about and aside from needing an intercooler (thanks Swamp) the truck handles it all very well. [img]/ubbthreads/images/graemlins/grin.gif[/img]
96 F-250 xlt auto 4x4, 4.10's, ext cab, Red & White two-tone, Dana 60 front end with a Sky Man. Reverse Shackle Kit, Firestone airbag overloads, 35" tires. TYMAR intake, fillernecks, and hx hose, running Roan Switches, custom 4-position chip from Northern Diesel Performance, JS idm, Hypermax dp, 4" exhaust before tire, DIY exhaust brake, homemade AIC, 10k, shimmed reg, sonnex valve and tricumulater springs, Isspro EV gauges on pillar, Lund visor, mudflaps, and steps for the wife.
Oh yeah!! I almost forgot Swamped!!!!
Babies through Northern Diesel Performance.
I wouldn't put blocks in it, i have 6 total inches of blocks and had really bad wheel hop before i put traction bars on it, i'm going with new leaf springs, as soon as i get my D60.
My Trucks,
1999 Dodge 2500... 438HP, I just got a superchip...
1997 F250 ext cab 7.3, 5spd, 4x4, with some modifications (Sold)
2007 Q&S Gooseneck, 25+5 with tandem duals.
1966 Mustang coupe, (Sold)
1984 Chevy K10, Built motor, lift, all the good stuff. (Sold)
1997 F150 XLT ext cab, sb. (Sold) http://community.webshots.com/user/pogrelis97
Myspace: http://profile.myspace.com/index.cfm...ndid=103875904
Hey G_M, I talked to Sky about their REAR shackle flip and was told they were making some stronger shackels to go w/it. It looks like a nice kit but,was going to put the hanger & shackle right where my 5" tailpipe is. Just didn't feel like a more exhaust work! Either way you loose your overloads so prob need airbags to haul some weight.I had some when my truck was low and used to tow a 32' tag and one time hauled 40! sheets of 1/2" 4'x12' drywall in the bed.Was a little hard on the tail gate but the bags worked great.
How high are you going? And tires?
Brian
95 F350 CC XLT,bought new as 2x Dually,owner converted to 4x4,open intake,SD IC,1.0 Housing,Pedestal Mod,Gutted EBPV,dp,5"no muff, Baumann TCS controlled e4od,"I LOVE that thing"!,Baumann VB kit,UCC Custom Billet T/C-VERY low stall speed,Mag-Hytec pan,dual True-Cools,remote filter,3 pos.T/C lock-up switch w/LED,Elec.fans on trans.& engine w/Derale adj.stats,Gauges,Kingpin D60 w/Lock Right,Detroit Locker in the 10.25,4.88s,4" Nat. springs w/ORU-SRK in fr.,crossover steering,10" Atlas springs in rear-no blocks!,Bilstein 5100s,38" PJ Dirt Grips on 16x12" M/T Classic Locks w/Centramatic balancers,Warn hubs,Powerslot rotors,Hawk pads,Can-Back canvas top.
where do you get the sky kit and all the stuff to lift my 250 bec im feeling the superdoodie woes also
05 F 250 XLT extented cab PSD, guages, exterior stuff, recon stuff, SCT Xcal 3 innovative X street tune, silver line cool duals, mtx thunderform encolsure with two 10's, alpine deck.
96 F250XLT heavy duty, ext cab, PSD 5-speed, 4:10's/limited slip-so far homemade tymar intake with big filter ,diy stage 1's, ts 6 pos chip, 4 inch turbo back to 5 inch slash cut stacks, pyro and boost guage.reverse glow guages, replaced clutch with a LUK replacement,garmin street pilot, sirius sat radio, Alpine Cd player, Alpine Type R 12" sub, sony xplode amp in custom center console, diamond plate trim and side steps, Visor, bug sheild,
I did the SKY 3" rsk on the front of my 95 F350 CC, and like you, didn't want to stack blocks on the rear. I like the way the front rides and handles, so that was good.
I found a set of Superlift 4" rear springs; 6 leaves and heavy as lead. I put them on and found a pair of 2" flat blocks to level out the truck, and it looks great. I was concerned about load carrying also, but tested it with a ton (literally) of salt blocks for the ranch. No problems with either sagging or squatting suspension, and have since hauled several pickups on a 20' tongue pull car hauler with no problems at all. Rides better than stock empty or loaded.
The 2" flat blocks are stock on a 1990 F250 4x4, 8600 GVW, and I had to make a 1/4" spacer for the carrier bearing.
Hope this helps.
Jimbo
Oh, tires are 315/70R16 BFG MudTerrains
95 F350 CC 4x4 DRW ZF6 4.56 l/s front & rear rsk 9.00R16's Banks stinger
02 F550 EC 7.3 ZF6 4X2 (soon to be 4X4) tow rig
AIS, 4" turbo back, what's next?
