1992 Ford F Super Duty 7.3 IDI fuel system issue. - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 03-24-2013, 09:50 PM Thread Starter
Hi, thank you for reading. Any help would be appreciated.
I recently purchased a 1992 Ford F Super Duty bucket/boom truck with the 7.3 IDI motor in it. When I switch to the rear tank via the dash switch the engine runs for a couple minutes then stalls an refuses to start. Upon switching back to the front tank it cranks fires and runs flawlessly. I have very little experience with Diesel, but I am mechanically inclined.
Thank you for reading, and again, any info that you can offer.
The truck has 210k miles on it, if that means anything.
Buckeyedatajaxllc is offline
post #2 of 6 (permalink) Old 03-24-2013, 09:58 PM
chuckster57's Avatar
Welcome to the Diesel Stop.
Two things come to mind here. Either a sticky tank selector, or a broken pick-up in the rear tank.
How much fuel is in the rear tank? If it has 1/2 tank or more, then more than likely the selector is sticking. They are replaceable, but if I remember right you have to modify the fuel lines to attach them. Some members have succeeded in taking them apart by drilling out the rivets, and using machine screws to put it back together.
Sent from AutoGuide.com App
Train Horns:
PM please not visitor message
chuckster57 is offline
post #3 of 6 (permalink) Old 03-24-2013, 10:11 PM Thread Starter
O
What part am I searching for the switches between tanks? Not the dash switch I'm assuming. Is it a Fuel Pump Relay?
Ok sounds fairly straight forward. I guess my best bet is to replace the tank selector. The rear tank is 100% full. So I'm hoping its te selector. I'll be sure to update when I solve the problem.
post #4 of 6 (permalink) Old 03-24-2013, 10:21 PM
The tank selector is a valve usually mounted on the frame. It has 4 lines I believe, a supply and return for each tank. The internals will move allowing fuel lines to "line up" and let fuel flow/return to the selected tank.
Foreign material can lodge and hinder the full movement of the internals.
Train Horns:
post #5 of 6 (permalink) Old 03-24-2013, 10:27 PM Thread Starter
Sounds like something I can replace in my driveway if I can disconnect it and clean/replace the selector.
post #6 of 6 (permalink) Old 03-24-2013, 10:32 PM
It is an easy repair. As I write this, one other possibility comes to mind. A plugged fuel line from the rear tank. Easy check is to disconnect both the supply and return lines at the selector valve and blow low pressure air through them.
Train Horns:
