1993 Ford F350 (non turbo) Fuel sending unit - Diesel Forum - TheDieselStop.com
post #1 of 18 (permalink) Old 05-13-2009, 09:29 PM Thread Starter
I think my fuel sending unit went out today but I just want some advice to make sure before I spend money to buy a new one. On Saturday I was driving my truck and the fuel gauge shot all the way to full then slowly came back down then today I started it up and it shot all the way past full and is stuck there now if I flip to the front tank the gauge works fine but when I switch back to the rear it goes all the way past full again and I know the rear tank is at about a quarter I went to the fuel station to get diesel and I put about 15 gallons in her and she is still shot past full. I pulled out my test light and my test light tests both positive and negative and I am getting both back on my tanks harness. So do you think it my fuel sending unit or should I be checking something else? Thanks!
fl3590 is offline
post #2 of 18 (permalink) Old 05-13-2009, 11:51 PM
cdnsarguy's Avatar
My Photos: (109)
Could be the sender is worn out....... try Rock auto for a new one.
Here are the fuel guage test #s
22 ohms sent to the guage it reads empty "E"
145 ohm sent to the guage it reads full "F"
Here are the sender test #s
Sender at empty stop 14-18 ohms
Sender at full stop 154-162 ohms
Proud Canadian BOOB man too!!
cdnsarguy is offline
post #3 of 18 (permalink) Old 05-14-2009, 01:47 AM
See this thread -
Fuel gauge "stuck"
1994 F250 7.3 IDI E4OD
rkpatt is offline
post #4 of 18 (permalink) Old 04-28-2012, 12:22 PM
Can't find this sending unit!
I'm also looking for the sending unit to a 1993 non-turbo diesel. I have the front-rear 2 tank setup and I need the sending unit for the rear tank. I checked Rock Auto and they don't list the one I need. Anyone know of another place to find it? I also tried all the local auto parts stores, AutoZone, Robbins, Ford, etc. etc. Everyone seems to try to sell me one with a fuel pump on it.
mwc32m is offline
post #5 of 18 (permalink) Old 04-28-2012, 04:40 PM
nbkr341's Avatar
I have the same year and tank configuration as you, and I just ordered the right sending units from rock auto a few weeks ago. They should have it. I think it's part number PS20 or PS21.
93 Ford F250 7.3 IDI
2wd
E4OD Auto
31" bfg all terrains
Just rolled 100k original miles
nbkr341 is offline
post #6 of 18 (permalink) Old 04-28-2012, 08:31 PM
Mongus's Avatar
So, both my front and rear went out on my 92, all with in 3 months.
I had a hard time believing this happened. I decided to look at them both before spending that much cash. I am soooooo glad I did.
The floats are made from very thin copper or brass ? It really did not matter, they had very minor fractures from the mounting clips they hang from, thus fuel of diesel and not floating.
I took them out, drained, cleaned, and finally applied a really good gasket making type sealer on the fractures.
3 months later, all is working perfect.
Easy for me, this happened on my dump truck.
Total time - 1 hour start to finish.
Check em first, before dropping that cash !
Mongus rigs;
1992 F-Superduty Dump truck 7.3 - Luk SMF 5spd 5:13 rears-Ricksons 19.5 wheels & tires-Banks get kits.
This is my work hoarse !
2000 F550 - Crew cab -Custom Hood
Harley Flamed Fenders & Doors.
4x4-7.3 - South Bend 6spd 4:88 rears. Loaded ! Volant intake
Hog Performance 4" SS exhaust
Banks wheel, turbine, exhaust brake-Ceramic coated
AFE Blade Runner Spyder
Strickley Diesel Return Fuel & Banjo Bolts
IH up pipes - ceramic coated
Powder coated everything.
Brake Performance-slotted & dimpled rotors with performance pads
DP Tuner 80 Tow
Coolant filter system
Evens Coolant
203 thermostat
Bullet Liner coated Dana 60 front end
2008 F-350 Harley Davidson Crew cab - long bed - 6.4 - Banks-Six gun-Air intake-IQ-Dual Exhaust
2004 Pace American 28' x 9' x 8' enclosed work trailer. 18k GVW. Tri axle - loaded
Custom Built Roll -Off dump trailer. 17yard box. Double dual axles. 20k GVW.
Fully decked 2003 Anni Fat Boy.
Rare "Reaper Tins"
Mongus is offline
post #7 of 18 (permalink) Old 04-29-2012, 09:23 AM
drinkypoo's Avatar
My Photos: (25)
I did that with my rear tank, time to try it with my front I guess. I used RTV to seal mine.
1997 Audi A8 Quattro 225k Warm/Cold packages
drinkypoo is offline
post #8 of 18 (permalink) Old 04-29-2012, 08:33 PM
LTG
LTG's Avatar
will the gasket or rtv sealant deteriorate from the diesel fuel? would it be better to solder it if its copper or brass?
1990
F350 XLT Lariat 4x4 Crew Cab, 8' Bed, 7.3L IDI- E40D rebuilt 7/29/12 with shift kit and Pro Torque Conv,Tru Cool Low Drop Aux Trans Cooler-Rodney Red Custom Fit Aluminum Rad- Dana 60, Sterling 10.25 Rear, Mickey Thompson Classic II Pro Comp A/T 315x75 load D,Bilsteins 4600's x4, Manf. on 5/90 at
MOTOR CO. OF
Truck was purchased from Good Guys Auto Sales in Olympia,WA. 5 of 2010
LTG is offline
post #9 of 18 (permalink) Old 04-29-2012, 09:14 PM
chuckster57's Avatar
I have soldered a few floats in my day. Just make sure ALL the fuel is cleaned out and dry.
Answered on my iPhone.
Train Horns:
PM please not visitor message
chuckster57 is offline
post #10 of 18 (permalink) Old 04-29-2012, 09:23 PM
LTG
LTG's Avatar
I have the same problem with my midship tank. have to drop the tank and take a look. is it a ***** to undue the straps ?
1990
MOTOR CO. OF
LTG is offline
post #11 of 18 (permalink) Old 04-29-2012, 09:27 PM
I think it's easier to lift the bed. Just leave the rear bolts in loose and lift the front.
Train Horns:
post #12 of 18 (permalink) Old 04-29-2012, 10:19 PM
nbkr341's Avatar
Big +1. 6 bolts and a couple hundred pounds.
2wd
E4OD Auto
nbkr341 is offline
post #13 of 18 (permalink) Old 04-29-2012, 10:27 PM
I use my engine hoist. Changed a fuel pump in a full size Chevy in 25 minutes start to finish.
Train Horns:
post #14 of 18 (permalink) Old 05-01-2012, 11:04 AM
I am having the same problem with my senders, but removing the bed is not really possible as the previous owner welded part of the gooseneck hitch to the bed. Don't know why he did that, but the bed is not comming off short of cutting it off. Is there any good way to get the straps off the mid tank without taking the bed off and that would be a whole other mess to deal with. I have looked at taking it down a few times and each time I said to myself, "I can live with a bad sender." But really it would be nice to fix it if I can get those straps loose and and then back on. Has anyone done it without removing the bed?
1994 Ford F350 Crew Cab Dually 7.3 IDI NA
~100K on WVO! Now needs new head gasket
1991 Ford F250 Extra Cab Lariat 7.3 IDI NA
1989 International S1600 Box Truck 7.3 IDI NA
1980 Mercedes 300TD Wagon
durlecs is offline
post #15 of 18 (permalink) Old 05-01-2012, 04:33 PM
drinkypoo's Avatar
My Photos: (25)
You don't need to remove the bed, the straps bolt on. I took my rear tank down, but I lifted the bed for my front tank, and now I need to do it again (did pickup doing sender)
