2wd front lift - Diesel Forum - TheDieselStop.com
Old 10-12-2005, 06:46 PM   #1 (permalink)
My Photos: (13)
2wd front lift
The truck has always set low in the front and I would like to raise it 1" to 2". What would be a simple way to do so? I have seen the red airbags that go inside the coil...anyone here using them? Just wonder if they would make ruff ride rougher? Also saw some sort of spacer that goes under the spring. Want your opinions here...everybody's!!!!!!
1989 F250 single cab 2WD
7.3 IDI with 200,000 miles
Single Straight Exhaust with 4" Chrome Tip
No Soupbowl
E40D
LT 265/75/16 Hankook ATM's on 16x7 Eagle Wheels
Gooseneck hitch
Homade rear pipe bumper with built in utility-lights and D-rings
Diamond Plate Aluminum Toolbox
Tinted Windows
Roof Markers
1995 F150
Single Cab Short Bed
4.9 Straight Six
5 Speed
1997 F250 Extended cab 4x4
PowerStroke Diesel, E40D, Manual Hubs
Tymar Intake - No Cat, 18" Glasspack
welder79 is offline
Old 10-12-2005, 07:04 PM   #2 (permalink)
Re: 2wd front lift
I use the "inside coil" airbags on my E350 van. They make the ride a little bouncy, but not rough. I like the air bags because they are adjustable, and I can use them to alter the suspension height to change the alignment (camber) setting.
You could also swap in a set of F350 2WD coil springs.
*ASE Master Certified, Medium & Heavy Trucks*
Mr_Roboto is offline
Old 10-12-2005, 08:52 PM   #3 (permalink)
My Photos: (13)
Re: 2wd front lift
I opted for the heavier springs on a previous truck and there wasn't really any difference to speak of. How high can you rqise the front before a realignment is needed?
No Soupbowl
E40D
Gooseneck hitch
Tinted Windows
Roof Markers
1995 F150
4.9 Straight Six
5 Speed
welder79 is offline
Old 10-12-2005, 10:07 PM   #4 (permalink)
Re: 2wd front lift
ANY suspension height changes in the Twin I Beam suspension changes camber, and to a lesser amount toe-in.
After I installed my air bags, I turned my caster / camber bushing to pull the ball joint all the way inside, then used the air bags to raise the suspension to get the camber correct (basically the tire straight up and down).
It's really easy to adjust, the bushing is turned by a 1-1/2" socket, after loosening the pinch bolt. You can actually see the spindle move around quite a bit as you turn the bushing.
Old 10-12-2005, 11:08 PM   #5 (permalink)
Re: 2wd front lift
I fabricated a 6" lift on the front of my 79 f100 ranger 2 wheel drive; It had the twin I beam, is that what your truck has?
What I did was I removed the spring perches, I removed the rivets with an air chisel. Then I welded together 3 2x2 inch pieces of steal square tubing .25" thick and put the stack between the frame and the spring perch. I bolted these blocks to the frame and bolted the sping perch to the block in all the places the rivets had held it to the fram. I put the same blocks under the brackets that hold the strut things that locate the I beam front to back. Since I moved the whole spring perch, the spring position and the shock mount as well as the spot the oposing I beam ataches moved down with it, its all connected. Therefore my ride, steering, caster/camber is still all the same. I just had to relocate the brake line bracket. For the back of the truck I just flipped the shackle upsidown and used 3" blocks.
I'm not sure all of this was the right way but they realy don't make kits for 2WD trucks and Im cheap and like to make stuff. I'm planning on building a lift for my 94 f250 turbodiesel 4x4 soon.
Another way you could do it since you don't want to go too high is spring spacers, they're made of polyurithan or something and just fit at the top or botom, I'm not sure, between your spring and the perch to give you 1" or 2" of lift depending on which size you buy. 4wheelparts.com should have em. You will have to adjust your camber as it will be too positive, not sure how far you can go, on my twin I beam truck there were no camber adjustments and thats why I did what I did.
I can send you pics if you like.
-Rob
'94 F250 XLT 7.3L. Turbo Diesel 4X4 "OFF ROAD" package, X-Cab, 4.10 grears, Now a 5 speed, original IP, just did injectors,"Wallace mod" 3.5" turbo outlet housing and 3.5" DP and straight piped exhaust, 113K on the clock. Repainted it black. Ispro pyro and boost gauges, turned up pump.
ClassicFordGuy is offline
Old 10-12-2005, 11:34 PM   #6 (permalink)
e444's Avatar
Re: 2wd front lift
moog cc860 springs gives 13/4 in of lift been on my e350 for 75k miles and still sits good realignment is needed plus springs were only $75 a set
2002 e350 power stroke former patty wagon egt boost tach gauges walkers btm diy intake 130k miles dp tuner f5 80e 100 140 extreme overboost annihilator 410 gears
e444 is offline
Old 10-13-2005, 08:53 AM   #7 (permalink)
My Photos: (13)
Re: 2wd front lift
Would like some pics.
Sounds as though I have a few options.....just which way to go?
Anyone else?
No Soupbowl
E40D
Gooseneck hitch
Tinted Windows
Roof Markers
1995 F150
4.9 Straight Six
5 Speed
welder79 is offline
Old 10-13-2005, 01:51 PM   #8 (permalink)
My Photos: (23)
Re: 2wd front lift
I'd go with a spring swap. That's your best option.
- Mel
1983 F-250HD 4X4 The Moose Truck - Moose Pump, Moose Mister Injectors, Hypermax Turbo, Intercooler, GV 7spd., 3.54 Gears, Moose Air, RDT, Dual Stacks, 35"tires. My Album 55MPH at 1400 RPM. 19MPG Avg.
1993 F-350 CC DRW The Lady Moose - Hypermax Turbo, GV 9spd w/Double OD. 4.10's. Dual Exhaust, custom trim, turned up 6.9 fuel system, Lucky Flywheel.
1987 Bronco The Moosestang 1987 Bronco Diesel 6.9L C6 4X4 with 3.54 gears, 2" body lift.
HeadGasket/Turbo Article
A BOOB man! Visit EZBoard.com and search for IDI.
agnem is offline
Old 10-13-2005, 09:24 PM   #9 (permalink)
Re: 2wd front lift
I can either emial you pics or post them on the sight, I have quit a few.
I can't figure out how to post em?
-Rob
Old 10-14-2005, 01:05 PM   #10 (permalink)
My Photos: (13)
Re: 2wd front lift
Email works for me!
No Soupbowl
E40D
Gooseneck hitch
Tinted Windows
Roof Markers
1995 F150
4.9 Straight Six
5 Speed
welder79 is offline
Old 10-26-2005, 10:55 AM   #11 (permalink)
Re: 2wd front lift
I know
Fabtech
makes a nice lift kit for our trucks
1989 F250 7.3 N/A 2wd bone stock finally fires in the cold!!!!!!!!!!!!!!!!!!!!
dont miss out ***************
Proud BOOB man http://p087.ezboard.com/bmidatlanticforddieselclub
dbarilow is offline
