1992 7.3 cuts off / hard to start afterwards - Diesel Forum - TheDieselStop.com
Old 11-07-2009, 08:44 PM   #1 (permalink)
My truck will idle ruff and cut off sometimes and sometimes going down the road it will start surging and cut off.Either way it is very hard to start after.Have checked vacuum at inlet of supply pump.Has 24 in. supposed to be at least 12 in.. When i took the line loose no fuel ran out.Took line loose at inlet of filter and would not flow any fuel into jug.Took hand vacuum pump and to hose from tank to supply pump to see if i could pull fuel from tank and it took three pumps before any flowed.I feel like it is the supply pump but don't want to waste money if not.Thanks for any help
dragster557 is offline
Old 11-07-2009, 08:45 PM   #2 (permalink)
Snotzalot's Avatar
How full is the fuel tank?
Regards,
Paul - Pocono Mtns. USA
02 E350 15 Passenger, 52,000 Miles
'90 E350 7.3L Ex-Ambulance High Top 400K Miles, No Turbo, Stock Stock stock, No ELC! (Extended Life Coolant) & 10 Oz. Bars Stop Leak, Retired 11/8/2011 with blown trans.
7.3L Alternator Belt Idler Photos
Snotzalot is offline
Old 11-07-2009, 09:04 PM   #3 (permalink)
1/8 of tank.Thanks
Old 11-07-2009, 09:13 PM   #4 (permalink)
Snotzalot's Avatar
Has this just started, or has it happened no matter how full the yank?
Regards,
Old 11-07-2009, 09:14 PM   #5 (permalink)
Just started.Thanks
Old 11-07-2009, 09:23 PM   #6 (permalink)
Could be the fuel pickup in the tank. Keep tank 1/2 full and see if you still have the problem.
How recent has the fuel filter been changed?
If new filter then it sounds like the lift pump.
1994 F250 4X4 w/ 7.3 factory Turbo IDI and a 5 speed, 340K and going good
Living in NW Montana
7bicks is offline
Old 11-07-2009, 09:25 PM   #7 (permalink)
Snotzalot's Avatar
Most likely a broken pickup in the tank. does it do this on the other tank?
Regards,
Old 11-07-2009, 09:27 PM   #8 (permalink)
Steve250's Avatar
Fill it to over half, see what happens. Also, check all electrical connections, ours would cut off in the middle of driving... we found out it was a loose connection.
Our pickup tube is bad also, so we always keep the rear full, but it won't cut off while driving, only if you turn it off and try to turn it back on will it not start.
'92 F-250 7.3 IDI Diesel 4:10 (99k) 4x4 ext cab (Prodigy brake controller)
'98 Ranger 4x4 ext cab - wheelin' in the mud
John Deere 510D Backhoe - it's not a ford, but it's nice
Steve250 is offline
Old 11-08-2009, 02:57 PM   #9 (permalink)
Thanks for everyones help.I put some diesel in the other tank and and vaccum pumped the bleeder on the filter and got it cranked and drove it several miles.So i guess it is the pickup in the other tank.Is it hard to change the pickup.Also,is it normal when you run the rpm's up to the yellow line which is 3400 for it to nose over.Is this the governor.Thanks
