Re: 1988 f250 7.3 IDI 4x4-cranks-NO START!!
Check and make sure you have power (12 volts) at injection pump with key turned on. I think there are two wires at the injection pump one should be hot with the key on, turn key off nothing there. If you have air in the system it can be a bugger to get started. Keep bleeding and make sure you have all the air out. If you have bad battery cables and are not getting enough power to your starter so the motor turns over fast enough it will not start. Are your glow plugs working? Make sure you are getting a good volume of fuel at the filter or injection pump.
Good Luck, Greg
1988 F250 7.3 diesel 4x4 auto C6 now ZF5
1990 F250 7.3 diesel 4x4 auto E4OD. now ZF5
1992 F250 7.3 diesel 4x4 ZF5
