3/4 ton to 1 ton conversion - Diesel Forum - TheDieselStop.com
post #1 of 22 (permalink) Old 12-18-2005, 10:29 AM Thread Starter
I want to know what I'm looking at to convert my truck too a ton. I plan on putting a flat bed on. Can I not change calibars and rotors to a ton because I have the large bearings on my axles. Thanks for any help.
01, F-350 XL, SRW, 4X4, 7.3, Auto, Crewcab long bed.
TRADED: Burgandy,93,F-250 XLT(converted to a dually and added 9' flatbed),4x4,Super Cab,E4OD(converted to ZF5),7.3 IDI Nonturbo(Added ATS Turbo 3.5" down pipe with 4" straight pipe turned out in front of the rear wheel), 4.10 rearends average 15 miles to a gallon.
Pulling Toys, 2000 model 16' Stock Colt Gooseneck Horse Trailer W/Custom Built Sleeping Quarters, 16' flat bed trailer that I haul my 35 h.p. 4x4 tractor w/front loader and backhoe attachment, 88 29' Terry tag along camper and also pull my 18' Ranger bass boat.
paintedreams93 is offline
post #2 of 22 (permalink) Old 12-18-2005, 11:00 AM
cdnsarguy's Avatar
My Photos: (109)
Re: 3/4 ton to 1 ton conversion
No matter what you do brake/axle/spring wise the frame will still be a 3/4 ton.
Proud Canadian BOOB man too!!
cdnsarguy is offline
post #3 of 22 (permalink) Old 12-18-2005, 05:37 PM
i have yet to see the real differnece between a juan ton and the 3/4 minus the rear springs and hangers. if you have the dual calipers, you share the same front and rear brakes as the one ton. the front 2wd springs are the same. the rear springs on most 1 tons DO NOT have helpers. some did, and it seems like they were mostly duallies though. my 3/4 has a 8 and 7 spring, spring pack out rear and "F350" hangers. well at least thats what they are stamped with. no overloads, and that 2500lb load of pellets never dropped her more than 3/4 of an inch. the frames measure the same thickness between my 85 4x4 f350 gasser dually and 88 f250 2wd diesel, and i see no extra crossmembers. i am not really sure what the extra weight difference is between them, but it seems the SRW F350 was always a bit heavier. if i was going to own a f350, it would be a dually, i would not was my time on a F350 SRW..
no matter what you decide to do, your truck is still only a 3/4 ton. be happy though. most 3/4 ton SRW will carry more weight than most 1T SRW trucks can.. its all about "GVW-Curb Weight= How much junk you can carry". but as for towing, most duallies will take you down there as there GCVWR is ALOT higher...
It is the soldier, Who salutes the flag, Who serves beneath the flag, And whose coffin is draped by the flag, Who allows the protestor to burn the flag.
Father Dennis Edward O'Brien, USMC
Semper Fi 16.5 years and counting
huskyhauler is offline
post #4 of 22 (permalink) Old 12-18-2005, 06:51 PM
My Photos: (15)
huskyhauler, so your saying it is more of a "load rating" thing than an actual physical difference?
I know my old mans 05 F250 Crew Cab 4x4 Short Box FX4 has a higher GVW than my 89 F350 Crew Cab 4x4 Long Bed. Go figure [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Mike
89' F350 Crew Cab 4x4 E40D 4.10:1 Early Banks Turbo No More Trans Command - Transgo "TUGGER" 5" Stacks Bronco 33gal Tank
Runboy is offline
post #5 of 22 (permalink) Old 12-18-2005, 08:35 PM Thread Starter
Well I was just wanting to put dual wheels on because it would look better under the flat bed.
post #6 of 22 (permalink) Old 12-18-2005, 10:22 PM
been thinking here myself on changing also but i dont have the money right now. but i had made a post on this samething about a week ago and someone sent me a link to some wheel adapters i talked to teh guy and he said it would be around 500.00 to get them to run duel wheels on the back and the bud style on the front to give it the dulley look. because i need to put a flat on the back of mine too bed rotten with the rest of the truck, nicked the truck titantic
1994 f250 super duty ext. cab 7.3l IDI turbo. 4x4 manual tranny. I am new to the diesel trucks, i bought this truck to pull my tractor and equipment for my landscaping business
ncfirefighter46 is offline
post #7 of 22 (permalink) Old 12-19-2005, 07:54 AM
Supercab79's Avatar
Paint I don't understand exactly what you are asking are you looking to make your truck a legal one ton by name, weight, paper work or just in apperance the frames are the same the rear is the same the rear leaf packs are the same the brakes are the same the front axle and springs are not but easy enough to change now this is only true if you are staying single wheel not changing over to a dually. As far as saying your 3/4 ton will always be just a 3/4 ton is not totally true. It really depends on what exactly you are trying to accomplish. To say changing the cab is needed is crazy it has absolutly no bearing on anything other than VIN designaton of what is displayed on the title. As far as GVW's are concerned EXAMPLE- 88 F350 standard cab 4x4 diesel GVW= 9000lb. 88 F250 standard cab 4x4 diesel GVW=8600lb. Only difference F350 rear spring pack equipted with a single over load. Truck to truck empty weight diff is the F250 is 143lbs. liter. so the F350 can leaglly haul 257lbs. more than the F250.
If you need any further #'s or spring codes dually adapter info or any thing feel free to PM me I can give you as much info as I have from frame thickness to spring load ratings just let me know.
Good luck
Marc
06 Dodge 3500 Laramie 4X4 Megacab Short Bed 5.9CTD
97 F-250 XLT 4X4 C/C Short Bed PSD, D60 Front Axle Conversion Tymar Open Air Intake, Full 4" Exhaust, DP 3 Pos Chip, Banks Billet Converter, ISSPRO Triple set, Banks Techi Cooler
87 F-350 XL 4X4 Stakebody 6.9 5 Speed (22 Years) OLD ENOUGH TO SMOKE
77 F-250 Custom 4X4 Crew Cab Short Bed 400M C6
06 Tahoe LT
97 Holiday Rambler 32.5' 5TH Wheel Alumilite
96 F-350 XL 4x4 Utiliy Body 460cid E4OD
96 Honda Foreman 400
GONE 3/6/07 BUT NOT FORGOTTEN LONG LIVE THE IDI
93 F-250 XLT 4X4 4" Banks Sidewinder and Straight Pipe, Straight Axle Conversion
Supercab79 is offline
post #8 of 22 (permalink) Old 12-19-2005, 09:24 AM
The frames are the same in thickness, etc.. but they are different in width. The one ton frame is 2 and 2/4 inches narrower. A 1 ton rear end will NOT bolt under a 3/4 to unless you move the spring pad, not will the sway bar from a 1 ton fit in the correct location unless you move the mounting location of the links to the inside of the frame (boxing in the frame)..
Leo
1994 Ford F-350 CC with 105K. Slowly plugging away at achieving mechanical nirvania and a turbo with bigger exhaust system.
1960 Austin Healey Bugeye.. TOTALLY restored to stock configuration and NEW condition
My baby
60bugeye is offline
post #9 of 22 (permalink) Old 12-19-2005, 10:31 AM
My Photos: (15)
Supercab79, question on rear leaf interchangability. I have an 89 F350 Crew Cab 4x4 SRW and am looking to raise the rear approx. 2-3 inches and soften the ride at the same time. This truck spends 85% of it's time running empty. I was thinking of going to a softer rear spring and maybe an Air helper for the times when I need to bring the load capacity back up. What do you think on this?
I know on the Ranger pickups the 4x4's ran a real flat spring with a block and the 2WD's had a higher arch spring with no block. Was wondering if the 350's had a similar situation? Meaning - swap in a 2WD spring for lift. Or maybe a 2WD F-150 spring for lift and softness?
I would be willing to add a Track Bar etc. to stabilize the rear when under load. What do you think?
Mike
Runboy is offline
post #10 of 22 (permalink) Old 12-19-2005, 02:14 PM
hesutton's Avatar
My Photos: (30)
As far as the frame differences between F350 and F250. There are no differences in the frames. I have personally swapped drivetrain parts (front and rear axles, spring, sway-bars) between a F350 and a F250. The frame is not different. In fact, the F350 frame had the holes drilled for the TTB brakets for the F250 Dana 44. The TTB Dana 44 simpley bolted into place on the F350. The trucks are 7 model years different as well. I'm not trying to argue with anyone, but, my personal experience with F350's and F250's..........NO DIFFERENCE IN FRAMES. The other differences are drivetrain related only, and they are minor.
Heath
1986 F250HD 4x4 7.3L IDI '95 PSD front clip, '97 bed, T19, D60/10.25 with 3.55's. Rebuilt from the frame up. Banks Turbo, DPS IP & Stage 1's, Isspro TTM, Banks Exhaust, Boost gauge, Pyrometer, Precharged Coolant Filter,
. 16.5 x 37 x 12.5 Goodyear Wrangler's, Air Horns. 6in lift, Fresh Paint, On-board Air. Revamped Interior. Rhino Liner.
1983 F250 4x4 5.0L with C6. 340,000+ miles.
hesutton is offline
post #11 of 22 (permalink) Old 12-19-2005, 02:44 PM
Has anybody actually ever been stopped for too much weight if it wasn't painfully obvious? Just curious.
Dane
1988 F250 4X4 Super Cab ZF XLT (Gone-sold) 1994 F250 4X4 Super Cab E4OD XLT 7.5L
Dane Launius is offline
post #12 of 22 (permalink) Old 12-19-2005, 05:04 PM
If your just wanting to run duals you will need the adapters for the rear. If you don't the tires will hit the springs. Or you could find a rear out of a dually with the pickup bed. It will be wide enough to clear those springs. If you want to run the dual style up front, you will need the front adapters also.
00 Excursion 6.8 4X4 4.30 LS
97 F-350 SRW R/C 4X4 7.3 Auto. 4.10 LS
91 F-250 R/C D-60 conv. 4X4 7.3IDI Manual 4.10 LS
87 Chevrolet 1/2 ton 4X4 5.7TBI Auto. Stepside
71 Land Rover Series IIA 2.25 Manual
DarylB is offline
post #13 of 22 (permalink) Old 12-19-2005, 06:51 PM Thread Starter
Is $500's for both together or separate.
post #14 of 22 (permalink) Old 12-19-2005, 07:12 PM
500.00 to 550.00 is what i got from the guy let see if i can get the link to the site http://www.wheeladapter.com/ that is front and rear i think he siad 200 or 250 for the real and 300 for the front
post #15 of 22 (permalink) Old 12-19-2005, 09:45 PM
Guest
Posts: n/a
Post deleted by JLester
