Old 10-12-2008, 08:03 PM   #1 (permalink)
1991 f250 with 7.3 & 4speed od tranny(automatic)
bought a f250 last week with the 7.3 and automatic with od transmission got it home it wouldent go in reverse so i was reading in the fourm aboult cleaning the plug ins on the transmission well i did that and when i was done it had reverse but acted like it was trying to take off in 2nd gear so i done some more reading and recleaned the plugs again and took the positive cables off 15 min. well it worked like a champ for aboult an hour and then it got stuck in 1st gear and wouldent shift but it only for a few minutes then it went back to work like it should i kinda lost with this thing?
crackerjack is offline
Old 10-12-2008, 09:18 PM   #2 (permalink)
cdnsarguy's Avatar
My Photos: (74)
Can you get the codes checked at azone...... Do the speedo and tach work correctly.....
Proud Canadian BOOB man too!!
cdnsarguy is offline
Old 10-12-2008, 09:24 PM   #3 (permalink)
chuckster57's Avatar
I remember reading a post last month or two where the "post"er said that AZ won't do them any more cause of a lawsuit alledging (sp) loss of income. Here is a link to pull codes:
Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
1994 F-350 7.3 IDI Turbo, crew cab, E4OD, LB, Dually, Photos
1997 Jayco fifth wheel 323 RKS, Robins 16K dual axis hitch
Apillar pod with: Autometer C2 Series gauges: pyro,trans, boost
Hypermax Cowl induction, Flex-A-Lite 26K tranny cooler w/fan
K&N air filter (we'll see in a million miles)
Tekonsha "prodigy" brake control
Train Horns: Pictures here
chuckster57 is online now
Old 10-13-2008, 04:39 PM   #4 (permalink)
I used to have an 86 Ford F250 with the 6.9 diesel.
My truck had a vacuum leak from the vacuum line coming from the Injector Pump, and it was nearly impossible to shift. Once I got that figured out, it ran great.
Not sure if the 91 7.3 has a vacuum-controlled shift sequence in the tranny, but that's just my experience with a slightly older truck.
Good luck!
JoeVR5 is offline
Old 10-13-2008, 05:18 PM   #5 (permalink)
M.L.S.C.'s Avatar
Joe, the E4OD is an electronic deal, but uses the same input as the C6 you worked with - the C6 has a VRV on the side of the IP, the E4OD has a FIPL (TPS), one adjusts a vacuum signal and the other electric signal. If there's something wrong with the FIPL trans will act up.
The more I drink, the more I drink, the more I drink...
'90 F350 XLT Lariat, reg cab, dually, 4.10s, factory tow package, Chevy hydroboost conversion, P3 brake controller - now Back in Black!
M.L.S.C. is offline
Old 10-13-2008, 08:30 PM   #6 (permalink)
i drove it a little today and it works perfect? ill try and scan it tommorrpw and see if it has any codes almost for got the tach and speedo work fine
Old 10-15-2008, 10:48 AM   #7 (permalink)
Ah, thanks for clearing that up.
Sorry I gave some bad advice
I didn't realize that my E4od was not controlled by the vacuum. I've never had to mess with mine yet. I guess you learn something new every day.
Thanks.
JoeVR5 is offline
Old 10-18-2008, 02:13 PM   #8 (permalink)
read the codes today they are 62 & 23
Old 10-18-2008, 02:15 PM   #9 (permalink)
You can see the codes here:
Old 10-19-2008, 01:43 AM   #10 (permalink)
M.L.S.C.'s Avatar
62 seems to be a common one, the converter lockup failure, not good. However, FIPL being out of range (code #23) - did you have the pedal to the floor when pulling the codes? You have to, else you end up with wrong diagnostics.
M.L.S.C. is offline
Old 10-19-2008, 09:32 AM   #11 (permalink)
I did not have the pedel to the floor when I read the codes,guess i better go try it again.
Old 10-19-2008, 02:01 PM   #12 (permalink)
Went out today and hooked the horse trailer to my truck to see how it pull the transmission worked great for about 10 minutes then started to act like it was silpping and then started not shifting. with out load it was working pretty good kinda acts like it dont know what gear it wants to go in?
Old 10-19-2008, 03:51 PM   #13 (permalink)
M.L.S.C.'s Avatar
Dude, pull the codes like you should, who knows what's going on in there... The first thing that comes to mind with that last situation is high temperature, for the first several minutes after startup the ATF is still fairly cool, and it generally stays fairly cool when you ain't towing, but hook up the heavy trailer and it starts heating right up. A code 62 if you indeed have it means your converter ain't locking up right, a slipping converter does generate lotsa heat, which may explain your issue somewhat?
M.L.S.C. is offline
Old 10-20-2008, 06:28 PM   #14 (permalink)
ok pulled the codes today again with the accelerator to the bottom I only get a 62 code
