When adding an intercooler, do we HAVE to have an early 99 y-pipe or will a 2001 model work? My concern is where the turbo bolts to the intake.
You will need one from an early 99. A 2001 wont fit. You will have to change to much to get it to work. But the early 99 will be a direct fit for you 97
1996 crew cab 4x4 black psd BDP 250cc hyrbids BDP fuel system Stealthhinator dual ipr hpop
H2E TDP tuning 515hp 1158tq
99.5 psd reg cab 2wd
334hp 740tq
rdrcm #29
"New opinions are always suspected, and usually opposed,without any other reason but because they are not already common" John Locke Truck and misc pics
To further what pwrtrip mentioned. If you are to use a late 99.5 and newer Y pipe you would have to change the turbo, turbo pedistal, up pipes and up pipe collector as they are different then the 97 or early 99.5. Given that you have the D66, would guess you would not want to change out all the for noted stuff. As I recall factory early 99.5 may be the easiest or there are aftermarket ones available i'm sure, or you could fab your own, kinda depends on what you want to do.
jrc
jrc
96 XLT F350 CC ZF-5 355's 16x8 aluminum rims 285/75R 16 Dick Cepek F-C IIs. T Wildman programs, Map regulator, DIY CCV & HX mod, TDS exhaust brake, BD gauges, downpipe 4" exhaust, custom SS resonator, LUK, SD I/C, Custom Shackle Reversal, Custom Moose Bar and Velvet rides, RS 9000x shocks, Custom Aluminum Drybox/fuel tank, Swamp's Baby Injectors, SD Hpop, DIY Oil by pass filtration, DIY electric fans, DIY E-Fuel system, Lighting by VisionX, LightForce and PIAA and other stuff. http://community.webshots.com/user/jcart44
