Hey - I'm trying to remove the rear brake drum on my 1993 f250. I've backed off the adjuster and it still won't budge. The local library doesn't have a manual for the truck. but a friend told me the axle has to come out. I thought that was only on older models. Shouldn't the drum come off? What am I missing. Thanks. Larry
The drum is probably rusted to the hub along with the wheel studs. Get some liquid wrench and spray the area and hit the drum with a hammer wail a while and then repeat. If you have the shoes backed off enough sooner or later it should come off, and you do not have to remove the axle.
Jim
96 F250 PS XLT 4X4 long box, 5sp,4.10, manual hubs,pyro+boost guages,Dark Toumaline, add a leaf,Dale's TYMAR,and HX hose, downpipe, coolant filter with coolant eye
Just a heads-up - dunno why you're removing the drums, but if tis for wheel cylinder replacement and you plan on reusing the drums after all that beating you may end up with a warped drum and nicely pulsating brakes - guess how I know. If you're replacing the drums, disregard all that.
__________________ The more I drink, the more I drink, the more I drink...
'90 F350 XLT Lariat, reg cab, dually, 4.10s, factory tow package w/ P3 controller, single 3" stack w/ clapper, wood stakes & rails
Yeah - I Kinda figured that - which is why I was a bit gentle to start with. It is to replace a bad wheel cylinder, but it is what is I guess. I'm not going to sweat it. It had to come off. And, now I can move forward. Thanks again.
got a air chisel????? if so, get the blunt end adaptor tip--and beat the snot out of the area between the studs---breaks all the rust loose--and drums come right off--older man showed me this--never has failed yet. and please wear ear protection!!!!
ya e brake is not good to be on
had it parked and the person didnt know we were doing a brake job
after wards it slid right off
88 F-250 body,550 rear frame setup, 7.3 idi, 3:73 dana 80 rear, srw, dana 50 front, heavy duty leaf springs, back up camera, 20$ wallyworld fog lamps, class 5 bumper hitch welded to frame and gusseted, 32" steering tires all around, ac power converter,jeep bucket seats, deezee runningboards (cab only),cobra 29 cb w/ 102" whip, 2 trucklight worklights on front stake pocket each side,high lift jack behind seat, toolbox for the junk, visor, running lights, 6600 lbs with all my junk
i plan to add propane kit, stake body bed, gn hitch,western style mirrors, and a lot more
<span style="color: red">i have created a website for old ford diesels please check it out and tell me what you think</span> http://oldforddiesels.googlepages.com/home
