Old 03-23-2005, 12:58 AM   #1 (permalink)
My Photos: (15)
3" - 4" - 5" ? What's too much?
Exhaust that is. What is the optimum size on a 7.3 with a Banks Non-wastegate turbo?
Is there any benefit to running a pipe size larger than the outlet on the turbo?
Mike
89' F350 Crew Cab 4x4 E40D 4.10:1 Early Banks Turbo No More Trans Command - Transgo "TUGGER" 5" Stacks Bronco 33gal Tank
Runboys Pics
Runboy is offline
Old 03-23-2005, 03:36 AM   #2 (permalink)
towcat's Avatar
Re: 3" - 4" - 5" ? What's too much?
the larger the diameter the less high rpm "bark" downside is the noise. Its enough to bring the law down on you.
86 f250 6.9IDI, 4spd 4X4 "the runt"
89 f450 rollback carrier 7.3IDI, ZF5, 4X2(in memory of...)
90 f450 conventional towtruck 60"CA 7.3IDI, E4OD, 4X2
92 f350 CC 7.3IDI, ATSturbo*intercooled*, ZF5, hydrostop, 4X2 "the nebuchadnezzar"
...Quack Quack................*P.A.K.*...
red pill or the blue pill? make your choice and pm me.
7/03 mini meet pics
towcat is offline
Old 03-23-2005, 07:45 AM   #3 (permalink)
IMHO, Once you get up to 8" or so [img]/ubbthreads/images/graemlins/phoney.gif[/img] stovepipe size, that might be a little big. LOL
New rig: 1995 Dodge 2500 LB, Reg. Cab, 4x4, Cummins, 3k GSK, Hillbilly plate ground, 4" exhaust, 285/75/16s
Old rig:
1989 F-250 7.3 IDI, 4x4, 4" Rough Country Lift, Hypermax Turbo, 128K, 5 Speed, 4.10 gears, Custom air intake, "MIG-Made" Propane Kit, 3.5" Dual Chrome Stacks w/ straight exhaust, 285/75/16 tires on Classic 589s, Pioneer MP3 Player with 10" sub, Galaxy DX959 CB. Savin' some bread for some new 315/75 shoes.
My drinking team has a rockcrawling problem.
Hold it 'til the valves float!
nosliw is offline
Old 03-23-2005, 10:52 AM   #4 (permalink)
My Photos: (13)
Towcat is right about the bark, once you get above a 3" pipe you will cut down on the bark and loud rap at higher RPM's. The 4" sounds really nice and deep, not a sharp bark. If you are going to do it, it really can't cost too much more to run 4" pipe. Scotty
Semper Fi
Scott Beretz
2006 Dodge Megacab 4x4, Cummins, 6 Speed, Airbags, Quadzilla Commander, XZillaraider 2, 285/75R17 Toyo OC AT's
Pulls a: 3814SS Keystone Raptor Toyhauler w/Quads
beretzs is offline
Old 03-23-2005, 01:37 PM   #5 (permalink)
So you will get more power out of a 4 inch cause it breaths better but you wont get the noise? Im thinking about going duals straight out behind the rear bumper with no muffler or with a good sounding one. Will a 3inch or 4inch perform and sound better. Im guessing the 4 will perform better but not as good, im not sure. What am I better to go with if I put on a banks wastegated turbo?
Jimmy C.
89 F350 7.3 IDI Diesel, 110,000 miles, Black and silver, single cab long. 4x4 XLT Lariat. 5 Speed Manual, very clean truck. Banks sidewinder kit, 4" dual stainless magnaflow exhaust, 4" skyjacker suspension kit with rear add leafs. Chrome Pro Comp wheels, 35" Pro Comp Mud Terrains.
JCDiesel89 is offline
Old 03-23-2005, 03:15 PM   #6 (permalink)
My Photos: (13)
I went from the Banks 3-3.5 inch system to a 4" straigth pipe and it looks, sounds and perfroms better, but most of the performance is due to not having the muffler. If I had just deleted the muffler, I probably would have gotten the same results. Scotty
Semper Fi
Scott Beretz
beretzs is offline
Old 03-23-2005, 03:46 PM   #7 (permalink)
Vek
I just completed a 5" exhaust system for my '89 cc 4x4. I have the Hypermax turbo system. Here's the system, from the turbo back:
I went with the first half of the factory 2.5" downpipe. This piece has a bracket which bolts to the turbo mount bracket on the back of the starboard cylinder head. This piece ends right as it clears the firewall under the truck.
From there, instead of attaching the rear half of the hypermax 2.5" downpipe, I attached the hypermax exhaust system's 2.5" x 3.5" reducer, welded to an appropriately-shaped chunk of the hypermax 3.5" over-the-axle pipe. The tailpipe section I selected ends up puking straight back, right beside the transmission.
From there, I welded my 3.5" x 4" reducer, and 4" x 5" reducer. This ends right behind the tranny crossmember.
From there, I clamped a straight ~8' length of 5" pipe.
From there, I welded the front half of the 5" tailpipe for a '99-'03 from shopdiesel.com.
From there, I clamped the back half of the shopdiesel 5" tailpipe.
I welded supports to match the factory hanger locations, all the way back. I made the supports out of 3/8" steel rod, bent to match the pipe contour, and made to hang the system as high in the chassis as possible. In front of the axle, almost all of the pipe is obscured by the frame rail. It spits out at an eye-appealing (not too low, as I've seen on other systems) level behind the rear axle, angled slightly downward and backward.
The turbo kit came from my totaled '88 x-cab, and I wanted a bigger exhaust, as the aftermarket 3.5" systems are a bit "hissy" for my taste. No more of that! The truck sounds flat-out angry now. You don't notice it in the cab with the windows up. With the starboard rear window down, you notice a rumble. But, when you get beside a concrete divider, wall, or overpass, you can really hear the bark if you get on it. I haven't been harassed yet (only 3 months along), but it is quite a bit louder than the straight 3.5" pipe.
Not a difficult install, just a bit time-consuming. A muffler shop should be able to set something like this up for pretty cheap, if you supplied the tailpipe (and hardware, if they gouge you).
I'd do it again in a heartbeat. It sounds great.
Jerry V.
1988 F-250 XC 4x4 5-sp. 3.55s ~100,000 miles
Hypermax Turbo, Big Exhaust (edit) T-boned 1/02, totaled 3/02, parked 3/02, stripped of turbo 12/04, will be retitled and sold.
(edit) 1986 F-250 XC 4x4 4-sp 3.55s 230k Hypermax Turbo, Intercooler, Big exhaust - bought 2/02, run hard, 12/04 stripped of intercooler, will be sold with just turbo. Best vehicle I've owned.
(edit) 1989 F-350 cc 4x4 200k, Custom (not even an XL), only luxury item is cruise control. Receipient of turbo from '88 and intercooler from '86 in 12/04. 5-inch exhaust added 1/05. USGear overdrive waiting in the wings.
Vek is offline
