03-02-2006, 07:18 PM
#1 (permalink )
will late model wheels fit my 96 superduty
like the title says...will late model(99up) wheels fit my 96 superduty 2wd
03-02-2006, 07:39 PM
#2 (permalink )
Re: will late model wheels fit my 96 superduty
sorry, no
97 f350 cc 4x4, srw ,tde1, 4.10 gears,head studs w/ factory gaskets' bts tranny mobil 1 synthetic diesel site full pull injectors h2 turbo, 02 hpop ,twin tymar intake ,beddins custom fuel system ,custom ladder bars,turbo life saver,dead kitty, ,dp tuner 4 position chip,hypermax innercooler,oil filler extension,,maghytec pan,4inch exaust w/ 4" stacks, aux tranny filter,dual aux tranny coolers, autometer a-pillar 3gauge,295 nitto at's,4inch lift,ranchhand bumpers front&rear
If you are reading this, THANK a teacher. If you are reading this in ENGLISH, THANK a soldier!!!
03-02-2006, 09:41 PM
#3 (permalink )
97 and down wheels are 8 on 6.5" bolt pattern
99+ SD wheels are 8 on 170mm bolt pattern
99 F350 XLT 4x4, Crew Cab, 6spd, 19.5s, Cummins 12V powered, with a few mods, SBC DD clutch
2005 F250 XLT, Supercab, V10, 6spd, 4wd, SWB, 4.10 LS
03-02-2006, 09:47 PM
#4 (permalink )
A 96 Superduty has 10 hole wheels. Are you needing a complete set of wheels or just a spare? I have one new wheel and tire.
03-03-2006, 08:49 PM
#5 (permalink )
my bad..i meant was f250 "superduty"...not the f450
03-04-2006, 07:25 PM
#6 (permalink )
Do you mean "F-250 Heavy Duty"?
Bright White 1997 F-350 XLT Crew Cab Duallie, This is a late-build (11/97) truck and one of the last of the "real" ones! 7.3 Power Stroke, E4OD, 4.10 Limited Slip, Alcoas, 5-inch turbo-back system, 42,000 original miles and every option you could think of. I love this truck...absolutely the baddest '97 on the planet...I get at least two offers to buy it every time I drive anywhere.
03-04-2006, 10:04 PM
#7 (permalink )
yeah...stupid me
91 F-350 rollback car hauler, 7.3, 5spd, 159,000 miles, stock,stock,stock/SOLD,SOLD,SOLD
96 F-250 ex-cab swb,powerstroke,tymar,stock"for now"sold sold
05 F-250 sold
03 F-350 single wheel, 4wd, stock, 258,000 miles!!sold
06 F-350 4 door,4wd,tow command,tow boss,lariat,everything you could get sold
00 excursion diesel 4wd limited sold
02 E-350 Traveler powerstroke sold
03-04-2006, 10:34 PM
#8 (permalink )
only the 97's said "F-250 HeavyDuty" on the fender badge
Rodney #33
96 F250 XLT, RC, 4X4, 3.55's. 86 Kingpin D60, Sixpak of TW's tunes, DI Mini-Me's, H2E, Stealth Oil, BDP Fuel/twin SD pumps, ARP headstuds, DI pushrods, John Wood Trans, JoeServo IDM, 6.0 intercooler, Windstar fans, SD dual tensioner pulley, 4" TuffCountry lift, 35" BFG AT's, Centramatics, MileMarker hubs, Westach gauges, Fumoto valve, Amsoil bypass, Stancor 586-902, Aeroturbine 4040 /4" stacks, SD seats, PA 2818, 203º t'stat, vented filler necks, a/c mod, custom desert pinstripes,,,,,,,,,
2000 3500 SLT QC 24V 4x4 DRW NV5600 mostly stock
Arizona Powerstroke Group
03-04-2006, 11:01 PM
#9 (permalink )
Also, 99+ wheels are hub-centric(flat lug nut), the OBS wheels are lug-centric(cone-style lug nut).
'01 F-250,4x4,SC,LWB, Evans coolant/coolant filter, ATS Stage 5 tranny/torque converter, V-10 tranny cooler, 3.73 w/Detroit locker, Truetrac front, Bilstein 5100's, Auto-Meter Phantom's, 5" Hypermax exhaust
BDP
'02 F-250 4x2 CC SWB 4R100, 3.73ls(shimmed carrier), DI chip, CCV mod, 203* t-stat, coolant filter, AIH delete, Tymar HPX oil line, AIS, WW, Banks 1.0 "slowspool" housing, pedistal mod, Banks elbow&BHA, 4" turbo back w/btm, Isspro's
6.0 intercooler install(OBS)&truck pics
<span style="color: red">
RDRCM #10 </span>
Sniper's credo "If you run, you'll just die tired"
03-04-2006, 11:45 PM
#10 (permalink )
I was also wondering if the 99 up dually wheels will fit a 95 f350 dually?
95 F350 crew cab PSD 2wd automatic 3 1/2" downpipe
4" exhaust 4.10 gears TS performance 6 position chip.
03-05-2006, 12:43 AM
#11 (permalink )
Nope, even the 99+ duallies have the 170mm bolt pattern and yours has 8.5" bolt circle
Rodney #33
03-05-2006, 03:10 AM
#12 (permalink )
And I belive that the 05 and 06 Super Dutys are 8 on 200mm.
03-05-2006, 02:07 PM
#13 (permalink )
I think I read on here the other day that 05/06 dually wheels will fit on 97 and earlier trucks???
My Trucks,
1999 Dodge 2500... 438HP, I just got a superchip...
1997 F250 ext cab 7.3, 5spd, 4x4, with some modifications
(Sold)
2007 Q&S Gooseneck, 25+5 with tandem duals.
1966 Mustang coupe, (Sold)
1984 Chevy K10, Built motor, lift, all the good stuff. (Sold)
1997 F150 XLT ext cab, sb. (Sold)
http://community.webshots.com/user/pogrelis97
Myspace:
http://profile.myspace.com/index.cfm...ndid=103875904
03-09-2006, 10:28 AM
#14 (permalink )
Let me clarify this,
The only BOLT Pattern Change that occurs on the 05 and 06 Trucks are on the Duallys, they changed to 8x200mm and they have a bigger hub bore also.
The Single Wheel Truck STILL has the 8x170mm pattern.
Linear Mode
» Site Navigation
» Other Sites
» Network Links
» Sponsor Links
