Old 12-24-2005, 02:29 AM   #1 (permalink)
1992 manual tranny ?
I just bought a 1992 f350 dually with 5 speed with 156k..Changed my tranny oil, look like 85w-90 was in there..put dextron 111(8qts)back in and did not want to shift right...dained and went back with 85w-90 oil and shifts fine..Shouldn't i be running atf..Can't understand why it didn't work? Were all 1992 tranny's zf's?
mud91 is offline
Old 12-24-2005, 03:37 AM   #2 (permalink)
towcat's Avatar
Re: 1992 manual tranny ?
more info needed.
generally, atf is the norm for a ZF5. if you have 85/90, it is masking a potential problem. Either the synchros are worn out, the bearings are shot, or the plastic tips on the shift forks are wiped from the lack of oil.
86 f250 6.9IDI, 4spd 4X4 "the runt"
89 f450 rollback carrier 7.3IDI, ZF5, 4X2(in memory of...)
90 f450 conventional towtruck 60"CA 7.3IDI, E4OD, 4X2
92 f350 CC 7.3IDI, ATSturbo*intercooled*, ZF5, hydrostop, 4X2 "the nebuchadnezzar"
...Quack Quack................*P.A.K.*...
red pill or the blue pill? make your choice and pm me.
7/03 mini meet pics
towcat is offline
Old 12-24-2005, 03:41 AM   #3 (permalink)
ok i bought superTech dextron 111, is that the same as atf. Some cans say atf and some say dextron 111...whats the difference.
mud91 is offline
Old 12-24-2005, 04:05 AM   #4 (permalink)
towcat's Avatar
It would take a couple of oil changes to clear out all the gear oil, so whatever dexron you are running is going to be contambinated. Do check to make sure your clutch system and your firewall is solid before condemming the trans. There's no doubt that the gear oil is masking a problem, you have to figure out what went wrong.
7/03 mini meet pics
towcat is offline
Old 12-24-2005, 04:26 AM   #5 (permalink)
PSDfreak's Avatar
It shouldn't take 8 qts? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
1997 F-250HD SuperCab●4x4●ZF-5●4.10●Tymar Intake●Tymar HPX●Wildman 3 Pos. Chip (Econo/Tow/Xtreme)●SD Intercooler●17* HPOP●4” Straight Pipe w/5” Silverline Tip●3-Pillar Zeries Gauges (Pyro/Boost/Oil Temp)●LuK SMFW●4” Rancho Suspension Lift●Ride Rite Rear Bags●Bilstein 5100 Shocks●Rancho Stabalizer●Energy Poly Bushings●Hella 550’s●Line-X●315/75/R16 BFG A/T●Pro Comp XTreme Wheels●Diamond Plate Rails, Gate, & Bulkhead●Ford AIC ●Cobra 25 w/ Wilson 1000 Ant. & RK-56 Mic●Sirius Sat. Radio●
PSDfreak is offline
Old 12-24-2005, 04:32 AM   #6 (permalink)
ok, when i bought the truck the guy said he had rebuilt the tranny, could it be the parts he used require the different oil? ..When i drained the oil(dextron) it smelled burned really bad with only about 10miles of driving. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
mud91 is offline
Old 12-24-2005, 05:26 AM   #7 (permalink)
towcat's Avatar
zf parts only comes in one flavor, these are germans we are dealing with here. Suggestion. drain and refill. try to determine if you have syncro, bearing or shift fork issues. chances are you have bearing issues. It is prolly set up too tight.
7/03 mini meet pics
towcat is offline
Old 12-24-2005, 10:20 AM   #8 (permalink)
When my 92 5-speed ZF started going south (210,000 miles), the failure mode was to pop out of reverse unless it was fully, totally, carefully engaged. Finally had it rebuilt before getting to the point where it would not stay in reverse. Not a cheap rebuild, and the mechanic who took it out sent it to a trans shop because it required special tools to disassemble the gear packs, etc.
1992 F250 dually conversion (Arrowcraft), NA Jasper rebuild after 180K, currently 220,000 and running fine, 5 spd, 4.10, mostly stock, stretch cab, a farm working truck which hauls hay on a 25' gooseneck utility trailer.
FarmerSteve is offline
Old 12-24-2005, 11:15 AM   #9 (permalink)
cdnsarguy's Avatar
My Photos: (74)
Some items require specific temperatures applied to install them.
Proud Canadian BOOB man too!!
cdnsarguy is offline
» Sponsor Links
»Garage Storage and Cabinets
