Old 12-19-2005, 10:13 PM   #1 (permalink)
Will any year IC work on our trucks?
Was looking on eBay for an intercooler. Will any year work?
Thank you,
Jeff Blumenthal
Austin, Tx
97 F350 CC SWD 4X2 4:10, Wildman chip, AFE Stage 2, 6.0 IC, BD 4" Exhaust System, BD Exhaust Brake, BD AutoLoc, Tranny Shift Kitted, Billet Torque Converter, Tru Cool 4739 w/Thremal Bypass, EGT Shutdown Monitor, Air bags, EGT/Boost/Tranny Piller Guages
warpdriv is offline
Old 12-19-2005, 10:22 PM   #2 (permalink)
Banned
Re: Will any year IC work on our trucks?
ya,im getting ready to do a 05 6.0 IC in mine
tubzz is offline
Old 12-19-2005, 11:27 PM   #3 (permalink)
Jeff, since your truck is 4x2 the 6.0 intercooler will hit the sway bar. I dropped mine 4 inches to make it fit, everything else fit great.
'01 F-250,4x4,SC,LWB, Evans coolant/coolant filter, ATS Stage 5 tranny/torque converter, V-10 tranny cooler, 3.73 w/Detroit locker, Truetrac front, Bilstein 5100's, Auto-Meter Phantom's, 5" Hypermax exhaust
BDP
'02 F-250 4x2 CC SWB 4R100, 3.73ls(shimmed carrier), DI chip, CCV mod, 203* t-stat, coolant filter, AIH delete, Tymar HPX oil line, AIS, WW, Banks 1.0 "slowspool" housing, pedistal mod, Banks elbow&BHA, 4" turbo back w/btm, Isspro's
6.0 intercooler install(OBS)&truck pics
<span style="color: red">RDRCM #10 </span>
Sniper's credo "If you run, you'll just die tired"
richmondfarms is offline
Old 12-19-2005, 11:29 PM   #4 (permalink)
Any 7.3 SD (like 99-03) intercooler will fit with say, the GTS pipe kit (this is what I got). If using the stock SD pipes I think they require a little fabbing. If using the 6.0 (03-up) intercooler the GTS pipes or stock SD pipes will require some fabbing... or so I hear.
The 6.0 intercooler I don't think has seen enough installations with the GTS kit though to say that for sure. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
- Ryan
<font color="red">7.3 POWERSTROKE DIESEL</font> F-250 Flatbed 4x4 -- full info and pics inside
<font color="black">DOB 6/10/1996</font>
<font color="red">bdp</font> <font color="#8B7162">Stage I injectors and custom programs</font>
<font color="orange">SBC</font> <font color="#8B7162">Con OFE</font>
<font color="green">2002</font> <font color="#8B7162">SD HPOP</font>
285HP
Live in SoCal? Check out SoCAPS! [img]/ubbthreads/images/graemlins/grin.gif[/img]
ryanPSD is offline
Old 12-19-2005, 11:33 PM   #5 (permalink)
Banned
gts kit worked with no modifications plumbing in my 6slow cooler
luke
lukecline is offline
Old 12-19-2005, 11:39 PM   #6 (permalink)
Really?
I swear I heard a couple quick fabs to his pipes were needed?
I guess it makes sense, if Ford upgrades their IC and if they have room for a larger cooler, keep the pipes the same. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Dang, if I'da known I'da gotten a 6.uhoh intercooler. [img]/ubbthreads/images/graemlins/grin.gif[/img]
edit: I still can my IC is still sitting on my desk! [img]/ubbthreads/images/graemlins/mad.gif[/img]
ryanPSD is offline
Old 12-19-2005, 11:49 PM   #7 (permalink)
Banned
the SD pipes will need some work to fit in a OBS truck
tubzz is offline
Old 12-20-2005, 03:06 AM   #8 (permalink)
Banned
The stock SD pipes need a lot of work to fit without rubbing on a ton of stuff. You can do it easiely by lengthening them by about 3" in the middle but then you end up with a 3/4" hole in one like I did way back when I first did my IC. I guess that was incentive to do something a little different! [img]/ubbthreads/images/graemlins/biggrin.gif[/img] I haven't personally installed a 6.0L cooler with a kit yet but from what I've been hearing all you need is one different coupler.
gtspowerstroke is offline
Old 12-20-2005, 09:07 AM   #9 (permalink)
Banned
Oh thats right, i forgot about that coupler. Its a stock 6oh coupler and i got rapped for over 50 bucks at ford. If i recall it takes the 3.25" ic outlet to 3" so it will mate up w/ ic pipe.
luke
Old 12-20-2005, 10:20 PM   #10 (permalink)
Hey Luke,
Which kit did you get from GTS Motorsports for your 6.slow cooler? There are a few of them.
http://www.gts-motorsports.com/fordintercoolers.html
Thank you.
Jeff Blumenthal
Austin, Tx
warpdriv is offline
Old 12-20-2005, 10:51 PM   #11 (permalink)
Banned
the pipes are the same in the kits.the spider just works with a stock turbo. you have to fine one coupler to make the 6.0 IC work that doesn't come in the kit.
tubzz is offline
Old 12-20-2005, 11:00 PM   #12 (permalink)
Banned
i got the one at top of page for 595.
Luke
Old 12-20-2005, 11:03 PM   #13 (permalink)
Banned
you want to do my swap for me? just can't find the time [img]/ubbthreads/images/graemlins/frown.gif[/img]
tubzz is offline
Old 12-23-2005, 07:36 PM   #14 (permalink)
Just scored one off ebay for $50. [img]/ubbthreads/images/graemlins/cool.gif[/img] [img]/ubbthreads/images/graemlins/shocked.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Here is a link for the auction. It is closed, but they have 8 left.
http://cgi.ebay.com/ebaymotors/ws/eB...wItem&amp;rd=1,1&amp;item=8023945431
Jeff Blumenthal
Austin, Tx
warpdriv is offline
Old 12-23-2005, 08:25 PM   #15 (permalink)
Darth_Stroker's Avatar
My Photos: (6)
Are any of the 6L intercoolers all aluminum, or do they all have the plastic sides?
Alan
97 F350 CC 4x4
BDP Stage 2's, Dominator 66 turbo, 4pos Wildman Chip, BTS Tranny, ATS .95 Wastegated exhaust housing, Hypermax IC and Pipes, comp 910 valve springs, MBRP DP and 4" exhaust, DIY intake, 17 deg SD hpop, Autmometer sport comp boost,pyro,tranny temp, 35" BFG A/T's, Centerline wheels,3.55 LS, Powerslot rotors,hawk pads, gpr bypass,ac mod,fumoto valve,coolant filter,ELC coolant,JD coolant eye,fpr shim,EBPV gut, IDM Mod
Fightin Texas Aggie Class of '98
Darth_Stroker is offline
