Old 10-31-2007, 10:16 PM   #1 (permalink)
Fordpowrstroke73's Avatar
My Photos: (6)
Send a message via AIM to Fordpowrstroke73
Wildman Tunes........WOW!!
I got some of Tony's tunes last week, and all I can say is wow!! It is so much better than the TS stuff I used to have. It makes the ol truck scream now!!
'95 Ford F-350, CC,4x4, 7.3 Powerstroke,RDS Stage 1's,Tony Wildman 6 position chip,3.55LS,modded IDM(Thanks Dan),3" downpipe-5" mitre cuts,ebpv gutted, 6" tip,Napa 6637 air filter,Autometer ultra lite triple pillar gauges,Dana 60,Rancho RS 5000 schocks,E40D junk trans,,Aluminum tool box with 7 LED's, headache rack,bed protectors,Hayden Trans. Cooler,Custom Homemade SD Stainless Steel Nerf Bars,285/75/16 BFG All Terrains on Factory Alcoa's,'02 SD Intercooler with homemade IC pipes,Gooseneck hitch
Fordpowrstroke73 is offline
Old 10-31-2007, 10:28 PM   #2 (permalink)
DIESELDUTTON's Avatar
Re: Wildman Tunes........WOW!!
I wonder what tunes I have, I bought a 6 position chip along with my stage 1's from Bean a couple of years ago, I'm not sure who's programs they are. It is a TS chip. Did you have a TS chip and TS tunes before. Thanks
Frank
http://community.webshots.com/user/dieseldutton
2004 Pitbull Motorsports rigid chopper
121 TP 130rwh 250 avon
04 CRF250 mine
02 CR80 sons
03 XR100 daughters
425 Polaris magnum
500 Polaris sportsman and 300 lakota everyones
1998 27.5 Wilderness 5th wheel
DIESELDUTTON is offline
Old 10-31-2007, 10:31 PM   #3 (permalink)
My Photos: (9)
Now you know what some of us have known for quite a while!!!
Chris
97 F-350 cc srw 4x4,White,cab hi Leer,E4OD,4.10's,Hypermax H2E,Banks intercooler,BDP stage 1 injectors and fuel system,BTS tranny,BTS twin hpop,4 postion chip programmed by Cale,Skyjacker 4" system,35" BFG's W/Welds,Rear air bags,Hayden 26,000 trans cooler,4" exhaust,Tymar intake&hx mod,Amsoil dual bypass filter w/Amsoil syn. oil, and diff. lube, Ford aic, Joe Servo idm.
353 HP 677 TQ on BTS's dyno at 0 correction
SLAPS Treasurer
Member of FOKISD
<font color="red"> #5 </font>
Truck pics at http://community.webshots.com/user/ytee1100
ytee is offline
Old 11-01-2007, 12:25 AM   #4 (permalink)
My Photos: (6)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: DIESELDUTTON</div><div class="ubbcode-body">I wonder what tunes I have, I bought a 6 position chip along with my stage 1's from Bean a couple of years ago, I'm not sure who's programs they are. It is a TS chip. Did you have a TS chip and TS tunes before. Thanks
Frank </div></div>
Ya I had TS on the chip, but not anymore! [img]/forums/images/%%GRAEMLIN_URL%%/cool.gif[/img]
Old 11-01-2007, 09:07 AM   #5 (permalink)
Frank, call Bean..he may have had Tonys burn on it then but I would get new burns from Tony regardless.
Cary
1971 EB Hard Core Crawler
2006 Yamaha FJR1300
2005 Suzuki King Quad
caryt is offline
Old 11-01-2007, 09:29 AM   #6 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: caryt</div><div class="ubbcode-body">Frank, call Bean..he may have had Tonys burn on it then but I would get new burns from Tony regardless.
Cary </div></div>
I talked to Bean after I bought the chip and he said they have a bunch of programs, some are from Tony, but at the time he wasnt exactly sure which tunes were on my chip. I'm gonna send it to Tony, I was trying to wait until all of my mods are done, like electric fuel system, Dom-66 and a SD pump or Big Oil, but that might not be until the spring so I might just send it out when I go on vacation at the end of November, because I could never drive this truck in the stock setting [img]/forums/images/%%GRAEMLIN_URL%%/grin.gif[/img] Thanks
Frank
04 CRF250 mine
02 CR80 sons
03 XR100 daughters
425 Polaris magnum
Old 11-01-2007, 12:20 PM   #7 (permalink)
MarkEkberg's Avatar
My Photos: (13)
Do you have to send the chip to him. I don't want to be without my chip for a couple weeks [img]/forums/images/%%GRAEMLIN_URL%%/smile.gif[/img]
MarkEkberg is offline
Old 11-01-2007, 12:48 PM   #8 (permalink)
My Photos: (6)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: MarkEkberg</div><div class="ubbcode-body">Do you have to send the chip to him. I don't want to be without my chip for a couple weeks [img]/forums/images/%%GRAEMLIN_URL%%/smile.gif[/img] </div></div>
Ya if you just send it him, it shouldn't take to long. I was in the same boat, but defiantly worth the wait! [img]/forums/images/%%GRAEMLIN_URL%%/grin.gif[/img]
Old 11-02-2007, 01:25 PM   #9 (permalink)
Buy a new one and sell the old one [img]/forums/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
Cary
2006 Yamaha FJR1300
caryt is offline
» Sponsor Links
»Garage Storage and Cabinets
