Old 08-02-2008, 03:31 PM   #1 (permalink)
1993 f250 rear brake drum removal
Hey - I'm trying to remove the rear brake drum on my 1993 f250. I've backed off the adjuster and it still won't budge. The local library doesn't have a manual for the truck. but a friend told me the axle has to come out. I thought that was only on older models. Shouldn't the drum come off? What am I missing. Thanks. Larry
lcotelaw is offline
Old 08-02-2008, 03:58 PM   #2 (permalink)
Supporting Member
bugman's Avatar
My Photos: (15)
The drum is probably rusted to the hub along with the wheel studs. Get some liquid wrench and spray the area and hit the drum with a hammer wail a while and then repeat. If you have the shoes backed off enough sooner or later it should come off, and you do not have to remove the axle.
Jim
96 F250 PS XLT 4X4 long box, 5sp,4.10, manual hubs,pyro+boost guages,Dark Toumaline, add a leaf,Dale's TYMAR,and HX hose, downpipe, coolant filter with coolant eye
bugman is online now
Old 08-02-2008, 09:36 PM   #3 (permalink)
Jim:
thanks for the advice. A little more "persuasion" and it came right off.
Larry
lcotelaw is offline
Old 08-02-2008, 11:32 PM   #4 (permalink)
M.L.S.C.'s Avatar
Just a heads-up - dunno why you're removing the drums, but if tis for wheel cylinder replacement and you plan on reusing the drums after all that beating you may end up with a warped drum and nicely pulsating brakes - guess how I know. If you're replacing the drums, disregard all that.
The more I drink, the more I drink, the more I drink...
'90 F350 XLT Lariat, reg cab, dually, 4.10s, factory tow package, Chevy hydroboost conversion, P3 brake controller - now Back in Black!
M.L.S.C. is online now
Old 08-02-2008, 11:59 PM   #5 (permalink)
Yeah - I Kinda figured that - which is why I was a bit gentle to start with. It is to replace a bad wheel cylinder, but it is what is I guess. I'm not going to sweat it. It had to come off. And, now I can move forward. Thanks again.
Larry
lcotelaw is offline
Old 08-03-2008, 01:10 AM   #6 (permalink)
bockhold's Avatar
Send a message via AIM to bockhold
make sure your parkin brake is off. ;-)
Jarrod
NRA member
1997 F350 4door 2wd long bed white 7.3L Powerstroke, E4OD, C5 4:10LS diff 326K miles on org engine
and is being repaired
bockhold is offline
Old 08-04-2008, 12:23 PM   #7 (permalink)
hesutton's Avatar
My Photos: (30)
What am I missing?
A bigger hammer.
Just yank'n your chain. Glad to hear you got it off and got the job done.
Heath
1986 F250HD 4x4 7.3L IDI '95 PSD front clip, '97 bed, T19, D60/10.25 with 3.55's. Rebuilt from the frame up. Banks Turbo, DPS IP & Stage 1's, Isspro TTM, Banks Exhaust, Boost gauge, Pyrometer, Precharged Coolant Filter, Holley Red Pump. 16.5 x 37 x 12.5 Goodyear Wrangler's, Air Horns. 6in lift, Fresh Paint, On-board Air. Revamped Interior. Rhino Liner.
1983 F250 4x4 5.0L with C6. 340,000+ miles.
7.3 Project Pictures
Webshots Project 7.3 Gallery
DYNO YOUR IDI AT THE 2009 RALLY
hesutton is offline
Old 08-04-2008, 03:19 PM   #8 (permalink)
Snotzalot's Avatar
If you hammer on the drum around the center to break it loose it will usually be Ok for reuse. Don't hammer at the edge!
Regards,
Paul - Pocono Mtns. USA '90 E350 7.3L Ex-Ambulance High Top 400K Miles, No Turbo, Stock Stock stock, 10 oz. Bars Stop Leak and No ELC!
7.3L Alternator Belt Idler Photos
Snotzalot is offline
Old 08-04-2008, 08:27 PM   #9 (permalink)
got a air chisel????? if so, get the blunt end adaptor tip--and beat the snot out of the area between the studs---breaks all the rust loose--and drums come right off--older man showed me this--never has failed yet. and please wear ear protection!!!!
94_turbo is offline
Old 08-04-2008, 09:03 PM   #10 (permalink)
88beast's Avatar
ya e brake is not good to be on
had it parked and the person didnt know we were doing a brake job
after wards it slid right off
88 F-250 body,550 rear frame setup, 7.3 idi, 3:73 dana 80 rear, srw, dana 50 front, heavy duty leaf springs, back up camera, 20$ wallyworld fog lamps, class 5 bumper hitch welded to frame and gusseted, brush guard with front mount hitch, 32" steering tires all around, ac power converter,jeep bucket seats, deezee runningboards (cab only),cobra 29 cb w/ 102" whip, 2 trucklight worklights on front stake pocket each side,high lift jack behind seat, toolbox for the junk, visor, running lights, 6600 lbs with all my junk
http://youtube.com/watch?v=ILAQuHNAGE0
i plan to add propane kit, stake body bed, gn hitch,western style mirrors, and a lot more
88beast is offline
» Sponsor Links
»Garage Storage and Cabinets
