Old 09-24-2006, 07:49 PM   #1 (permalink)
workhorse module
hey guys have any of you tryed this new module the web site is www.morepowerlessfuel.com it claims at least a 15% fuel mileage increase 80hp and 160 ftlbs tourque at rear wheels all with no need for gauges as there is no increase in temps . has any one got one in use right now? [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
roland is offline
Old 09-24-2006, 10:31 PM   #2 (permalink)
Patrick Feeley's Avatar
My Photos: (18)
Re: workhorse module
Still sounds like an overblown 10k mod to me (only my opinion, though). Cheers!
1994 F350 CC DRW 2WD PSD (ALF4), ZF 5 Speed, 4.10 LS, SBC Con-O SMFW/Clutch, Baldwin Filter, Tymar HPX Hose, DPPI DP, Bilsteins, $12 AIC, Coolant Filter, Stancor GPR, Explorer Overhead Console, A-Pillar w/ISSPRO Black Ice, EV Boost, and EV Pyro (pre-turbo) , Relocated Block Heater Plug, Modified Pedestal, Gutted EBPV.
Patrick Feeley is offline
Old 09-24-2006, 10:36 PM   #3 (permalink)
My Photos: (6)
To increase the fuel rail pressure on PSDs you really increase the high pressure oil rail pressure. That's what the 10k mod does. They claim to be using a microprocessor to do this but that is an overkill for our engines. I do everything they describe with one transistor and a hand full of resistors. The price is outrageous. Read the add carefully. The power and mileage claims are "up to" not that you get at least that much. Increasing injection pressure does add more fuel and can increase EGT but probably not on a stock OBS Powerstroke because the HPOP isn't capable of providing that much oil. Save your money. A good chip producing the power they claim will increase power without producing excessive EGT or smoke.
This is my opinion. You can take it or ignore it. I do not care.
97 F-250 SC LB PSD. 4x4, BTS E4OD, 4:10LS. Baby Swamps, DP-Tuner F5 custom 6 program chip, 1.0 housing, SD-IC, SD-HPOP, IDM mod, HPX, Black Box ICP mod, Black Box MAP sim mod, Hypermax DP & 5" ex., Aero-Turbine, TYMAR intake, RW Turbo-Trac, Gauges, Airlift bags, Add-a-leaf, Superwinch hubs, Class V rear receiver, RBW Lil Rocker, DIY Tow hooks. Milemarker hyd. winch. Elkhorn 9VS slide-in, Nomad 24 ft. fifth/w slide, Century topper, old classic Sooner 18' 4 horse stock trailer. StarFlyte by DynaMax 6.8 V10
If you don't care where you are, you ain't lost.
Larry
Larry S. is offline
Old 09-26-2006, 12:25 AM   #4 (permalink)
The workhorse module deals with injection pressures. I sat down and talked to a company in my home town that sold workhorse modules and workhorse modules only and timing and pulsewidth was greek to them. If you are looking for hp and mpg I would talk to TWilman or DP, they have a very strong grasp on more of the variables ie: pulse width, timing, cp's, and injection pressure.
1997 Powerstroke F250 4x4, Swamps hybrid 250's,3 position chip,Hypermax down pipe, gutted ebpv,Isspro pyro and boost,Tymar intake, South Bend con-o-fe,DIY 5" turnout stacks,cheessy stick on fiberglass hood scoops, cracked windshield, and various wiskey bumps
<font color="red">MY PICTURES</font>
Nathan79 is offline
Old 09-26-2006, 02:01 AM   #5 (permalink)
Also talk to DI. David can make some mean burns. I wouldn't mess with any of thouse plug in modules. No matter what more fuel = more heat.
96' F350 4X4. E4OD tranny running Amsoil synthetic, 1 big tranny cooler and tricumulator springs and accumulator valve. Autometer guages, homemade intake, TS 6 position Chip (tuning by Diesel Innovations , Factory AIC, A/C mod, MBRP 4" Exaust, BDP Stage I injectors, Brakesmart trailer brake controller, T/C lockup switch
Soon to be installed: Innercooler (sittin at the shop), Big Oil, Built Tranny, Coolant Filter, HX hose, and some others. 350k miles.
Truck pics
Houston Area Powerstrokes
TimMiller is offline
Old 09-26-2006, 02:16 AM   #6 (permalink)
There is almost no way to get 80 more HP out of stock injectors at the rear wheels, unless you use drugs maybe. Our stock injectors can't get that much fuel out.
Dave
Smokyred- RED 11/97 F250HD XLT SCLB Auto 4.10LS 4x4 OFFROAD Powered By 2L Motorsports and SWAMPS.
Mods: AM Ultra-Lites, DiPricol HPOP gauge,TS/2L Moto Chip, 4" Straight-Piped, Poor boy's intake, Swamps II's, BTS, 285 BFG A/T's on factory Alcoas. Lots more to install, see below!
On the bench: AirFlo S400, Swamps 275's, Studs Rods and Springs for the top end, and some other stuff.
My Pictures
DD- SILVER 11/97 F350HD XLT RCLB Auto 3.55LS 4x4 OFFROAD
Mods: Redneck straight-pipe, TS/2L Moto chip.
smokyred is offline
Old 09-26-2006, 10:33 AM   #7 (permalink)
Workhorse [img]/ubbthreads/images/graemlins/laugh.gif[/img] [img]/ubbthreads/images/graemlins/laugh.gif[/img] what a joke, Outright lier's for that $$$ get a Tony Wildman chip.
Cary
1971 EB Hard Core Crawler
2006 Yamaha FJR1300
2005 Suzuki King Quad
caryt is offline
Old 09-26-2006, 04:46 PM   #8 (permalink)
Nit
teh only way to get 80hp out of stock injectors is to max out a propane system
1997 F250 FireTruck Red,CC SB,auto( Prescion TC, HD-2Tugger),5" exhaust, custom Swamp 195cc Hybrid injectors, TWildman 4-pos chip,open air cleaner, I/C w Banks intake, 225,000km,AIC,dual electric fans,Sky mfg RSK w/ D60w/ARB locker,Ramsey 15k# winch, BFG/AT 315's, F450 rear springs, home of Craig's Performance Diesel
pictures
" lying is a cheap way out of reality, the real cost is the loss of respect and trust"
dirty30
Nit is offline
Old 09-28-2006, 04:18 PM   #9 (permalink)
Thanks for the info I think I will go for a 6 pos bully dog 75 hp max can you get tonys chips sent up to mb can no problem or should I just stick with the bully that I can pick up locally at a speed shop tnanks
roland is offline
Old 09-29-2006, 10:19 AM   #10 (permalink)
Bully dog [img]/ubbthreads/images/graemlins/vomit.gif[/img] [img]/ubbthreads/images/graemlins/vomit.gif[/img] have you done any reading on this forum???? Get a Wildman or a DP chip and stop thinking about the other crap.
Cary
2006 Yamaha FJR1300
caryt is offline
Old 09-29-2006, 12:37 PM   #11 (permalink)
Just as a note, my local deisel performance shop recently did a test on various procducts, and the Bully Crap, gave the least power increase, with the highest overall egts. Not what you want for towing!! I would take CaryT's advice, and call Tony and get him to burn you a chip. Convinience is not wirth it in this case, plus Tony will reburn the chip for free if you do not like the initial set of tunes. Plus, his new programms have really made my tranny shift well. It will keeo my truck in the power band and does a great job of tuning for towing!! Just my recommendation! Colin
1997 ECLB F-250 4X4, TAT e4Od,4.10 Open Diffs,Superwinch Manual Hubs, 265/75/16 Force 4 AT's, DP Tuner F-5 5-Position (Stock,Hi-Idle, 40 Tow, 40 High Alt Tow, 80 Econo ),3"DP,4" Exhaust,Tymar Intake,Full gauges. Intercooled. ATS Turbo.
Allister73 is offline
Old 10-01-2006, 04:58 PM   #12 (permalink)
Thanks for the feed back guys I have been reading the forums there seems to be some for some against whats the average cost on tonys burn for 6 postion on average.
roland is offline
Old 10-01-2006, 06:06 PM   #13 (permalink)
[img]/ubbthreads/images/graemlins/confused.gif[/img] [img]/ubbthreads/images/graemlins/vulnerable.gif[/img]
Cary
2006 Yamaha FJR1300
caryt is offline
Old 10-01-2006, 08:54 PM   #14 (permalink)
I doubt you'll find much against Tony's chips. Just my opinion but a 6 pos chip is overkill for a OBS powerstroke with stock injectors. 4 is plenty in my opinion ...... I mostly use only 2 pos. on mine.
1994 F-250 PSD ext cab 5spd 4x4 Gutted ebpv ,Valeo smf and clutch,3 pos Tony Wildman chip!, 3-4" Dp, 4" exhaust,Tymar intake, shimmed fpr, HPX crossover, 1.0 A/R exhaust housing, vdo gauges, 279,000k
http://community.webshots.com/album/549770704UdvVUs
1996 F-250 PSD CC SB 4x4, 5spd, 4:10's SMF clutch, 3" dp, gauges, 6oh intercooler(GTS Kit), Tymar intake, HPX, .84a/r housing, 203* stat, 4pos Wildman chip!
ltfox is offline
Old 10-01-2006, 09:16 PM   #15 (permalink)
Nothin wrong with a 6 POS for a stock psd. You could have no start, high idle, Daily Driver, Tow, Econo, Extreme Just a suggestion. Its all preference.
Truck pics
» Network Links
