Old 01-23-2008, 10:52 AM   #1 (permalink)
Question Wire question
I am planning on rewiring my glowplug harness, completely abandoning the factory GP wiring after the GPR. I am tired of having GPs fail after a year, cooking the harnesses and VCGs, making the engine run poorly and necessitating a day under the hood and another $100+ in parts.
I intend to feed a single 12v lug off the GPR for 8 individual 10 or 12ga leads, fed thru grommets in the valve covers; I will use .157 femalebullet connectors to attach to the GPs, as they're a nearly perfect fit. There will also be a connector on each lead just outside the VC to enable me to insert an 60A ammeter to check each GP without having to pull the valve covers. My question is: what type of wire will withstand the temps and oil under the valve covers? I have plenty of new THHN 12ga with the two-part insulation, rated as oil-resistant and good to 90*C. It is obviously hotter than that under the VCs. I have used THHN, however, in the vicinity of the engine with no problem.
Can anyone point me in the right direction? Thanks -
Josh
'96 F350 XLT CC 4x4 PSD auto LWB 4.10 open, white, open intake, Tymar HX, 3"DPP downpipe, 315 Toyo A/T (2nd set - got 55k from first set) on factory Alcoas, big front bumper w/4 really bright lights; F add-a-leaf, new alt x3, fuel pump, water pump, t-stat, fuel heater, vac pump x 3, PS pump x2, SD starter, rebuilt seats, total poly bushing kit, serious noise reduction, new tan interior and vinyl floor, Bilsteins, Bean's Stage 1s, Tony Wildman 4-pos chip (wow), etc ad infinitum, black Lab in backseat, locally rebuilt tranny & new TC @ 211k, complete body 'makeover' and repaint @ 213k, 233k and counting...
JoshR is offline
Old 01-23-2008, 12:11 PM   #2 (permalink)
I had similar concerns with my truck, but approached the solution from a different angle. I upgraded the UVC harnesses and gaskets to the super-duty style, which has heavier 14-ga pins for the glowplugs and costs quite a bit less. I then wired each glowplug through an individual 30amp maxi-fuse and 40amp automotive relay. (The combined resistance of 8 of these relays in parallel is more than the stock GPR, so I don't think there will be a problem with overextending the PCM.)
The link in my signature has pictures of most of it.
-RD
ps. I'll try to put up some pics of the finished installation later.
1997 F350 CC DRW E4OD POS. electric fuel
webshots
RD97 is offline
Old 01-23-2008, 12:14 PM   #3 (permalink)
u2slow's Avatar
My Photos: (16)
I would look at equipment wire... one of the SEW types. The insulation is a silicone rubber with 150°C or 200°C rating. It is oil resistant and usually very supple due to the fine stranding. However, I would check with a supplier if its suitable for what is essentially oil immersion.
I like your thinking on rewiring the GPs. I'm watching this thread.
95 F350 Crew 5spd/4.10, SuperChips tuner, solid flywheel, T444E waterpump, 205° stat, Locked F&R, 9.00R16 Michelin XLs
97 E350 SRW cutaway, E4OD/D70/4.10, 19.5s on the rear, deep trans pan, batteries inside, 1800W inverter, manual glowplugs
84 C30 Suburban, 6.2/4-spd, 3.21s
Other rigs I goof around with regularly:
93 F350 4x4, 7.3 IDI turbo, 5spd, 4.10s
90 F250 4x4, 7.3 IDI, 5spd, 3.55s
, D60 swap, straight pipe, turned up fuel screw
u2slow is offline
Similar Threads
Shift lever wire question miteyvictor General Questions 2 07-15-2007 01:26 AM
wire code question jetsonic General Questions 2 04-24-2007 01:23 AM
PLease help, speaker wire question joewegat Power Strokes 1994-1997 Upgrades and Aftermarket 4 09-07-2006 12:27 AM
Wire harness question? magone 7.3L Power Stroke Engine and Drivetrain 0 02-24-2006 03:28 PM
Strange question about a frame wire brents_f350 7.3L Power Stroke Engine and Drivetrain 0 03-28-2005 01:23 PM
» Sponsor Links
»Garage Storage and Cabinets
