Old 10-17-2006, 02:32 PM   #1 (permalink)
ZF man. trans.
I was told that the first 7.3's came with a different 5-spd than the later powerstroke tansmissions which were built heavier. Is this true? What are the different model #'s? What years did they switch? On the 5 and 6-spds is there any difference other than bell housing on the gas and diesel transmissions?
warwagon82 is offline
Old 10-17-2006, 08:08 PM   #2 (permalink)
Re: ZF man. trans.
I'm no expert, but I've read the 94 and 95 models had the ZF-42 which is rated at 420 ft-lbs of input torque. The later models had the ZF-47 which is rated at 470 ft-lbs of input torque. I believe the two transmissions are dimensionally the same, and either would bolt right up...but don't quote me!!
However, the 6 speed doesn't interchange at all with the 5 speed if I have interpreted other people's comments correctly. (different splines/size of input shaft?)
Again, I'm no expert, but nobody else answered your question, so I figured I'd try.
'94 F250 supercab 4x4, original owner, 4.10LS, shimmed FPR, Tymar air intake, DP Tuners 80 Econo burn, VDO gauges (boost,pyro, outside temp), Ford digital AIC, DPPI downpipe, gutted EBPV, add-a-leafs front and rear, Monroe Reflex shocks, Milemarker 449SS hubs, towing 25' Mallard travel trailer
nashvillebill is offline
Old 10-17-2006, 08:43 PM   #3 (permalink)
PSDfreak's Avatar
Re: ZF man. trans.
Sounds about right to me [img]/ubbthreads/images/graemlins/wink.gif[/img]
-Casey
1997 F-250HD SuperCab●4x4●ZF-5●4.10●Tymar Intake●Tymar HPX●Wildman 3 Pos. Chip (Econo/Tow/Xtreme)●SD Intercooler●17* HPOP●4” Straight Pipe w/5” Silverline Tip●3-Pillar Zeries Gauges (Pyro/Boost/Oil Temp)●LuK SMFW●4” Rancho Suspension Lift●Ride Rite Rear Bags●Bilstein 5100 Shocks●Rancho Stabalizer●Energy Poly Bushings●Hella 550’s●Line-X●315/75/R16 BFG A/T●Pro Comp XTreme Wheels●Diamond Plate Rails, Gate, & Bulkhead●Ford AIC ●Cobra 25 w/ Wilson 1000 Ant. & RK-56 Mic●Sirius Sat. Radio●
PSDfreak is offline
Old 10-18-2006, 12:37 AM   #4 (permalink)
Re: ZF man. trans.
The ZF6 CAN be put in our trucks, but you need to modify such things as the trans crossmember, and there is some wiring IIRC.
Dave
Smokyred- RED 11/97 F250HD XLT SCLB Auto 4.10LS 4x4 OFFROAD Powered By 2L Motorsports and SWAMPS.
Mods: AM Ultra-Lites, DiPricol HPOP gauge,TS/2L Moto Chip, 4" Straight-Piped, Poor boy's intake, Swamps II's, BTS, 285 BFG A/T's on factory Alcoas. Lots more to install, see below!
On the bench: AirFlo S400, Swamps 275's, Studs Rods and Springs for the top end, and some other stuff.
My Pictures
DD- SILVER 11/97 F350HD XLT RCLB Auto 3.55LS 4x4 OFFROAD
Mods: Redneck straight-pipe, TS/2L Moto chip.
smokyred is offline
Old 10-27-2006, 03:17 PM   #5 (permalink)
Re: ZF man. trans.
What about the 5-spds from the late 80's? Gas and diesel trans the same or different.
Old 10-27-2006, 05:47 PM   #6 (permalink)
Re: ZF man. trans.
The gas bellhousing is a different bolt pattern than the diesel. You can use an early diesel 5 speed. It is the same as the early Powerstroke 5 speed.
Tim
"Better to be hated for who you are, than loved for who you're not." - Van Zant
My Truck 1972 F-350 4x4 Extended cab 14-36 Swampers, 97 Powerstroke, 4 position chip with custom tunes, 3" downpipe, 5" exhaust, 99 intercooler, DIY E-fuel, Dana 60 front, 70 rear, lockers in both ends.
<font color="blue">72 POWER STROKE</font> <font color="red"> INTERIOR PICTURE </font> <font color="blue"> ENGINE PICTURE </font>
Wifes' Grocery Getter 99 F-250 SD 4x4 XLT Lariat 4 door. 7.3, Auto, 4 pos Bullydog chip, 3 1/2" downpipe, 5" straightpipe, Genuine Tymar, Stage 1 Monsterbox, 33-12.50-16.5's
72Pstroke is offline
Old 10-29-2006, 06:12 PM   #7 (permalink)
Re: ZF man. trans.
So, the ZF-42 was the first 5-spd. Then in about 95/96 they switched to the ZF-47. Was the switch also for gas engine trans? Are there any internal differences between the gas and diesel trans? What about the gas and diesel 6-spds? Are they the same internally add what are their model numbers?
Old 10-30-2006, 07:28 AM   #8 (permalink)
My Photos: (5)
Re: ZF man. trans.
In general, Gas and diesel transmissions do not interchange.
The diesel and Gas engines have very different torque and rpm characteristics, usually the gear trains are very different in terms of ratio's - diesels make as much torque at idle as many gas engines do at peak tq rpm ;-) but diesels are redlined out by 3500 or so... where a gas engine will wind up to 5500-6000 depending on application.
Belleville, MI (Detroit / Ann Arbor)
'97 F250 4x4 7.3PSD ZF5spd 4L10
PA2818 diy intake, wicked wheel diy turbo rebuild, .84 turbo housing, no muffler, I LOVE MY BEANS TS'ers! ;-), new pedal box bushings, Fleetgaurd coolant filter, Seat Mod, electric fan, Eagle 16x8 w/265 75 Firestone Steeltex AT, cooling pkg front bumper
'69 Mustang 428CJ(ongoing project)
'99 escort zx2 commuter
'86 Supra classic ski boat 351W PCM power
'54 Belair sedan, all original
milner351 is offline
Old 10-31-2006, 12:04 AM   #9 (permalink)
Re: ZF man. trans.
The diesel and Gas engines have very different torque and rpm characteristics, usually the gear trains are very different in terms of ratio's - diesels make as much torque at idle as many gas engines do at peak tq rpm ;-) but diesels are redlined out by 3500 or so... where a gas engine will wind up to 5500-6000 depending on application. [/quote
I know they can't be interchanged because of the bolt patterns, but does ZF actually make any differences in the internal gear ratios of their 5 and 6spds?
Old 10-31-2006, 09:18 AM   #10 (permalink)
My Photos: (5)
Re: ZF man. trans.
the gear ratios for a diesel and gas are not the same as far as I know....
Old 11-12-2006, 07:43 PM   #11 (permalink)
Re: ZF man. trans.
So if the 5spds were the ZF-42 and ZF-47 what are the 6spd model number(s)?
Old 11-13-2006, 03:55 AM   #12 (permalink)
klhansen's Avatar
My Photos: (92)
Re: ZF man. trans.
The 6-spd used in the 99 &amp; up trucks is a ZF S6-650 rated at 650 nm (~535 ft-lb) input torque.
The 99&amp; up gassers still use the ZF S5-47 5-spd, which is rated at 470 nm (~385 ft-lb) input torque.
99.5 F250 PSD Supercab LB 4x4, 6spd, 3.73LS, Boost & pyro gauges, Swamps S175/146 injectors, Jody's 80 HP Econo PCM (classic version), AIS, coolant filter w/"hokum" bracket, regulated return, heated mirror mod, lighted cupholder, Marinco heater plug-in.
Hard or no-start? Check here
klhansen is offline
Old 11-13-2006, 08:30 PM   #13 (permalink)
Re: ZF man. trans.
There is a nice ratio chart on US Gear's site for the overdrive.....
I frankly like the ZF42 for normal driving because 1st gear is higher and actually useful to take off. But for very HD use the 47 first gear ratio is lower. I don't care because if I'm in that tight of a place I'll put the transfer case in low range to take the stress off of the clutch.
I havent heard of anyone breaking the ZF42 in a high perf truck.
Diesel Mechanic 28 yrs
Garbage_Mechanic is offline
Old 11-21-2006, 11:18 PM   #14 (permalink)
Re: ZF man. trans.
I have a 95 with 5 spd. Can the 99 and up 6 speeds bolt right up to mine? Will this drop my rpm down at all, or just spread the shifts out a little? I want to drop 200-300 rpm on highway.
shannon80 is offline
Old 11-21-2006, 11:27 PM   #15 (permalink)
Re: ZF man. trans.
The 6 sp in my 99 has nearly the same top gear ratio. 5sp in my 96 was .77:1 for OD, and 6th in 99 is .72:1. Low is also the same at 5.??:1. They are just closer together in the 6sp. I do not know about fitment. [img]/ubbthreads/images/graemlins/wink.gif[/img]
Me + Wife + 3 Rugrats + 1 German Sheherd (The Sheriff) = 1 Crew Cab Full
Early 99 2wd Crew Cab SRW 6MT
FPR Shim and 6637 Mod
jbawilliams is offline
