yet more zf swap questions - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 11-16-2009, 12:17 AM   #1 (permalink)
91diesel's Avatar
Send a message via AIM to 91diesel Send a message via MSN to 91diesel
Im doing my 5 spd swap at the end of next week. Im just thinking about the cruise control..I know i need to get a new computer/get it reflashed. But how will the computer know to idle the motor when i push the clutch or when i take it out of gear?
Does it assume that if you take it out of gear, you have pushed the clutch?
Also, for my 97, what safety switch do i need for the pedal?
thanks!
1997 F-350, XLT, dually, crew cab, 4x4, 7.3 PSD, zf-5 speed, Autometer Pyro and boost, DpTuner F5, 3.5"DP , B+W turnover goosneck hitch, 2wd to dana 60 swap
http://community.webshots.com/user/91diesel
18.9MPG
91diesel is offline
Old 11-16-2009, 12:26 AM   #2 (permalink)
My Photos: (60)
There is a switch on the clutch pedal just like on the brake pedal (you will have to add it as part of your conversion).
As for safety switch on the pedal are you talking brake or clutch pedal? They both have one on a manual tranny.
THANK YOU to all the heroes in our military and all the heroes at home who wait for their safe return. I am humbled by and grateful for your service and sacrifice.
LINK TO LIST OF THE FALLEN
'95 F250 ext cab long bed, PSD, 5 speed, 2 wheel drive, 3.55 gears, 286,000 miles, Edge Evolution CTS (LINK TO MY REVIEW), LUK clutch, homemade REAR BUMPER, open element AIR FILTER, 36" ARE contractor cap. With tools, full of fuel and me on board (300 lbs) steer 3620, drive 3860 total 7480.
Believer45 is offline
Old 11-20-2009, 06:57 AM   #3 (permalink)
91diesel's Avatar
clutch pedal. How does it know when to shut the cruise control off i mean? I thought the clutch switch only opened when the pedal was all the way down for starting.
Do you have a p/n for what i need? thanks
18.9MPG
91diesel is offline
Old 11-22-2009, 07:15 PM   #4 (permalink)
I am in the process of doing this swap right now, as far as I can tell the switch for the clutch is built into the Master cylinder. The wires that plug into the master cylinder are already under the dash with a cover on them. I will let you know what I find when I get it finished this week or next.
1995 250 XLT BlackRegCab4x4,5 Speed,3.54,D66, stage 1's, BTS Chip, tymar intake, glow plug mod, shimmed FPR,gauges, 3" into 4" stock exit. Dana 60, idm mod 241K.
jwaltblue is offline
