Old 03-25-2006, 07:11 AM   #1 (permalink)
[Wildman Chip] Can someone explain the settings??
I know call Tony... but I first want to have an idea what is going on before I call.
Can someone explain the following settings?
High idle: Confused on this what is it for and who usually needs this?
Tow: I know I need this as all I use the truck for towing a lot.
Econ: Does this have more or less power than stock?
Extreme: I don't think I need this but would like to know what it is.
Any other settings:
I have a stock 97 E350 (except guages) that I use to tow. What do you guys suggest I get?
How much do these cost if someone could pm me if they don't want to post. Don't want to wast Tonys time if this is out of my price range.
Thanks!!
0100 is offline
Old 03-25-2006, 08:12 AM   #2 (permalink)
Re: [Wildman Chip] Can someone explain the settings??
the high idle is for faster warm ups, and also for your ac in the summer it puts the idle up to like 1200 rpm.
tow is for just that, you can use it when you got a load to haul, it has a faster boost and more power when you need it.
the extreme is for when you really want to go, it gives the most power you can get from your stock injectors, also it is very touchy on the throttle with mass boost levels.
most people run the tow for just driving around, and then put it to extreme when the want the smoke and power to toast ricers. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
97 f-250 powerstroke, e40d shift kit big cooler, 4:10 gears, goose neck hitch,twildmn 4 pos chip, Tymar Intake, 3" downpipe and the cat is dead. HX crossover hose, 3guage pod, Gutted EBPV. 137,000miles
86 f-250 extended cab,4x4,auto,6.9l with hypermax turbo running on veggie.
President of www.RRORC.com
greenbeast is offline
Old 03-25-2006, 09:11 AM   #3 (permalink)
the econ has more power than stock and is for unloaded fuel mileage. A tad less power than Tow
97 psd, sc, 4X4, 4 pos Wildman Chip - Tymar Intake/H-max Downpipe
'99-'00 Igneous Pinners, '00 Igneous Smurfs, '02 Dynastar Arno Adams, '03 Atomic BIG Daddies, '04 V-Pros
-- Resident Bilge Don Quixote #3
lemon boy is offline
Old 03-25-2006, 12:20 PM   #4 (permalink)
Basically what was said above....
I love mine. I have the "Power Selector" knob mounted in the dash right beside the WTS light. This makes it handy for on the fly adjustments.
High Idle would prolly not work out as well in an auto as it does my manual. I have a 1000 RPM idle in my Stock position and an 1100 in my tow position. I love this feature. 1000 RPM warm ups, 1000 RPM cooldowns...it keeps the turbo happy with plenty of oil, prevents any possible wet stacking (I don't buy into this much), lets the AC work better, better starts at the stop lights...the list goes on.
Being a lover of military aviation from the old prop days... my positions are labled as follows:
1. Military (Stock)
2. Auto-Lean (economy setting)
3. Auto-Rich (Tow)
4. War Emergency Power (Extreme)
Brendon
<----- My Baby: 1951 R John Deere with factory optional all steel cab.
<font color="1adf00">1996 F350 XLT 4x4 SWR Long Box,TWildman 4 Position Chip, ZF-5, Tymar Intake, 3" Turbo back exhaust, No cat, no muffler, Boost Pressure and Coolant Temp manual gauges mounted on bottom of dash in typical farmer fashion [img]/ubbthreads/images/graemlins/wink.gif[/img] DeeZee Moon visor and running boards, John Deere floormats and mud flaps,EBV Engine Brake w/3 Position control switch, Shimmed FPR to 82PSI, JS IDM, Westach EGT 100-2000* </font>
Kansas_Farmer is offline
Old 03-28-2006, 05:41 AM   #5 (permalink)
Awesome info thanks guys!
Another question.
Does Econ get better fuel mileage than stock?
I am definitly getting tow.
Just not sure on:
3 pos
1.Stock
2.Econ
3.Tow
or
2 pos
1.Econ
2.Tow
If Econ has more power and better mileage than stock than I probably don't need Stock. Any suggestions?
Thanks again!
0100 is offline
Old 03-28-2006, 02:36 PM   #6 (permalink)
My Photos: (9)
I think everyone said that at one point till they tried it. [img]/ubbthreads/images/graemlins/biggrin.gif[/img] I never looked back. [img]/ubbthreads/images/graemlins/smokin.gif[/img] Well just to see the tire smoke.
Jon K
94 F250 4x4 SC LB 367,000 miles (Same motor it came from the factory with) 5 speed, Intake, Bully dog 4 pos chip, Egt gauge, 3in down pipe into 3in straight pipe, 16x10 rims 265/75/16 tires, 2in leveling kit http://photos.thedieselstop.com/show...=1&thecat=500/
jonathankasprzak@hotmail.com
kasprzak85 is offline
Old 03-29-2006, 12:06 AM   #7 (permalink)
my best mpg was in extreme
95 f250 psd reg cab XLT 4x4 5sp 4:10 188k
diy tymar, big exhaust, 4 pos chip burnt by bdp, carbon fiber gauges, luk smfw
bean's stage I's
new ride: 02-99 f350 srw cc lb 4x4 6sp 3.73 stock, previous owner installed some kind of 10k, or 18k mod, true milage unknown
1064RG is offline
Old 03-29-2006, 03:24 PM   #8 (permalink)
DIESELDUTTON's Avatar
I went to BTS this weekend and this was the first time i was able to put some miles on the truck to compare the first two tanks in econo doing the speed limit about 70mph i got 18.5 mpg the second fill in the stock program i got 19.5 i was on cruise the whole way after i got my tranny done i drove back in the stock position and got 20.5 and in the stock position it feels more like my 40 hp tow program i cant say enough about Brian and his crew at BTS it was worth every penny and every mile of the 2,460 mile trip Thanks
Frank
http://community.webshots.com/user/dieseldutton
2004 Pitbull Motorsports rigid chopper
121 TP 130rwh 250 avon
04 CRF250 mine
02 CR80 sons
03 XR100 daughters
425 Polaris magnum
500 Polaris sportsman and 300 lakota everyones
1998 27.5 Wilderness 5th wheel
DIESELDUTTON is offline
» Sponsor Links
»Garage Storage and Cabinets
