Tranfer Case
My gasser plow truck had the same problem. The shifter fork was worn out. the oil pump had set up and spun inside the case. All the other ranges don't use that fork, therefore they don't have a problem. These T-cases are fairly cheap on Craigs list.
Jim. My Second 94 F250 XLT,4X4,Ext. Cab,7.3 I.D.I Factory Turbo, 4.10 Limited Slip, E4OD, K&N, Pyro, Boost and Tranny temp Gauges,Tekonsha Defender Tranny Cooler,B&M Shift +,Home Grown Glow Plug Saver and Headlight "Bright Box", Banks Stinger Exhaust, Powershot 2000 LPG, Cooper 33's on Aluminum rims, DeLorme GPS on the Laptop.
