1993 7.3 problems (injector pump?) - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 02-04-2007, 01:19 PM Thread Starter
A friend has a 93 with the Banks turbo, not really modified other than that. It has about 115K miles on it. Just recently, it will cut off when the clutch is pushed in. He says it idles fine, but anytime the clutch is pushed in it will cut off.
Another friend said it is the injector pump? Any info on best place to get one, how hard is it to install one, etc?
Tacoma747 is offline
post #2 of 9 (permalink) Old 02-04-2007, 03:08 PM
Re: 1993 7.3 problems (injector pump?)
No need to replace the pump, the governor ring is just sticking. He needs to run some lubricating diesel additive through it. A little turn up of the idle screw will help until it gets cleared up.
1997 Ford F350 SRW 7.3L PSD
1985 Ford Ranger 2.3L 5 speed
1966 Mustang 200 I6, auto, 4 wheel disk, power brake retrofit, Corvette master.
Former vehicles, 1994 E350 7.3L IDI, 1985 International 1654 rollback, 6.9L IDI, (2) 1994 Ford E350 7.3L IDI, 1985 Ford F350 DRW 6.9L IDI, 1985 Ford F350 wrecker 6.9L IDI.
*dual ASE Master Certified, Automotive, Medium & Heavy trucks*
Owner / operator, Patriot Automotive, N Ridgeville OH
Mr_Roboto is offline
post #3 of 9 (permalink) Old 02-04-2007, 06:21 PM
mrroboto, I am just curious how the clutch relates to this? Do you know?
thanks
1993 Ford IDI 7.3L
F-250
ZF-5 speed 4 wheel drive
Class 5 hitch
D load tires <img src="/ubbthreads/images/graemlins/frown.gif" alt="" />
super cab
18x,xxx miles.
Purchased 9-22-06
luckys420 is offline
post #4 of 9 (permalink) Old 02-04-2007, 06:40 PM
When the clutch is engaged, the trucks' inertia keeps the engine RPM up, even when you are off the throttle. Once you push the clutch in, the IP governor has to give more fuel to keep RPM up. When the governor gets gummed up, it can't react quite fast enough and you get stalling.
My truck does the same thing after I run it low on fuel (even after refilling), it must be sucking crap up from the bottom of the tank.
post #5 of 9 (permalink) Old 02-04-2007, 11:15 PM
ok. great. thanks alot.
1993 Ford IDI 7.3L
F-250
Class 5 hitch
super cab
18x,xxx miles.
Purchased 9-22-06
post #6 of 9 (permalink) Old 02-04-2007, 11:39 PM Thread Starter
Diesel additive you put in the fuel, or somewhere else? Seems it would take awhile if it is the fuel kind since he can't really drive it (guess he could let it sit idle for a long time).
I know nothing about the IDI 7.3's, and to keep me from having too look too much, where exactly is the idle screw at?
Thanks, I am sure he will be very happy if it is not the injector pump.
post #7 of 9 (permalink) Old 02-05-2007, 03:58 AM
cdnsarguy's Avatar
My Photos: (109)
Visit my gallery for pics of the IP.....
Proud Canadian BOOB man too!!
cdnsarguy is offline
post #8 of 9 (permalink) Old 02-05-2007, 02:02 PM
GenLightening's Avatar
Pull the fuel filter and fill it, or a new one, with the additive. Hope it clears it up.
1988 Chevy CC DRW w/a 7.3L IDI w/Banks Turbo
E4OD w/Baumann Transcommand
Racer-X triple disc TC
US Gear Exhaust Brake
4.10 Chevy Diff
GenLightening is offline
post #9 of 9 (permalink) Old 02-05-2007, 08:09 PM Thread Starter
Filled the fuel filter with additive (power source brand), truck sputtered for a little bit, but it runs fine now [img]/ubbthreads/images/graemlins/smile.gif[/img]
I am getting a free dinner out of this deal, saved him $1000 or more on an injector pump, at least for the night that is... I will be sure to update if it fails to KEEP working. I also put the additive in both his fuel tanks, and I bet he keeps using it [img]/ubbthreads/images/graemlins/smile.gif[/img]
Thanks for the help.
