1990 F350 No overdrive and no tachometer - Diesel Forum - TheDieselStop.com
post #1 of 10 (permalink) Old 10-10-2007, 08:18 PM Thread Starter
Hi All,
My tach is not working (stuck at 0) and Overdrive OFF light is constantly on (switch on dash). I cleaned up the switch and wiring harness in dash but no help. I also check all my fuses and they are good. Anyone have any suggestions as to where to start troubleshooting? Also which OBD1 reader would you suggest for this truck? Thanks.
2004 Chevy Silverado LLY
2003 E-450 Bus
mikedean is offline
post #2 of 10 (permalink) Old 10-11-2007, 01:21 AM
cdnsarguy's Avatar
My Photos: (109)
re: 1990 F350 No overdrive and no tachometer
A dead tach sender should/would send the automatic trans into a "failure management mode" (limp mode) with harsh engagements and firm shift feel and an abnormal shift schedule. It has no effect on a manual trans only the Tach readings.
Check the wires where they exit the big nut on the oil filler housing , known to short out due to bare wire.....
Replace the tach sender on the oil fill housing a big 1" nut with 2 wires. Ford only part Engine RPM sensor E5TZ-17B384-A about $50. You can remove and clean it but usually changed later too.
You can test it too, hold it in the air away from ferrous metal, using an ohm meter lead on each wire you need DC resistance between 2000-3000 ohms.
Proud Canadian BOOB man too!!
cdnsarguy is offline
post #3 of 10 (permalink) Old 10-11-2007, 04:29 PM
7.3L F-250's Avatar
My Photos: (16)
Send a message via AIM to 7.3L F-250
we had the same problem on my dads truck
it can be a sensor in the transmission
or the tack sensor it self
the computer
a relay
or a problem with one of the wires
company trucks
2002 ford F-350 powerstroke cc sb zf-6
1987 ford F-350 6.9L idi flat bed
1989 ford F-350 7.3L idi pick up
CURRENT PROJECTS
1978 ford F-350 custom
7.3L F-250 is offline
post #4 of 10 (permalink) Old 01-21-2015, 01:59 PM
1990 7.3D E4OD Trans Problem
My 1990 F-350 7.3 has a intermittent tach working. It doesn't work until about a half hour of driving. When it isn't working, the transmission goes into limp mode. When the tach starts working everything is fine. I have replaced the tach sensor and still have the same problem.
Any ideas?
HawksFan67 is offline
post #5 of 10 (permalink) Old 01-21-2015, 02:13 PM
Mark Kovalsky's Avatar
My Photos: (6)
The problem is most likely in the wire between the tach sensor and the computer. Often the easiest way to fix this is to just run a new wire.
Mark
Former
Automatic Transmission Engineer 1988-2007
Mark Kovalsky is offline
post #6 of 10 (permalink) Old 01-22-2015, 07:03 AM
Octer20's Avatar
like Mark said the wire is likely broken.
Mine broke right where the two wires come out of the harness and go to the sensor. The two ends of the broken wire were close enough that it would be intermittent like you're describing.
It was easy to see once I looked for it. I just spliced in a short piece of wire with a nice loop so it could flex and not break again.
94 E350 7.3idi, E40D, 4.10's, dually, uhaul turned camper/toy hauler, F-350 gauge clusther w/tach and modified oil pressure gauge
Hypermax Pulse turbo kit, cowl induction hood scoop, 3.5" exhaust and boost/pyro gauge, IP turned up 3 flats, Transgo HD2 shift kit
Octer20 is offline
post #7 of 10 (permalink) Old 01-22-2015, 10:07 AM
But doesn't it sound like a moisture problem?
post #8 of 10 (permalink) Old 01-27-2015, 10:04 AM
Same component different problem.
My tach works most of the time, almost always at an idle it will drop to zero. Revving the the engine always re-activates it but sometimes I can also turn the headlights on or touch the brake pedal and it starts working. On one occasion it was erratic while running down the highway for a short distance kicking it in and out of over drive. I have tried different tach sensors. I am thinking corrosion somewhere. This problem started 5 years ago right before I parked it. It has been sitting for 5 years but as my '06 was stolen (see signature)I have to use this rig until I get back to work. Going back through all the connections again today but I can not find my wiring diagrams for pin assignments. Can anybody help with the pin assignments.
'06 F250 Crewcab King Ranch 4X4 auto Black 6.0 stolen 12/31/14
by clifford bledsoe.
'09 Cameo 5thwheel home while working
'02 Eddie Expedition
'91 F250 SuperCab 4X4 Stock IDI 2 tone brown E4OD
'96 IH 7.3 4700LP field mechanic
'84 Bronco II 2.8 4 speed 4X4
'50 F-1 V8 Flathead 4-speed non syncro(bought new)
'76 Honda 250 Multi Sport(enduro)
'76 F250 4x4 standard 360 Highboy
mont91 is offline
post #9 of 10 (permalink) Old 01-27-2015, 10:53 PM
hawkrod's Avatar
I have same problem, what wire would best to splice into to run the new wire
hawkrod is offline
post #10 of 10 (permalink) Old 01-28-2015, 05:20 AM
standerd I use on auto motive is no smaller then 16 guage, for a vss it should be twisted, how many twists per inch you'd need to look it up or measur the current signal wire
New truck: 1988 F-350 1 ton dualy 2*4, 7.3L IDI Naturally Aspirated, Dual tanks with Camper package.
Mods: Enhanced gauge cluster; Transmission temp, rear diff temp, coolant system pressure, Vacuum pressure, Fuel pressure, Crappy tire Air horn Kit, Raycor pre filter/water sep. All LED Dash lighting, Parker LFS tranny filter, super duty tranny cooler, gerret turbo, waste gated (pending).
Xeonpony is offline
