1977 F150 w/a Cummins. Have a transmission question (C6)
(moved this thread here)
Hey all,
Have a question, tried the search but came up dry. C6 doesen't have three or more characters. Wasn't sure where to put this cause it's a little different but here it goes anyway.
I am putting a Cummins 4BT into my old '77 F-150. I have a C6 automatic. Previous engine was a 429. I'm using an adaptor kit from fordcummins dot com out of Montana. So far so good.
Anyone have any recommendations on what to do with the vacuum signal? What I'm planning on doing is going to a full manual valve body (from BTE), thus eliminating the need for a vacuum signal for shift points and leaving the vacuum modulator on the transmission there with the line open to the atmosphere giving it the impression of WOT all the time (no vacuum) rather than try to rig up some contraption or other.
Is there any negative consequence to doing this? There aren't a whole lot of options out there for what I'm doing. I've checked all over the net, and over at 4btswaps dot com and nobody seems to have a clue.
Any input from a knowledgable C6 guy would be appreciated. Thanks!
