Hi all. I haven't been here for awhile. Other matters more urgent has kept me away. Now that I am back I have a ?. I have been searching the internet for information about converting from rear drum to disc brakes on the truck in my sig. A link was given on another site to The Diesel Stop and said the link contained suppliers for Sterling parts and some conversion info. The link was a dead end and using the search feature here has proved useless. Can someone point me in the right direction?
Kywookie
3 X 06 Ford F250s 6.0 stock 4X4, just got two more, so now 5!
2003 Ford F250 4" Lift, Chipped, 4X4, Diamond Box
2000 Ford F250 7.3 PSD, 4X4, Stock
1999 Ford F350 7.3 PSD, SRW, 4X4, Chipped
1994 Ford F250 7.3 IDIT, 4X4, Pump cranked way up, fuel milage down way low, 6 inch lift on 315/75r16, still rides like a caddy for its day.
And I grow asparagus.
Thanks for the links guys. I have found lots of info, but the thing that has me puzzled is this: It seems the 96 E350 van w/7.5l came with rear disc brakes. Some have used the rotors from this application, but I have only seen one small mention of using the dual piston calipers from it. It seems that this would be a straight bolt on if one got the brackets to go with it. Most seem to advocate using the front caliper from a 76 to 78 Cadillac Eldorado. I would like to have more info from anyone who has used the E350 parts.
Kywookie
It seems that the E350 has a Dana 60/61 axle in it. The rotor and calipers can be used, but you still must fabricate caliper mounting brackets.
Kywookie
Kywookie
Could the whole rear axle housing with disc brakes and all be swapped into a truck? Do trucks and vans have the same width rear-end?
Kywookie
I doubt the width is the same.
One other item I discovered. After a few emails with the guy that used all Ford parts off the 96 van I found out that the e-brake setup is integral to the mounting brackets and not the caliper. What this means is you must find a complete donor axle or try to source 2 brackets for each side from Ford in addition to fabricating the bracket that replaces the existing drum brake flange. I intend to go to the Ford dealer this morning to see what I can find out concerning availability and pricing. I'm beginning to lean more toward the Eldorado caliper approach, unless the Ford brackets are reasonably priced, and we all know how unlikely that is.
Kywookie
As long as a van & truck rear end is the same overall width, you could cut off the van spring perches and weld new ones on in the right location for the truck leaf springs. That seems much easier to me.
