Old 05-17-2007, 10:45 PM   #1 (permalink)
WILL A SD DANA 60 FIT A 97 F350
GREETINGS, JUST WONDERING IF A SUPER DUTY FRONT END WILL BOLT INTO A 97 F350.
1997 F350 XLT, CREW CAB, POWERSTROKE, AUTO,
278,000 MILES. TYMAR INTAKE SYSTEM. 3" down pipe,
4" exhaust. 14-16 mpg, RSK with SD springs, 315 Dick Cepek Mud tires on 10" rims and BULLYDOG 4 BANKS CHIP, Bilstein Shocks
dieseldo is offline
Old 05-17-2007, 10:49 PM   #2 (permalink)
STurbo90's Avatar
My Photos: (9)
Re: WILL A SD DANA 60 FIT A 97 F350
it will...........
BUT the spring perches are slightly different widths, so the springs will be slightly angled.
The lug pattern is different, so you will need to swap the rear axle as well, unless you want to have two different spares.
1995 F350 PSD,CC,LB,E4OD,4WDw4:10LS
IDM Corrosion
Underdash Gauge Pod
Front Tow Hooks
STurbo90 is offline
Old 05-17-2007, 11:32 PM   #3 (permalink)
And then you come to the non serviceable wheel bearings the SD guys are paying big bucks to retrofit......
The only upside is the ability to use the SD rear with disc brakes.
Diesel Mechanic 28 yrs
Garbage_Mechanic is offline
Old 05-18-2007, 09:59 AM   #4 (permalink)
But you could always add disks to the stock rear.
Cary
1971 EB Hard Core Crawler
2006 Yamaha FJR1300
2005 Suzuki King Quad
caryt is offline
Old 05-18-2007, 02:04 PM   #5 (permalink)
In closing- Probably best to get a OBS dana 60 and avoid the hassle of the SD axle. It might be a cheaper initial purchase but the cost to get real bearings like the OBS has stock and the different bolt patterns just isn't worth it IMO.
97 F350 std. cab PSD, Auto, Autometer Z-series, 4" MBRP s/s exhaust, AD code Inj., TS 6 pos chip tuned by TW, shimmed FPR, AFE Intake, IDM Mod, 315/75/16 Toyo M/T, ARB Bull Bar w/Warn winch & IPF lights.
jeepermc is offline
Old 05-18-2007, 02:06 PM   #6 (permalink)
A very good option Cary, I would just love to have a rearend that is a little wider and that came with factory disc brakes and the right bolt pattern.
Old 05-18-2007, 08:27 PM   #7 (permalink)
You already have the second best front end you can get...its a D60 now, the best is a king pin D60 [img]/ubbthreads/images/graemlins/wink.gif[/img] You won't gain anything but a weaker axel going to a SD..its gona be a D60 with the crap uni bearings or if your lucky [img]/ubbthreads/images/graemlins/rolleyes.gif[/img] you get a D50 SD version with uni bearings and d44 outers [img]/ubbthreads/images/graemlins/vomit.gif[/img]
Cary
2006 Yamaha FJR1300
caryt is offline
» Sponsor Links
»Garage Storage and Cabinets
