1990 5 spd
Hello , I am looking at a 1990 5spd 7.3 reg cab F-250. I liked what I saw but the guy says the truck won`t go into reverse unless the truck is off.He says his mechanic could remove some air "somewheres"and it would be better. Also, when I went to start, I had to push the clutch way down to the point that I thought I would put my foot thru the floor board.He says he thinks its a switch. Any help would be appreciated.Rob
1992 F-250 7.3 IDI 2wd Auto 156000 miles
Blended user w/rear tank/Front tank reg-diesel.
DSE Blend in rear tank.
20 gal WVO/2 gal kero/1 gal gas/15 oz. Diesel kleen/3.5 oz. DSE Used Blend from 144,000 miles. Sold , but a friend has it,so I will keep it in signature.
1988 F-250 7.3 IDI 4wd non turbo c6 auto crew cab. w/ 136500
Blended DSE fuel in rear tank.Started 2-25-08 @ 132000 miles.Changed O-rings,rubber fuel lines,cleaned injectors,changed fuel and air filter.Changed Wiper motor 4-4-08.Cleaned injectors again 10-1-08 136000 miles.11-4-08-Changed all fuel line clamps and glow plugs(Wellman)
1991 F-250 7.3 IDI 2wd non-turbo,E4OD,181,000 miles.Started DSE blend in front tank 11-14-08.Changed air filter, injector to injector line fuel hoses from 5/16 to 1/4".Was a truck of a fleet manager of an oil company.Has a tommygate lift.All service records from 1991!
