Old 10-01-2007, 07:30 AM   #1 (permalink)
Supporting Member
4door96's Avatar
zf5 to automatic question
I want to change my truck to an automatic, if I got the wiring, tranny and the pcm, what else would I need to do for this to work?
1996 f350 2wd dulley, 7.3psd, 190k, 5 speed, 3" down pipe,5" exhaust pipe no restrictions, edge evolution programmer, stage 1 injectors, k&n air, and gauges.
4door96 is offline
Old 10-01-2007, 11:46 AM   #2 (permalink)
RSP
My Photos: (17)
Re: zf5 to automatic question
If it was me I would buy a PCS controller, That way you can program the trans to do what you want it to do Not what Ford wanted.
2006 F250 CrewCab Lariat FX4 6.OH AFE, MBRP SS Cool Duals, Elite SCT, 4 Up the pillar, Bed Rug and Retrax Lockable cover.
1997 F350 CrewCab XLT 4x4. ?hp/?lb-ft Intercooled, BTS Trans, BTS Dual HPOP, Big Full Force Diesel Jectors, Big Turbo, Ford AIC, Rockin S Custom 5 inch Exhaust w/AeroTurbine Muffler, AFE Stage II Intake, Total Diesel Performance 4 Positon Chip, White Face Gauges,
1979 F250 SC Lariat 4X4 5.9 CTD, BTS E40D, Dana 60/Sterling 10.25, SD HydroBoost brakes, 440HP 992lb-ft, Intercooled, BFG All Terrains on Eagle Alloy 102s. Custom Rockin S Dual stack Exhaust system. DDP Stage IV injectors, HTB2 Turbo, Snow Water/Meth injection
My Webshots page
RSP is offline
Old 10-01-2007, 02:33 PM   #3 (permalink)
A steering column.
http://www.brianstruckshop.com/conversion.html
Pics are from a SD, but the main points are still the same. Oh, and they can do it for you.
Cale also does tuning.
'96 F250 XLT, PSD, 4x4, ExtCab, LB, Auto, 3.55.
11-06: DIY Open Element, EBPV & TC exhaust brake.
02-07: 40 gal '05 F550 aft-axle tank = ~60 gal total.
03-07:DIY/RDS stage 1's, 220,356mi, BTS downpipe & 6pos chip.
04-07: 226,000mi 277HP, 543TQ, Graph
05-07: EGT, Boost, Trans from Tymar
06-07: 4" exhaust, 31 row 6.0L trans cooler
08-07: BTS Transmission.
09-07: 80.76 @ 16.527
My picture & diagrams
danjreed is offline
Old 10-01-2007, 07:56 PM   #4 (permalink)
Send a message via AIM to bamboo
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Rockin_S</div><div class="ubbcode-body">If it was me I would buy a PCS controller, That way you can program the trans to do what you want it to do Not what Ford wanted. </div></div>
A PCS controller for a zf5 ? or for the auto.. I also have a zf5 and was hoping for a short shift kit, or switching to an auto so i can race, and get semi good times maybe..
1996 F250 X-cab SB, zf-5, open element intake, tymar 3-4" DP, 4inch dual DE exhuast,gutted EBPV,MidWest Shortshift kit, DP-tuner chip,Gauges,
sounds, with a bunch of rammat and ensolite in the cab.
1997 f250 longbed xcab,zf-5, 4inch lift with 18 inch wheels and mickey thompsons
Motor all stock for now..
1994 f250 with a custom dump/flatbed heavy duty winch up front, 7.3 idi, None turbo...
bamboo is offline
Old 10-01-2007, 08:07 PM   #5 (permalink)
Supporting Member
4door96's Avatar
cool thanks for the answers guys
4door96 is offline
Old 10-01-2007, 10:49 PM   #6 (permalink)
Fordpowrstroke73's Avatar
My Photos: (6)
Send a message via AIM to Fordpowrstroke73
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: bamboo</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Rockin_S</div><div class="ubbcode-body">If it was me I would buy a PCS controller, That way you can program the trans to do what you want it to do Not what Ford wanted. </div></div>
A PCS controller for a zf5 ? or for the auto.. I also have a zf5 and was hoping for a short shift kit, or switching to an auto so i can race, and get semi good times maybe.. </div></div>
Get a PCS controller for the E40D.
'95 Ford F-350, CC,4x4, 7.3 Powerstroke,RDS Stage 1's,Tony Wildman 6 position chip,3.55LS,modded IDM(Thanks Dan),3" downpipe-5" mitre cuts,ebpv gutted, 6" tip,Napa 6637 air filter,Autometer ultra lite triple pillar gauges,Dana 60,Rancho RS 5000 schocks,E40D junk trans,,Aluminum tool box with 7 LED's, headache rack,bed protectors,Hayden Trans. Cooler,Custom Homemade SD Stainless Steel Nerf Bars,285/75/16 BFG All Terrains on Factory Alcoa's,'02 SD Intercooler with homemade IC pipes,Gooseneck hitch
Fordpowrstroke73 is offline
Old 10-02-2007, 01:37 AM   #7 (permalink)
BDS
It's ashame you are so far away...I would gladly swap my auto in my 97' with your manual. I really don't want a ZF but I would doa swap with you just to get the pedals and linkage and crap I need for a manual.
Brent.
96' F350 XLT C/C PSD 4X4 LWB-Green...His, SOLD IT, Stupid Move, Found Another!
97' F350 XLT C/C PSD(for now) 4X4 LWB-White...His
01' Excursion PSD 4X4 Limited...Hers
Trucks
Sled Pull
BDS is offline
Old 10-02-2007, 01:50 AM   #8 (permalink)
RSP
My Photos: (17)
What would you use if you really dont want a ZF?
My Webshots page
RSP is offline
Old 10-02-2007, 02:46 AM   #9 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 4door96</div><div class="ubbcode-body">I want to change my truck to an automatic, if I got the wiring, tranny and the pcm, what else would I need to do for this to work? </div></div>
<span style='font-size: 14pt'>Check on the cross member and drive shaft(s).
Another option is to have your pcm flashed for an automatic. Install a shift kit or VB and programming. It can be chipped with the flash or compatable chip/programming that works with the V B changes. I like the mechanical change to make the tranny last and shift. A controller can't improve control circuits that a mechanical change can.</span>-
The Racer X Built E4OD THAT CAN Video. 1997 F-350 7.3 Twin Turboed Power Stroke Diesel. Fueled with 473 + cc's of Diesel and nitrous!
Family owned & sponsored by : FloridaNorth
For Fuel - D.J. @ DIY-injectors.com
"AMERICAN INGENUITY " Half of AMERICAN is I CAN."
Racer_X is offline
Old 10-03-2007, 09:20 AM   #10 (permalink)
BDS
I'm going to a Cummins in my 97' So I was planning on using a beefed up NV4500.
Brent.
Trucks
Sled Pull
BDS is offline
» Sponsor Links
»Garage Storage and Cabinets
