Old 07-22-2007, 10:42 PM   #1 (permalink)
1993 F250 Turbo - Where to find stock intake and housing?
I just got a 1993 F250 IDI Factory Turbo. The turbo was replaced a year or two ago by previous owner, but he didn't have, or didn't put back, the air intake that goes from the air inlet to the front of the truck.
What's my best bet for finding a replacement for this ?
Thanks,
BD
bdoss123 is offline
Old 07-23-2007, 01:22 AM   #2 (permalink)
Re: 1993 F250 Turbo - Where to find stock intake and housing?
I use the aluminum dryer vent hose from any chain hardware store. You really don't want the standard hose because its really too restrictive. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
icanfixall is offline
Old 07-23-2007, 01:08 PM   #3 (permalink)
Really? How does that fair considering the heat in the engine compartment? Also, if you go that route, how does it mate up to the front end?
- BD
bdoss123 is offline
Old 07-23-2007, 03:05 PM   #4 (permalink)
Look under the drivers side battery. That area is where you form the aluminum vent hose to. Some members even cut out that area for more air. Your right about the hot air in the engine compartment. It doesn't help the motor breath any but if its cold air then it helps. Really the best place for an air induction place would be just below the windshield. That area has plenty of compressed air in it. Thats where NASCAR pulls there air from and yes I know they are running faster but its the same principal on any windshield. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
Old 07-23-2007, 03:54 PM   #5 (permalink)
How does the aluminum hose fair in the hot conditions?
Also what size tube do you use? What's the inlet size??
- BD
bdoss123 is offline
Old 07-23-2007, 07:42 PM   #6 (permalink)
It can handle the underhood heat easily. I have been running it for a few years no. No problems and its easy to make fit around all the differant items.
Old 07-23-2007, 10:49 PM   #7 (permalink)
Is that 3" tubing?
Also did you use a flange of some sort to hold it in place at the front of the vehicle?
- BD
bdoss123 is offline
Old 07-23-2007, 11:29 PM   #8 (permalink)
Are you looking for just the intake tube or the filter housing too? I have both that I'd sell, but won't split them apart since they are already boxed together in my folk's garage 2500 miles away from me. If interested, shoot me a PM.
'91 F250 4x4 SC, ATS 093, ZF-5, GV OD, 4:10's, 3" in, 3" out, AEM Dryflow, 33"s
skimballc is offline
Old 07-24-2007, 02:59 AM   #9 (permalink)
asauer's Avatar
Send a message via MSN to asauer Send a message via Skype™ to asauer
I used 3" PVC pipe to make an intake all the way from the turbo inlet to the cone-type air filter at the other end. Works nicely. Now I just need to make a little box to ensure that only cool air is drawn in, and not underhood air.
I also wrapped the PVC pipe with 'headerwrap' that my buddy got for free from work, and wrapped that with aluminum duct tape to make sure it doesn't unravel. Looks like a giant baked potato under the hood. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
--motor/trans sold--
2000 VW Jetta TDI = 48+mpg
1997 Dodge 3500: 2WD Cab & Chassis, 12V Cummins, 47RE Automatic, Dana 80, 194,000mi. Parting out.
1989 12V VE Cummins out of Chevy C60? at the machine shop...going into the Ford.
Member of Indiana Air National Guard 122FW MXS
asauer is offline
Old 07-24-2007, 10:17 PM   #10 (permalink)
Asauer, any noticeable diff in sound or performance over the stock setup?
- BD
bdoss123 is offline
» Sponsor Links
»Garage Storage and Cabinets
