Old 10-20-2006, 10:09 PM   #1 (permalink)
1993 f450 blowing white smoke
i have a 93 f450 non turbo and its blowing white smoke like crazy and smells like diesel check oil looks good checks water level and also looks good so i don't think it could be the head gasket could be wrong also the truck has been sitting for 2 years or so thought maybe fuel wnt bad but put fresh in and still doing the same thin any help would be great
bounty21061 is offline
Old 10-20-2006, 11:00 PM   #2 (permalink)
Re: 1993 f450 blowing white smoke
if it has a lot of miles or just wasnt taken care of that could be your problem. it could have compression problem or have worn injectors. my 88 F250 with 300,000 smokes like crazy just because its old and worn out.
1987 F350 4 Door 6.9IDI 5Spd Banks Turbo Dually -1986 F250 Reg Cab 6.9IDI 4spd 4X4 Dually-1988 F250 Reg Cab 7.3IDI C6-1985 F250 Ext Cab 7.6 DT466 10spd
http://community.webshots.com/user/MyDTpickup
INTERNATIONALDIESELPOWER
MyDTpickup is offline
Old 10-20-2006, 11:21 PM   #3 (permalink)
it only has 140,000 miles on the truck some one said also a injector pump or something of that nature but i did a search and i don't think they had one on that year i could be wrong don't know nothing about diesels my first 1 . and autozone isn't showing one for that truck
Old 10-21-2006, 12:49 PM   #4 (permalink)
I have a '94 with100,000 on it and it is doing much of what you are describing. White smoke at idle and eye burning fumes. It also does not idle real smoth. Local injection shop told me the inj pump needs replaced. Seams as though there is a timing advancer in the bottom of the pump that wears out thus throwing the timing off. They explained it like a vacum advance on a gasser( for those of us that are trying to reform lol) Ken at DPS agreed with the theory and feels that a new pump and injectors will fix me right up. So.. I'm about to bite the bullet and order one to the tune of just under $700.00.
NEW:- 2000 f-350 4x4 dually. Bully Dog exhaust brake. 4" straight pipe with single 5"stack in bed.
CRASHED:-1986 F-350 4x4 dually. Hillsboro flatbed. 3" aluminized exhaust t'd under bed.5" stacks.'94 7.3 turbo diesel with ATS upgrade kit.Kenwood cd player, Autometer; pyro,boost,trany temp,oil pressure, and engine temp. Jasper transmission and transfer case. "B&M suppercooler" Trany cooler. Perma-cool electric fans. Holly "Red" fuel pump. 9' fisher commercial snow plow. Munci live hydo pump; 5 core radiator(can't remember brand) More $$$ then if I'd have bought a new one!!
stevehastings is offline
Old 10-21-2006, 05:44 PM   #5 (permalink)
i just found 1 for 300.00 where i live i'll pick it it tommorrow and try it to see if it works
Old 10-21-2006, 08:39 PM   #6 (permalink)
I just went through all of this with my 1994 F250 IDI non-tubo with 209K miles on the original IP and injectors ( see- http://forums.thedieselstop.com/ubbthrea...e=0#Post3031814 ) . I did the R&R labor and spent about $750 on the IP , new injectors , and paying a diesel shop to get it timed and some minor loose ends fixed. No smoke now and it seems to have a great deal more power than I it had when I have owened it ( I bought it 20K miles ago) . 'Still a few minor loose ends to deal woth but this was time and money well spent for me . Thanks again to the people here that have responded to my questions .
1994 F250 7.3 IDI E4OD
rkpatt is offline
Old 10-21-2006, 08:42 PM   #7 (permalink)
so i guess when you replace the pump it has to go to the shop to have it timed in is that correct
Old 10-21-2006, 08:53 PM   #8 (permalink)
Yes. It will run if you do the install properly but it it will need to be timed to get optimum performance . I takes a special timing meter or a special pulse timing light adapter which you probably would want to buy for basically a one time use. Some people can time close it by ear but that is not usually the case .
rkpatt is offline
» Sponsor Links
»Garage Storage and Cabinets
